Old 18th March 2017, 10:58 AM   #571
headin2001 Thread Starter
headin2001's Avatar
Originally Posted by SneakyBastd View Post
I've found that 5hgz/1.3vcore/LLC5 is fine for passing 15 minute tests of Prime95/AIDA64/XTU.
But some games crashed within minutes. Clearly it's not stable. And then I tried RealBench. OMG, it finds a blue screen alright.
After some experimentation with upping the vcore to 1.34 in bios, I noticed in hwmonitor it never showed that being used. It showed 1.328v. It helped a bit but the blue screens continued...
I then tried LLC6, and instantly hwmonitor shows vcore at 1.344v. Realbench passed!
Gradually lowering vcore, I find 1.32 in bios still passes. 1.31 does not.
Note that in hwmonitor, the vcore shows as 1.312v whether I've set 1.31 or 1.32 in the bios. But only 1.32 in bios is stable. Weird?
The kicker is:
LLC5, 1.34 in bios = 1.328 in hwmonitor. FAILS tests.
LLC6, 1.32 in bios = 1.312 in hwmonitor. PASSES tests. (About 3-4 degrees warmer, cores max at 71-74C)
Question is: is this approach best? It seems LLC is more important than vcore?!? Should I have stayed at LLC5 and kept upping vcore in bios, hoping it would eventually draw what it needs?
Thanks for putting up with my nub overclocking attempts!
Quick response is every CPU will react different.
I'm testing an Apex board at the moment, so I'll give it a go myself too.
What I found on the Formula board, like previous generation boards, is LLC5 will give close to no vdroop, but LLC6 was giving a slight overvolt. CPUz (the current version) gives the closest to real voltage in software, I tested with a multimeter.
With my M8 series boards, I always opted for LLC5, as a bit of droop is better than a constant overvolt. I have no technical reason for it other than it's my preference to set a max and it be the max. So MIXF and MIXA I will likely do the same.
So it's up to you which way you go. You may need 0.02v-0.03v more on LLC5, but it is going to end up around the same voltage under load. If it helps temps a degree or 2, it's a bonus.
BTW, I also believe auto LLC on the Asus boards is setting 5. I'll check that too.
Join OCAU to remove this ad!
Old 18th March 2017, 11:47 AM   #572
nCrypt
nCrypt's Avatar
i gave up on KabyLake, pretty much due to not being able to sell my 5960x gear.
The strix matx seemed ok, but pretty much no difference to the $150 cheaper gigabyte z270m-d3h in overclocking.
(the fact my 5960x does 5Ghz @ 1.4V, and thats the volts i needed with my 7700K for 5ghz pass in XTU, made me go back to X99 (Again for the 4th time lol)
1.5960X@4.5Ghz 1.25V WC X99 ROG R5 E10 32GB TridentZ 3200C14 GTX1080 Ti SLI WC CaseLabs S8
2.7700K@5Ghz 1.30V WC Z270 ROG APEX 16GB TridentZ 3200C14 GTX1080 STRIX OC WC Phanteks Luxe Tempered
3.7600K@5Ghz 1.31V H115i Z270 ROG STRIX 16GB TridentZ 3200C14 HD630 Caselabs S8
nCrypt is offline   Reply With Quote
Old 18th March 2017, 12:31 PM   #573
glnn_23
After a bit more tweaking have managed to run Realbench @ 5.2Ghz for a couple of hours this morning with memory 4133 C16.
After this run am now using the Adaptive core voltage with the Win10 power balance and it's pretty cool to have clocks and volts drop back down to stock idle when not pushed
Pretty impressed with the Apex board. Particularly with memory.
glnn_23 - 7700k - L639F976 - 1.2v - Asus Max IX Apex - G.Skill TridentZ 4133C16 - 5200/4500 - 1.395v bios
glnn_23 is offline   Reply With Quote
Old 18th March 2017, 12:40 PM   #574
aquaius
pix
jesus that's impressive, is that 7700k in a custom loop and delidded?
aquaius is offline   Reply With Quote
Old 18th March 2017, 12:49 PM   #575
glnn_23
Yes delid with Thermal Grizzly Conductonaut liquid metal under the IHS and Phobya Nano Grease on top. Cooling is 2 x 360 rads, 2 x d5 and EK Supremacy Evo. I think ambient was around 14C.
Old 18th March 2017, 1:17 PM   #576
SneakyBastd
Thanks
I'll leave it as is and de-lid during the week. Then see what happens as I try 5.1.
Sales to: noremac12321 FireWire1394
MadHatter
SneakyBastd is offline   Reply With Quote
Old 18th March 2017, 1:29 PM   #577
aquaius
sick build man, hope you enjoy it.
Old 18th March 2017, 3:34 PM   #578
headin2001's Avatar
That ambient will help for sure. At 30deg you might not be as lucky lol
But well done. I just sold a similar CPU to that, waiting on the new one to come from OS.
Apex is an amazing board for sure.
Old 19th March 2017, 10:01 AM   #579
SneakyBastd
I'm more jealous of the 14C ambient than anything else lol!
MadHatter
Old 20th March 2017, 11:23 AM   #580
headin2001's Avatar
Anyone in here killed a CPU when delidding. I am chasing an IHS from a Skylake or Kaby.
Old 20th March 2017, 4:09 PM   #581
AstinGC90
AstinGC90's Avatar
Might be worth buying a Kaby G4560 for $75.00 and trying a direct die cool for a laugh with added bonus of the lid you need
Better yet a cheap K i3 haha
I7-7700K Delided 5.2/4.8 1.42v daily OC, EKWC 360mm rad x2 UV Blue, 16GB Corsair Vengeance 3.2Ghz, Aorus Z270X-G5, SamEVO500GB, 8TB, FractalDefineS, CorsairAX1200, Gigabyte GTX 1080ti EKWB 2050/12000. AsusPG279Q 165Hz, LogiG510S, LogiG502Proteus, LogiZ906, ATHM50X.
AstinGC90 is offline   Reply With Quote
Old 21st March 2017, 8:10 PM   #582
straiton
straiton's Avatar
Tom's has done a Conductonaut 7700k test
http://www.tomshardware.com/reviews/...test,4970.html
MSI Z87 G45, delid 4770K
DIY Watercool
straiton is offline   Reply With Quote
Old 22nd March 2017, 3:21 PM   #583
mr_mordred2095
Oh look, Kryonaut is average-at-best for air/water. The people who bought it wouldn't listen to me when I told them, though -_-
mr_mordred2095 is offline   Reply With Quote
Old 24th March 2017, 8:50 PM   #584
coolroy
Yes but its non conductive which some people require & it still performs much better than a raft of non conductive pastes!
I7 7700K @ 5.2Ghz @ 1.380v 32Gb 3600mhz Gskill rgb Asus Maximus IX formula, 2 GTX1080 ek x in sli water cooled D5 vario pump & 480mm +360mm+240mm radiators, qty 9 rad fans & qty 3 case fans.
Philips 40" 4K monitor. Corsair psu AX1200I in Corsair 900D case K95 RGB keyboard,Razer Chroma Mamba wireless mouse
coolroy is offline   Reply With Quote
Old 24th March 2017, 10:34 PM   #585
LukeD_NC
so here's some food for thought about overclocking:
LukeD_NC is offline   Reply With Quote
