Old 6th January 2017, 7:22 PM   #31
cbwolf
cbwolf's Avatar
So i picked up my gear this morning and have been putting it together and testing it all arvo.
Happy to say my 7700k is running at an easy 5Ghz at 1.31v stable at 63 degrees under Prime95 with a Noctua NHD15 and ambient temp of 25 degrees.
Haven't bothered trying to eek out 5.1 or 5.2Ghz - this is good enough and the voltage is low.
Pretty fantastic really - happy to run it at this 24x7
i7 7700k @ 5.2 | Asus ROG Z270E Strix | MSI GTX1080 Ti Seahawk @ 2076/12000 | 32GB Trident Z 3200Mhz DDR4 | 256GB + 1TB Samsung 960 m.2 SSD | Philips 43" 4k IPS Monitor
Over $6,000 in forum trades and counting!
cbwolf is offline   Reply With Quote
Join OCAU to remove this ad!
Old 6th January 2017, 7:28 PM   #32
headin2001 Thread Starter
headin2001's Avatar
Great result. Just make sure you check what speed your CPU is running at with Prime running incase the board is underclocking it for the load.
Wraith, it's a case of me having more CM Nano on hand than Kryonaut, and to replace the Nano is only $10 a tube. I will test between the two though, but I believe the Krynonaut to be slightly better. We will see.
Old 6th January 2017, 7:39 PM   #33
cbwolf
cbwolf's Avatar
Nevermind - Asus AI Suite was lying, CPU is stable at about 81c using HWMOnitor.
Might need to see if i can drop the voltage a bit.
Old 6th January 2017, 8:18 PM   #34
zeropluszero
zeropluszero's Avatar
Delid it, you'll drop 20 degrees.
TeamAU
Old 6th January 2017, 8:21 PM   #35
aussie-revhead
aussie-revhead's Avatar
Op dropped 11-12 with delid at 5ghz, still decent gain.
Bench 1- Asus Rampage 5 Extreme- 5960x - 32gb of Samsung B die DDR4- 2x TITAN Xp - Intel 600P m.2 512GB - Enermax Revo1250 - water cooled tech bench - QNIX 2560x1440 screen @ 100Hz - Aten 120Hz KVM
Netbox - Dell 990 SFF - 2500 - 16GB ram - gtx750Ti - 240GB SSD - 2TB green
Current vehicles- Black 2007 ZX14 - VE V8 Calais (wifes car) - VN SS (for sale)
aussie-revhead is offline   Reply With Quote
Old 6th January 2017, 8:30 PM   #36
wraith.50
Yes but that was using Kryonaut under the IHS.
With a liquid metal TIM, such as CLU, you will get a 20+ degrees temperature drop.
wraith.50 is offline   Reply With Quote
Old 6th January 2017, 8:40 PM   #37
aussie-revhead
Really that much better?
Old 6th January 2017, 8:58 PM   #38
headin2001's Avatar
It is Aussie. So much better. I have more results to add.
I have run this CPU at 5.2 and 1.4v at same temp as the current chart, maybe a bit better. Can't remember.
Update again tomorrow when I test more.
Quick images - Conducanaut Under - CM Nano over
First one - Gaming temps BF1 for 2 hours
http://i.imgur.com/VdFl7GB.png
And Geekbench
http://i.imgur.com/yXBIFeg.png
Old 6th January 2017, 9:15 PM   #39
aussie-revhead
Good stuff mate, what about firestrike physics score?
Old 6th January 2017, 9:35 PM   #40
cbwolf
cbwolf's Avatar
Jesus - not having a great time over here.
This Asus Strix z270E board is in shambles. Definately needs a bios update to stabilise things - which the Asus update utility tells me there is one, but i can't download it because Asus have nothing on their website
This board just seems to be constantly chucking voltage down this processors throat. In Windows 10, i launch Chrome or open a folder, and suddenly the voltage spikes to 1.3v+ and Asus QFan spins up all of my fans for 3 seconds.
My PC sounds like it's having an intermittent fit
Old 6th January 2017, 10:36 PM   #41
headin2001's Avatar
Was in the other thread, but here it is again just for you.
At 5.2ghz but with Kryonaut.
http://i.imgur.com/gwawTbl.png
Old 7th January 2017, 12:52 AM   #42
Dorz
Dorz's Avatar
picked up my i7-7700k, asus z270f strix, 16gb gskill ripjaws v, 500gb samsung 960 evo m2, corsair h100i cooler today. should be a fair improvement from the i3-2130 i was using previously for a few tasks, which it was not cutting the mustard on!
cbwolf, i know what you mean with the motherboards needing a bios update, almost seems premature? mine isnt doing what you are saying, however when in bios if i turn the computer off with the on/off button, i need to turn the psu off and on again before it will boot again. it spins the fans for half a second and then nothing. only way to fix is to pull the plug :/
and no drivers on their website shitted me off, with no cd drive on the computer, and no cd drive on my laptop i had to find my external, plug it in to the laptop's esata, and am now copying the drivers onto a usb! gah.
Excellent trades: Too many to remember!
Originally Posted by _the_duke_ View Post
Listen to some Justin Bieber. If it sounds crap, you're speakers have accurate sound.
Dorz is offline   Reply With Quote
Old 7th January 2017, 9:51 AM   #43
Supersize
Supersize's Avatar
This is exactly the same thine the x99 Strix was doing on lauch, throwing far too much voltage at everything (CPU Core, VCCSA, VCCIO etc).
They finally fix it 4 BIOS's in, too late for some though.
Supersize is offline   Reply With Quote
Old 7th January 2017, 5:39 PM   #44
headin2001's Avatar
Testing for minimum volts for Cinebench R15 to pass. 1.32v set in Bios, LLC1.
http://i.imgur.com/xuck4kU.png
Old 7th January 2017, 5:47 PM   #45
shane41
Man that is sweet. Pop tha lid on that fukka
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
