Old 23rd July 2015, 10:48 PM   #61
Euphoreia
Euphoreia's Avatar
Originally Posted by mAJORD View Post
But yes, there's no denying Intel have the lead in gaming performance. but it is at a cost
Not when a stock $155 i3 is -stomping- an overclocked $200 FX8320 in gaming tests.
The -only- reason to buy an AMD chip is if you're doing lots of video encoding and you're on a super-tight budget.
Euphoreia is offline   Reply With Quote
Join OCAU to remove this ad!
Old 23rd July 2015, 10:59 PM   #62
C-BuZz
C-BuZz's Avatar
http://www.computerbase.de/2012-10/t...350-vishera/6/
http://www.computerbase.de/2012-10/t...350-vishera/7/
FX 8350 vs Phenom 965 is a pretty decent overall improvement .. more so than than the difference between an FX and an ivy i7 even. - Including unrealistic 640x480 CPU tests.
Vishera s even getting beat by the first gen i7 at stock. I wouldn't really call that a decent improvement.
Really disappointed in Amd. Massive fanboy but I go where the FPS is when it comes to gaming.
C-BuZz is offline   Reply With Quote
Old 23rd July 2015, 11:28 PM   #63
mAJORD
mAJORD's Avatar
Was thinking I should have ninja'd that to mention the i3's. Stomping no, but indeed in games that just don't make good enough use (Still) of cores they fall behind. This will change a lot with DX12, but by then one would hope FX is either history or close to it.
True. I mean the FX's we're talking about are nearly 3 yrs old now. It's quite irrelevent. They are priced pretty decently to compensate for that though. The 8370E in particular is not too bad at all.
FM2+ stuff is still relevent though in its price bracket.
Well you specifically said vs his PII 945 I was just responding to / disputing that. Unless you consider a 3770k to be "slightly better" than an FX 8350
secondly the first gen i7 in question wasn't that old at the time
means you're a Fan not a fanboy
I agree though, it is really disapointing, but what's more disappointing than the lack of competition up there, is even when AMD are putting out good products in the lower end and niche markets they still can't get them off the shelves or into devices.
This Carrizo launch for example. The product looks great for what it is, but it's looking more and more like it's going to end up hidden away in lackluster clamshell's, instead of at least making a bit of a name for itself.
Old 26th July 2015, 11:10 AM   #64
philscomputerlab
philscomputerlab's Avatar
What annoys me personally with AMD is that they kept pushing their strength with graphics, but in real life I found this to be a letdown.
I've got two machines that I've ran into issues.
One is a small notebook with AMD APU E-450. The processor is really slow, but the graphics part was talked up to accelerate anything to do with graphics. But the thing can't even handle YouTube videos
Got another system with AMD chipset 880G I believe. Onboard AMD Radeon. Now on Windows 8.1, no proper support anymore. Minimalistic driver with no options and videos are washed out.
So I just don't trust them anymore. My old Intel chipset based notebook, everything works.
philscomputerlab is offline   Reply With Quote
Old 26th July 2015, 8:13 PM   #65
dirtyd
dirtyd's Avatar
I have an MSI Wind with E-350 (same chip with lower clocks) and I don't have any problems with YouTube (up to 720p, laptop only has 1366x768 display), so your problem may lie elsewhere.
"It is worthy of remark that a belief constantly inculcated during the early years of life, whilst the brain is impressible, appears to acquire almost the nature of an instinct; and the very essence of an instinct is that it is followed independently of reason." - Charles Darwin | trustworthy traders
dirtyd is offline   Reply With Quote
Old 26th July 2015, 8:16 PM   #66
philscomputerlab
Well, where else would it lie? 720p is extremely choppy. Tried IE and Chrome.
I got another one with E-330, same exact thing.
Old 27th July 2015, 5:05 AM   #67
Nian
Memory speed?
Asrock Fatal1ty 990FX Killer, AMD FX-8370 BE @ 4.5Ghz, G.Skill TridentX DDR3 @ 2133 Mhz 10-12-12-31 4x8Gb , 2x Gigabyte Windforce 3 R9 290X OC 4Gb GV-R929XOC-4GD, Cooler Master HAF XB EVO, Cooler Master V8
Old System: Gigabyte GA-965p-DS4 Rev. 1.0, Q9300ES @ 2.8Ghz, Team Xtreem Dark DDR2 740Mhz 4-4-4-12 4x2Gb, AFox HD7850 2Gb, Asus Xonar D2X, CoolerMaster CM690. Zalman CNPS9700 LED
Nian is offline   Reply With Quote
Old 27th July 2015, 9:48 AM   #68
neRok
Perhaps its a flash player problem? You can force youtube to use html5 video player somewhere in the settings (or disable/uninstall flash player and it should be forced to use html5 player).
neRok is online now   Reply With Quote
Old 27th July 2015, 1:37 PM   #69
Freebee
Freebee's Avatar
That sums up my standpoint pretty well... Amd fan, but I go where the performance is... Choice between an amd a10-5800k or fx-6100 and an i7-950, the i7 will end up in my main machine any day
Really want amd to make an absolute intel killer In terms of price and performance, firstly so I can buy one and secondly to stop intel slacking off... Seriously intel could make a 16 core 5.5ghz chip and sell it for less than $500 if they had motivation to go to the level of power consumption of the 9590
spec's:
Parvum s2.0; build in PC-A71F on hold;
AMD FX-6100, Asus 880g-m(something), AMD HD 6950, 512gb Samsung 850 evo
(mb,cpu & gpu were free)
Freebee is offline   Reply With Quote
Old 30th August 2015, 5:11 PM   #70
port1
i7 was the nail in the coffin. Let's be honest here, an overclocked 1st gen i7 is still enough for 99% of users/gamers these days...
and this is the point. Whether you consider AMD or Intel, there has been no break though improvement for years. What we have now is the best
Port1
AMD FX 4130 quad core,Win8.1 64 bit
port1 is offline   Reply With Quote
Old 30th August 2015, 7:25 PM   #71
Reaper
Reaper's Avatar
There is no fight between amd and intel until they actually compile software for amd.
The real fight is amd vs NVidia as 4k is the hot topic.
Code:
     /  __  \	  |This space for rent|
_____|__||__|_____ ---||---------||---
Reaper is offline   Reply With Quote
Old 30th August 2015, 7:28 PM   #72
ipv6ready
AMD need to develop a decent CPU or gpu first
4k nut UP3214Q, UP2414Q and U28D590D
MSI Z77a-GD80, Cosmos II, i7-3770k, Swiftech H240-X, Gigabyte G1 GTX1070, G.Skill 32mb 1600, 256GB Samsung Pro 840, 120GB Sandisk Extreme, LSi 9261, 8 x 1TB WB Black HDD, Seasonic 660w Platinum, Cyberpower UPS
ipv6ready is offline   Reply With Quote
Old 16th September 2015, 1:12 PM   #73
sanjeevlives
sanjeevlives's Avatar
think DX 12 will help out amd massively - all that xbox dev might just pay off
http://www.extremetech.com/gaming/21...head-to-head/2
|| 4790K @ 4.7 | Corsair H100i | Asus Maximus VII Ranger | 16GB Gskill 2400 | EVGA 1070 SC | Sound Blaster Z | Sandisk 960gb | 8tb | Corsair AX860 | Phanteks Evolv Glass | Samsung S27A950D | Logitech Z623 ||
Tracking the IPA's impact on Australia
It's no longer "our" government. The government is now the sole proprietorship of global corporate interests. - ThankDog
sanjeevlives is online now   Reply With Quote
Old 19th September 2015, 12:58 PM   #74
Toliandar
4K is the hot topic for some anyway - others are more concerned about 120 fps @ 1440p.
Toliandar is offline   Reply With Quote
Old 22nd September 2015, 6:37 PM   #75
Outcast_Aussie
How will Direct X anything be of any benefit to Linux users ?
All DX does is lock you into a Microsoft O/s
Outcast_Aussie is offline   Reply With Quote
