Old 18th May 2015, 2:42 PM   #31
Smokin Whale
Smokin Whale's Avatar
Originally Posted by Nian View Post
I ordered last week a Gelid AM1 low profile cooler on eBay uk.
http://gelidsolutions.com/products/i...&cid=12&id=113
My plan is to build myself a car PC. With the pico psu's for cars, I expect it to run very very well.
Just out of curiosity, why not use an Android tablet? I thought X86 based car PCs were dead.
New RIG!
AMD Athlon64 x2 4400+ S939 (stock), Gigabyte K8N-SLI, 4GB DDR1 RAM, ATI X1550 256mb + X300 128MB, 24GB SSD, Triple 17" 1280x1024 monitors, Linux Mint MATE 18.1 64bit
Smokin Whale is offline   Reply With Quote
Join OCAU to remove this ad!
Old 18th May 2015, 11:02 PM   #32
Nian
Android tablets are ok but carpc's can do allot more.
E.g. More Storage, memory, speed, applications...
Asrock Fatal1ty 990FX Killer, AMD FX-8370 BE @ 4.5Ghz, G.Skill TridentX DDR3 @ 2133 Mhz 10-12-12-31 4x8Gb , 2x Gigabyte Windforce 3 R9 290X OC 4Gb GV-R929XOC-4GD, Cooler Master HAF XB EVO, Cooler Master V8
Old System: Gigabyte GA-965p-DS4 Rev. 1.0, Q9300ES @ 2.8Ghz, Team Xtreem Dark DDR2 740Mhz 4-4-4-12 4x2Gb, AFox HD7850 2Gb, Asus Xonar D2X, CoolerMaster CM690. Zalman CNPS9700 LED
Nian is offline   Reply With Quote
Old 19th May 2015, 10:38 PM   #33
Smokin Whale
How much storage do you need :s I have a Galaxy Note 2 with 64gb storage... thats a tonne of music and audiobooks. Can have up to 200GB if I want. Plenty of performance with my custom setup of CM12.1 and I'd argue the applications are far more suited for easy navigation and multimedia use than Windows 8.1 for example. Sorry to drag this off-topic but I want to be convinced CarPCs are superior but I'm just not quite seeing the value...
New RIG!
Old 19th May 2015, 11:29 PM   #34
Nian
If having more appellation then every, with much better performance and the latest Windows isn't enough. Not too sure what is.
Btw, I want most of my music on it, that's going to be a minimum of 1Tb.
Another thing, it would allow me to install cctv on the thing.
Old 20th May 2015, 1:12 AM   #35
Smokin Whale
Suit yourself, but just remember that Windows is going to struggle at things that devices designed for mobility excel at (eg. easy handling of phone calls or turn-by-turn navigation with media playing, voice input and SMS, 3G/4G connectivity, simple, customisable touchscreen UI, apps specifically designed for smaller screens without the use of a web browser, etc). I find it hard to believe that Windows 8 outpaces Android in terms of applications for the road. It's not about quantity, it's about quality, and the overal usability of the device. Performance isn't an issue with recent devices. The last thing you want to be doing though is dicking around trying to switch applications or use a web browser while on the road. Also 1TB is an insane collection of music... it would probably easier just to use something like spotify or Google Music. Or a USB-OTG external HDD, but you will want some serious playlist management or your library will be overwhelming.
As for CCTV, just get a dedicated dash cam.
New RIG!
Old 20th May 2015, 6:21 PM   #36
Nian
I believe Windows 10 will be good for a carpc...
Besides, honest question. What are you doing on the overclockers forum? This is where you take the extreme option. Not the tame off the shelf stuff. You views seem ill suited for the tone here.
Old 20th May 2015, 8:48 PM   #37
Smokin Whale
Possibly, we'll see.
This shit ain't off the shelf. I should probably do a write-up on what I've created, it's pretty unique.
Anyway, back to AM1. Has anyone found a good case ITX case for these? I'd be pretty interested if we could run a whole system off a 19v external PSU.
New RIG!
Old 20th May 2015, 9:51 PM   #38
miicah
Looked at AM1 for "upgrading" my NAS from the old i5, but none of the boards I could find had more than 2 SATA ports.
SFF Gaming>i5-4690|16GB Crucial DDR3|ASUS-H97I-PLUS mITX|EVGA GTX680|Crucial M550 M.2 256GB|Corsair RM450|Thermaltake Core V1|Edifier S550
CS:GO Videos | Motorcycle Videos
miicah is offline   Reply With Quote
Old 20th May 2015, 9:57 PM   #39
jji7skyline
I hope you were planning to do this for energy efficiency because even an old i5 is faster than these chips.
Phanteks Evolv mATX: i7-4790K/GTX980Ti
Successful trades: Over $1000+
jji7skyline is offline   Reply With Quote
Old 21st May 2015, 12:12 AM   #40
Nian
Unless it is software raid and supports the controller. Even with more sata ports, they don't do raid.
The Asrock AM1H-ITX has 4 sata ports.
http://www.asrock.com/mb/AMD/AM1H-ITX/
Old 21st May 2015, 10:59 AM   #41
miicah
Yes, I don't need the speed really. It would probably be cheaper to just undervolt the i5 though heh
Yeah software raid.
Old 21st May 2015, 11:16 AM   #42
Smokin Whale
Yeah software raid.
ZFS FTW
New RIG!
Old 21st May 2015, 11:47 AM   #43
lionman
lionman's Avatar
I just installed an android powered head unit in one of our cars. Goes pretty good. 2 sd card slots, two usb ports so plenty of storage. BT audio and hands free. Turn by turn navigation with voice activation. Reversing camera and dash camera.
Personally I think your crazy using Windows in a car.
My PC: i7 4770 - H87M - 16GB G.Skill Ripjaws - HD7970 - 120GB 840 PRO - 500GB 850 EVO - 9TB HDDS - HX-650W - Fractal Define Mini - U2410 - K65 RGB - G502 RGB
HTPC: 6400K - 88X - 4GB 1600MHz - HVR-2200 - 120GB 840 EVO - 5TB HDDS - 550W TruePower - SG06 - 50" LED
Fujifilm X100 + X-E1 + X-T1 - 12mm F2.0 - 18-55mm F2.8-4 - 35mm F1.4 - 56mm F1.2 - 90mm F2.5
lionman is offline   Reply With Quote
Old 21st May 2015, 11:59 AM   #44
Nian
Good, let me be crazy. But I'm doing it just the same.
On a side note. I have a Samsung Galaxy Note III with a 5.7" Screen, I also have a factory fitted phone holder in the center console. So it sits right next to me in perfect view.
Old 21st May 2015, 7:12 PM   #45
miicah
ZFS FTW
Nah fuck that shit, EEC ram (tons of it) ridiculous limitations on drive sizes. I ended up umming and ahhing about it for at least a month before I stumbled on SnapRaid. With openmediavault/snapraid/aufs I have a weekly backup of my *cough* linux ISOs *cough* and a single share that all my PCs can see.
It can't restore file permissions though which is fucking annoying. At least everything is just sickbeard:users
