Old 1st June 2015, 4:12 PM   #46
pivot
Default The Little APU that could
I have just built a box for what could be called a "file server".
It consists of the following parts:
AMD Sempron 3850
Asus AM1M-A AM1 Socket HDMI SATA 6Gbs USB3.0 Micro ATX
4GB DDR3-1333 (2x2GB)
Skymaster PCI-Express to SATA III Card
1 x WD 1TB Blue, 1x 2TB Segate, 2 x 3TB WD Green
Using the greens in a simple storage space connected via the add-in SATA card (does SATA3 speeds), blue has Windows 8.1 and the Segate is used as an internal backup drive.
This setup runs Windows 8.1, grabit, utorrent and Plex - all at the same time. No slow downs, even when accessing it from Remote Desktop.
Great CPU for what I wanted it to do - cheap and cheerful.
pivot is offline   Reply With Quote
Join OCAU to remove this ad!
Old 15th February 2016, 5:06 PM   #47
Unframed
Unframed's Avatar
Just bought into this platform as a replacement NAS. I realised when my N2310's NIC died last night that the real pitfall to a NAS is that if I can't reach it via Network then I can't get my data. So I wanted something dirt cheap and low power, conveniently enough one of my distributors is clearing stock now they've been bought out and I picked up an AM1 setup and SATA/RAID controller for $60. Cheaper than any empty NAS and far more power than my 800mhz single core/512MB RAM Thecus POS.
Went with:
Sempron 2650
ASRock AM1H-ITX
Corsair 4GB DDR3
Astrotek AT-CPES6
Now for a fist full of 6TB drives
CoolerMaster CM Storm Stryker | Intel 4790 w/ H55 | Asus Maximus VII Hero | Gigabyte R9 Fury X | Samsung 840 120GB, Kingston Savage 480GB, Samsung 840 Evo 240GB, 2x 3TB Seagate | 32GB Kingston Fury 1866Mhz | SteelSeries Apex M500/SteelSeries Rival 700 | Enermax Revolution87+ 1000W | LG 34UM88C, Dell U2211H
Unframed is offline   Reply With Quote
Old 16th February 2016, 3:45 PM   #48
Nian
Went with:
Sempron 2650
ASRock AM1H-ITX
Corsair 4GB DDR3
Astrotek AT-CPES6
Any chance you could hook me up with two to four of the Asrock motherboards?
Asrock Fatal1ty 990FX Killer, AMD FX-8370 BE @ 4.5Ghz, G.Skill TridentX DDR3 @ 2133 Mhz 10-12-12-31 4x8Gb , 2x Gigabyte Windforce 3 R9 290X OC 4Gb GV-R929XOC-4GD, Cooler Master HAF XB EVO, Cooler Master V8
Old System: Gigabyte GA-965p-DS4 Rev. 1.0, Q9300ES @ 2.8Ghz, Team Xtreem Dark DDR2 740Mhz 4-4-4-12 4x2Gb, AFox HD7850 2Gb, Asus Xonar D2X, CoolerMaster CM690. Zalman CNPS9700 LED
Nian is offline   Reply With Quote
Old 16th February 2016, 3:49 PM   #49
Unframed
Unframed's Avatar
Sadly not, last in stock.
Old 16th February 2016, 5:04 PM   #50
General_Cartman
General_Cartman's Avatar
CPL claim to have those boards in stock
General_Cartman is offline   Reply With Quote
Old 18th February 2016, 10:27 AM   #51
ErrorCode62
As do mwave $45
http://www.mwave.com.au/product/asus...FYSVvAodcYYPMA
Online Only. Limit 1 Per Customer. Ends 29/02/2016 or While Stock Lasts
cpu list: https://www.asus.com/au/Motherboards.../HelpDesk_CPU/
ErrorCode62 is offline   Reply With Quote
Old 18th February 2016, 11:19 AM   #52
PsychoticOrc
PsychoticOrc's Avatar
I'm planning on running one of these as a file server in the near future to replace a 2500k setup I've had running for the last year or so.
I read somewhere that these support ECC memory which would be pretty awesome as I have 2 sticks sat doing nothing currently. All this would do is serve files and run a minecraft server for my children so at most maybe 3 users but more often than not just two.
I've read conflicting posts about the pci-e x16 slot (which runs at x4) not being fast enough for a raid card. I was planning on running something along the lines of a HighPoint RocketRAID 2680.
When I do get it up and running i'll let you guys know how it performs, but i'm not expecting to many issues. The pci-e bottleneck might occur when the initial transference of files from my old server to the new but once that's done its all media files so pretty static anyway.
PsychoticOrc is offline   Reply With Quote
Old 18th February 2016, 9:02 PM   #53
Nian
PCI-e V2.0 x4 is still 2GB/s. If you think that it will bottleneck conventional hard drive raids. WOW!
Old 18th February 2016, 9:54 PM   #54
Unframed
Unframed's Avatar
Beat me to it.
Old 19th February 2016, 3:10 PM   #55
PsychoticOrc
Mate I ain't no expert if that's the case then that's great so I take it a x1 raid card would bottleneck then? as that was the other option I was thinking of going with so that I could use.
Old 19th February 2016, 3:55 PM   #56
Unframed
Unframed's Avatar
Perhaps SSDs but a 1x should still outdo a mech 7200 SATA RAID
Old 21st February 2016, 1:37 AM   #57
lionman
lionman's Avatar
If its a file server then you likely bottleneck will be the nic. Internal transfers would likely be affected by only a single PCIe lane though.
My PC: i7 4770 - H87M - 16GB G.Skill Ripjaws - HD7970 - 120GB 840 PRO - 500GB 850 EVO - 9TB HDDS - HX-650W - Fractal Define Mini - U2410 - K65 RGB - G502 RGB
HTPC: 6400K - 88X - 4GB 1600MHz - HVR-2200 - 120GB 840 EVO - 5TB HDDS - 550W TruePower - SG06 - 50" LED
Fujifilm X100 + X-E1 + X-T1 - 12mm F2.0 - 18-55mm F2.8-4 - 35mm F1.4 - 56mm F1.2 - 90mm F2.5
lionman is offline   Reply With Quote
Old 12th June 2016, 11:06 PM   #58
General_Cartman
While this is not strictly AM1 as the Kabini in question is the BGA variant, I'm quite impressed with what my little server running on a 15w A4-5000 APU can do.
I'm using the QC5000-ITX/WiFi board, and replaced the wifi card with a mini PCI-E sata card for a total of 6 Sata ports.
It's currently running Linux, with 4 HDDs in Raid 5 and a SSD for the os. I'm using it to do DHCP and DNS, Samba for sharing files and printers, and a windows 2012 server running using KVM to run a few windows services and SQL Server which I need for the work I'm doing, as I run linux as my primary OS. It also has a TBS Quad TV tuner card in it and tvheadend to stream TV to my media centres.
Despite the CPU having a 15w TDP, it has more than enough grunt to run everything, and the windows VM runs surprisingly well.
Old 13th September 2016, 10:10 PM   #59
jji7skyline
Did you guys see JayzTwoCents' latest video with the sub-400USD gaming PC build? He paired a AM1 platform with a R9 380 and got playable framerates at 1080p in games like CS:GO and Doom on high settings. Impressive for such an affordable platform!
PowerMac G5 Casemod Hackintosh: i7-4790K / GA-Z97M-D3H / 16GB / GTX 970 G1
Successful trades: "Limit-R", "quwackers", "Sarsippius", "BarboneNet", "Kosti"
jji7skyline is online now   Reply With Quote
