Old 30th January 2016, 1:48 PM   #16
tumutbound Thread Starter
tumutbound's Avatar
Finally got around to doing something about this.
Went to MSY (in Gelnorchy)) and bought some Noctua NT-H! compound.($11)
Cleaned up the CPU and cooler surface with a little isopropyl alcohol - the old compound was crumbly and dry. Put a thin smear of NT-H1 on the CPU surface and refitted the cooler.
System fired up OK - which is good.
Has the same CPU temperature - which is bad.
Playing a Youtube video or running Sketchup under a VM sees the temperature start to climb to 70 - which is where I've set the audible alarm.
Fan seems to be pulling a good amount of air and the fins are clear of dust. Next step will be to get a new cooler.
I've checked all the voltages with the monitor software (Linux based) as well as with a multimeter, all seem within spec.
EDIT: I took a break for a couple of hours to play around with the XYZ-Carve and now the system seems to have settled down, temperature wise. Currently sitting on 47. When I fire up Sketchup or Youtube, it only goes up to about 54 after 10 minutes or so.
My weather
tumutbound is offline   Reply With Quote
Join OCAU to remove this ad!
Old 8th September 2016, 12:07 AM   #17
tumutbound's Avatar
Default Noctua NHL12
I know this is an old thread but as I've finally installed a new CPU cooler, I thought I'd post an update.
System has been working but any serious number crunching (2+2 type of stuff), the temperature started to rise quickly. I did get an over temperature alarm occasionally which I solved by not doing any real processing.
Monday I bought a Noctua NH-U14S which I carefully checked on the Noctua site to make sure it would not interfere with memory, add on cards etc with my motherboard (Gigabyte 870GPA). I should have paid more attention to the height as despite the super large case I have, it wouldn't fit without leaving a side off. Went back to MSY today and swapped it for a Noctua NH-L12, a dual fan. low profile model. Dead easy to install and quiet!
Current CPU temperature is around 31 whereas previously, it sat around 50.
My weather
Old 8th September 2016, 5:12 PM   #18
Mensuri
Now that's a nice improvement
GAMING MONSTER : A64 3200 @ 2.4, X800GTO at 400/760 and 1.5G ddr 400
Labrador Rescue
Mensuri is offline   Reply With Quote
Old 22nd September 2016, 6:13 PM   #19
tumutbound's Avatar
Just installed a couple of Noctua case fans, 120mm and 92mm.
Do they ever make a difference to the noise level! Not sure what effect they will have on cooling but it has to be better than the single, 8 year old, 120mm fan that was in there - not sure if it was still running.
Well worth the $55.
My weather
