Old 7th January 2017, 4:56 PM   #46
headin2001 Thread Starter
headin2001's Avatar
Originally Posted by shane41 View Post
Man that is sweet. Pop tha lid on that fukka
It is Shane!!! Got 100mhz and slightly better voltages from it, but it's still over 30deg ambient here. These improve nice with colder temps.
First one to add to the Owners List
headin2001 - 7700k - L637F698 - 1.2vid - Asrock Z170M OC Formula - Galax OC LAB 4000C19 - 5200/4500 - 1.4v Bios - Geekbench
headin2001 is online now   Reply With Quote
Join OCAU to remove this ad!
Old 7th January 2017, 5:12 PM   #47
shane41
Haha matey you are doomed. My Devils Canyon sits on this thing.
20deg diff in temps that's what to aim for......
edit.......ah I get it. Not using the metal paste? So about 10-12 deg for non delid vs delid
Your screenshot. Coollaboratory Liquid will bring that down to 70-72 deg summer. 50-52 winter " here anyway.
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
Old 7th January 2017, 5:24 PM   #48
headin2001's Avatar
That's Delid with TG Conductanaut under lid and CM Maker Nano under the block.
Old 7th January 2017, 5:26 PM   #49
shane41
Quite possible that 7700K could hit 5400mhz better cooled 1.45V autumn?
Old 7th January 2017, 5:27 PM   #50
headin2001's Avatar
Not this one. I've been trying 5.3 but running out of comfortable volts. One day will get some ice out
Old 7th January 2017, 7:03 PM   #51
headin2001's Avatar
Realbench 1hour passed 5100/4500 - 1.4vbios
headin2001 - 7700k - L637F698 - 1.2vid - Asrock Z170M OC Formula - Galax OC LAB 4000C19 - 5100/4500 - 1.4v Bios - Realbench
Old 7th January 2017, 9:56 PM   #52
cbwolf
cbwolf's Avatar
Ok, so i've cracked the shits and am going to delid my 7700k. Fucking Intel and their bullshit TIM - shouldn't have to do this again. I miss the Sandy Bridge days.
In terms of what TIM to use between core and IHS, i've read a few different things about paste not being good as it'll get squeezed out in a few weeks, and to only use liquid metal products.
So i'm trying to decide between Thermal Grizzly Kryonaut (a high performance paste), versus Thermal Grizzly Conductonaut (a liquid metal product).
Any advice guys?
i7 7700k | Asus ROG Z270E Strix | MSI GTX1080 Gaming X | 32GB Trident Z 3200Mhz DDR4 | 256GB + 1TB Samsung 960 m.2 SSD | Philips 43" 4k IPS Monitor
Over $5,500 in forum trades and counting!
cbwolf is offline   Reply With Quote
Old 7th January 2017, 10:59 PM   #53
wraith.50
Any advice guys?
Definitely use the Conductonaut under the IHS, to achieve the best temperatures and use the Kryonaut on top.
As you can see from the results so far, using a liquid metal TIM on the cpu die, gives approx a 20-30 degree temperature drop and it will not pump out, like a non conductive TIM does.
wraith.50 is offline   Reply With Quote
Old 8th January 2017, 11:34 AM   #54
cbwolf
cbwolf's Avatar
Finally there was a BIOS update put up on the Asus website.
I updated this morning and now i can actually run my ram with XMP enabled and it's using lower volts
My 7700k still sucks though. I got it Prime95 stable at 5Ghz using 1.312v but it maxes out in the high 90s which is ridiculous for such low voltage. Intel's TIM must be super super bad.
Checked and reseated my cooler twice - it's fine.
Going to have to delid this guy. Order my Thermal Grizzly and will be doing it tomorrow so i'll post back with results.
Old 8th January 2017, 5:28 PM   #55
AstinGC90
AstinGC90's Avatar
Hey crew. Should receive my 7700k this week and am looking to delid straight up. Is 1g of TG Conductonaut enough to go under the HS or go the 5g for four times the price to be safe? Same question for the Kryo above the HS as well?
Also wats the best delid tool? Just buy a 3D printed one of eBay? Or OCUK like this: https://www.overclockers.co.uk/der8a...hs-000-dr.html
I7-7700K Delided 5.2/4.8 1.42v 50c max daily OC, EKWC 360mm + 240mm rad UV Blue, 16GB Corsair Vengeance 3.2Ghz, Aorus Z270X-G5, SamEVO500GB, 8TB, FractalDefineS, CorsairAX1200, Gigabyte GTX 1080ti EKWB. AsusPG279Q 165Hz, LogiG510S, LogiG502Proteus, LogiZ906, ATHM50X.
AstinGC90 is offline   Reply With Quote
Old 8th January 2017, 8:06 PM   #56
headin2001's Avatar
Update : Conductanaut results added to graphs.
As you can see, when Overclocking, with it under the lid makes a big difference again, but not as much in the day to day gaming compared to Kryonaut.
AstinGC90 : Plenty of tools to chose from man. Think the RockitCool one is cheaper and still does a good job. Hopefully others that have used can fill us in.
1g of the Conductanaut should be plenty for under the IHS, a little bit goes a long way. I suggest if you don't change out CPUs or maintain paste often to seal the IHS back up, sometimes it will turn to powder/oxidize over a long period otherwise.
CBWolf : great chip still man. If you are on Air and running Prime at that, you have done well. This one will do 5ghz prime95 with 1.38v under custom loop and only after delid and Liquid Metal.
Old 8th January 2017, 8:09 PM   #57
aussie-revhead
aussie-revhead's Avatar
My 7700k still sucks though. I got it Prime95 stable at 5Ghz using 1.312v .
wow and your disappointed? Delid and be happy.
Bench 1- Asus Rampage 5 Extreme- 5960x - 32gb of Samsung B die DDR4- evga GTX 1080Ti FTW (soon ....) - Intel 600P m.2 512GB - Enermax Revo1250 - water cooled tech bench - QNIX 2560x1440 screen @ 100Hz - Aten 120Hz KVM
Netbox - Dell 990 SFF - 2500 - 16GB ram - gtx750Ti - 240GB SSD - 2TB green
Current vehicles- Black 2007 ZX14 - VE V8 Calais (wifes car) - VN SS (for sale)
aussie-revhead is online now   Reply With Quote
Old 8th January 2017, 8:39 PM   #58
cbwolf
cbwolf's Avatar
I'm stoked i can get 5Ghz at that voltage - just unhappy about the temperature.
It's just weird. I've used these coolers on other i7's well over 1.35v at far lower temps. Seems like an Intel fail to me.
Anyway, i'll be picking up my Conductonaut from PCCG tomorrow morning, already have my razor blades - excited (and hopeful) to see if there's an improvement from delidding.
Old 8th January 2017, 8:46 PM   #59
aussie-revhead
Whats the diff with all the different Grizzly's? Is the Conductonaut anything like CLU? TIt looks like CLU and the item description looks like copy and paste from the CLU website ...
Old 8th January 2017, 9:22 PM   #60
cbwolf
cbwolf's Avatar
Yeh, Conductonaut is the CLU equivalent. From all the reviews i've read it's basically the same thing and performs the same.
Have never used a liquid metal TIM before - should be an adventure
