Old 20th March 2017, 9:42 PM   #3346
mAJORD
mAJORD's Avatar
Originally Posted by lithos View Post
Hmmm...the Ryzen 5 1600x is using the exact same die as the 1800x, just with two cores...disabled.
Is it too much to hope the same unlockability as with my Phenom II 555 dual core B55 quad core?
only if they allow to happen again
PS the R3/R5 quads are all 8core die as well, so yeah, would be great wouldn't it. (albeit the odds of unlocking a full octo from an quad would be pretty low!)
On the Bench: Ryzen 7 1700 - MSI B350 Tomahawk/Asrock AB350 Pro 4 - 16GB Corsair Vengance DDR4-3200
Ryzen OC / Owners Thread
Join OCAU to remove this ad!
Old 20th March 2017, 10:33 PM   #3347
Court Jester
Court Jester's Avatar
they will alos be reusing chips that have defective cores as well. So you might be re activating faulty cores that will cause issues.
like I said much earlier in this thread im looking forward to the 1600x that is where I see as the sweet spot for these chips.
Many suscessful trades over the past 11 years
Current system: i7 3820 @ 4.6ghz
Court Jester is online now   Reply With Quote
Old 21st March 2017, 11:36 AM   #3348
ipv6ready
Is Ryzen 1700 for $AUD 400 delivered good value?
4k nut UP3214Q, UP2414Q and U28D590D
MSI Z77a-GD80, Cosmos II, i7-3770k, Swiftech H240-X, Gigabyte G1 GTX1070, G.Skill 32mb 1600, 256GB Samsung Pro 840, 120GB Sandisk Extreme, LSi 9261, 8 x 1TB WB Black HDD, Seasonic 660w Platinum, Cyberpower UPS
ipv6ready is offline   Reply With Quote
Old 21st March 2017, 11:53 AM   #3349
Sipheren
Sipheren's Avatar
It's $469 plus post from PCCG, so what do you think? lol
Check the prices around and pick the cheapest.
Win 10 - AMD R7 1700 @ 3.7GHz - Asus ROG Crosshair VI Hero - 32GB DDR4 - nVidia GTX TITAN XP - InWin 805 Red | HTPC - Gigabyte BRIX i3 4010 | NAS - unRAID (12TB)
HTC Vive VR Headset
CAR - 03 BA Ford Fairmont Ghia 5.4L | Sipheren Racing Videos
Sipheren is offline   Reply With Quote
Old 21st March 2017, 12:08 PM   #3350
ipv6ready
I should clarify is 1700 at $400 a better choice in relation to 1700x at $479
It's 20% off rrp at the moment
Old 21st March 2017, 12:13 PM   #3351
Sipheren
Sipheren's Avatar
Ah, I would say yes, the 1700 is better value than all the current Ryzen chips, it clocks just as far, uses less power and costs less. Comes with a cooler as well
Go for it.
HTC Vive VR Headset
Old 21st March 2017, 12:21 PM   #3352
TaroT
TaroT's Avatar
value wise yes the 1700 is the go BUT clocked the same i can't see it using less power than the other 2.
also you buying into the silicon lottery 80% of the chips i have seen so far easily hit 3.9 but not as many crack 4 or above(but then again neither do the other 2 i know i, m still trying to get past 4 )
and think of it another way $80 bucks is the difference between a ASUS pro carbon and a Baymax or a b350 and a 370...
or better ram...
If i had not wanted the top chip just because i really wanted it i would have grabbed a 1700.
or you could wait 3 weeks and see what the 1600x goes for...
that will be cheaper again and maybe even better value.
AMD R7 1800X@stock:corsair H110 cooler: ASUS X370 crosshair 6(Baymax)Corsair 3200 ddr4 @2133(for now)R9 Fury X 1100/500:
Old 21st March 2017, 12:34 PM   #3353
Sipheren
Sipheren's Avatar
or better ram...
The difference between 3.9 and 4.1 is pretty small, I would say go for the cheaper option in value terms, the only reason for the 1800 is the guaranteed base clock which isn't an issue if your overclocking anyway.
Mine will do 4, it seems most Ryzen chips top out at 4 and a few can get to 4.1/4.2, the Global Foundry 14nm fab doesn't seem to go any higher at this time, this will no doubt be true for all the coming chips as well.
Hopefully by Ryzen 2 they will have sorted the process out some more and get some higher clocks.
HTC Vive VR Headset
Old 21st March 2017, 12:40 PM   #3354
ipv6ready
eBay has 20% off tech at the moment so looking around.
I might buy the CPU and a board.
Old 21st March 2017, 12:55 PM   #3355
Digit
Digit's Avatar
I got the CPU off eBay, but I wasn't game to get the board and ram since there have been so many reported issues and I wanted some decent support if I had issues too.
Edit; eBay also didn't have the Gigabyte Gaming K7, which I ordered from SCORPTEC, along with RAM.
Ryzen 7 1700 | Gigabyte AX370-Gaming K7 | AMD RX 480 | 32GB DDR4 @2133Mhz | 5TB | 9---------------|-} Trades: lost count
Digit is offline   Reply With Quote
Old 21st March 2017, 1:08 PM   #3356
Court Jester
im eyeing a 1700 at the moment, it will be hard to beat rice wise for it with teh current sale on ebay.
or I might way for a 1600x and hope for another 20+% off sale them.
honestly i dont know what to do I will probably end up keeping my x79 board and 3820(@4.69ghz) and just buy a 1080ti instead to replace my 2 x 290x's as I pretty much only game on it and I dont think Vega will be worth the wait and wont beat the 1080ti
and I dont think I am CPU limited playing @ 4k.
Old 21st March 2017, 1:08 PM   #3357
spank36
I've got permission to get a new comp at tax time, hopefully vega is out too so I can do a full AMD build
Comp: i5 4670k, Gigabyte HD3, 8gb Gskill Sniper 1866, 290 TriX, LG 34UM67.
Sound: Pioneer VSX-519 receiver, B&W M1 bookshelf speakers, Subsonic ML1 subwoofer, Samson SR850 headphones.
spank36 is offline   Reply With Quote
Old 21st March 2017, 1:16 PM   #3358
ipv6ready
I might do something similar and just get the 1700 $400 for now.
I dont think I can lose. Plus Swiftech have run out of AM4 bracket for my X240
MB and Ram I might wait, until a tried and tested combo come on the market.
Old 21st March 2017, 3:35 PM   #3359
Bertross
Bertross's Avatar
Finally Arrived.
ASUS GTX 1070 STRIX OC | RYZEN 1700+H100I | ASUS ROG BIG HERO 6+SAMSUNG 950 PRO M.2 | 32GB TRIDENT Z RGB 3000 | PHANTEKS ENTHOO EVOLV TEMPERED |
EVGA SUPERNOVA 750 | CINTIQ 24HD+U2711 | SWAN M200MKIII+DT770 PRO+D1 DAC
Bertross is online now   Reply With Quote
Old 21st March 2017, 3:47 PM   #3360
sammy_b0i
sammy_b0i's Avatar
Originally Posted by Bertross View Post
Finally Arrived.
pix
https://youtu.be/qchPLaiKocI?t=27s
Ryzen R7 1700, MSI X370 Gaming Pro Carbon, Noctua U14S, 16GB G.Skill TridentZ 3466MHz @ 3200MHz, HD7970 DCU2 (Temp), 480GB OCZ Trion150, eVGA G2 750W, Fractal Define C, BL3200PT
Originally Posted by tommodmc View Post
OCAU is a breeding ground for hyper-moralistic 13 year olds who've never stepped out of the computer room in their entire life. Young liberals, young labor, people who will grow old and die before they ever think about pulling their head out.
sammy_b0i is online now   Reply With Quote
