Old 8th January 2017, 10:14 PM   #61
bennyg
I heard someone say Conductonaut is thinner than CLU. Take the time to work it onto the surfaces. I didn't put enough first time and it dried up within a month on one of the GPUs (temp spike to thermal throttle), I just added some more and worked it around, didn't bother with cleaning it off. Still under 70C on 100W+ load. I taped over the tiny resistors next to GPU cores on each MXM board in case of it running. With kapton tape (can withstand high temps)
I did it first on my old laptop and the heatsink contact is dodgy because the heatsink is visibly concave. Core 1 is 15C hotter than core 0 on an ivy bridge quad - they are adjacent on the die and being mobile there is no IHS. So a good heatsink fit is more important than with a paste which fills gaps better (same CPU and HS were +-2C of each other with AS5)
I will be delidding the 6700K soon and will take some pics of what naked GPU dies and copper heatsinks look like after 3 months of Conductonaut
P870DM-G 6700K delid+LM @4.5GHz -45mV - 32Gb DDR4-2666 - 4K QFHD 17" - 980M SLI
+ a bunch of Ivy Bridge laptops - mobile CPU socket + anti-proprietary standard-loving basketcase
Trades: >70, Value: I can't count that high
bennyg is offline   Reply With Quote
Join OCAU to remove this ad!
Old 8th January 2017, 11:15 PM   #62
AstinGC90
AstinGC90's Avatar
Originally Posted by headin2001 View Post
AstinGC90 : Plenty of tools to chose from man. Think the RockitCool one is cheaper and still does a good job. Hopefully others that have used can fill us in.
1g of the Conductanaut should be plenty for under the IHS, a little bit goes a long way. I suggest if you don't change out CPUs or maintain paste often to seal the IHS back up, sometimes it will turn to powder/oxidize over a long period otherwise.
Ordered Grizzly goodness, what do you suggest for sealing her back up, Just any high temp silcone? Once its back under the water pump it will be there for years.
I7-7700K Delided 5.2/4.8 1.42v 50c max daily OC, EKWC 360mm + 240mm rad UV Blue, 16GB Corsair Vengeance 3.2Ghz, Aorus Z270X-G5, SamEVO500GB, 8TB, FractalDefineS, CorsairAX1200, Gigabyte GTX 1080ti EKWB. AsusPG279Q 165Hz, LogiG510S, LogiG502Proteus, LogiZ906, ATHM50X.
AstinGC90 is offline   Reply With Quote
Old 9th January 2017, 1:44 AM   #63
Dutch Wink
Dutch Wink's Avatar
Bought a 77k and a prime 270 AR yesterday, plumbed it under a H80i for good measure.
Currently looking at 5022mhz (162x31) at 1.305v bios which is IST happy but have to clip AVX back 2x (~4700mhz) in order to avoid thermal throttle when doing prime95 runs (so as a result I haven't been game to try and get that stable any higher). Will let it ride for a few hours overnight to be sure. IST on its own is 75-80 degrees, p95 takes that up to 95+
I'm seeing anywhere from 5-10 degrees difference in temps for cores 0+2 compared to cores 1+3 - is that normal or do I need to reseat the heatsink? Wasn't really keen on a delid, but if it'll give me 20 extra degrees again to play with during a Perth summer then maybe I will...
Also is there a good guide for o/c and verifying stability? Last time I did this was against an i7-950, a few years (and a lot less knobs) ago now!
OCAU OFFICIAL CHAIR RAVER'S SOCIETY MEMBER #1
Auroythmix**: GIRLS = MATH EQUATIONS, SO IF I SOLVE FOR X I GET THE SEX!
TheTron: If I sit and enjoy these pancakes. He'll buy me the new Justin Beaver album
Dutch Wink is offline   Reply With Quote
Old 9th January 2017, 9:47 AM   #64
Sindarin Ultra
Sindarin Ultra's Avatar
Looks like you have a great chip! I haven't spent much time on it yet but off the bat 4.8GHz 1.38v was not stable for me with an NZXT X41 (~Corsair H90)
Kind of a wtf since stock (4.5) runs at 1.20v, will play later.
Is anyone else having problems with XMP profiles? Putting my RAM at 3200MHz fails to boot, big thread on Corsair forums about it for Skylake. I'm running it at 3000@1.38v for now (meant to run 3200@1.35v).
Sindarin Ultra is online now   Reply With Quote
Old 9th January 2017, 9:57 AM   #65
Hex
Hex's Avatar
My 7700k is pulling upwards of 1.35vcore at stock speeds, it's currently set to auto in the BIOS, so I think I'll try and manually set that lower to fight the temps a bit.
Weekend ambient temps weren't great for any real testing (Especially Saturday in Melbourne) but it was hitting 90+ with prime95 which is obviously not great. Was Only hitting 65ish in games, so I'm not super concerned, but lower would be nicer (Only using a Noctua nhu12s with 2 fans, so I'm not expecting anything super impressive, but the temps are way higher than my overclocked 6600k was doing at about the same vcore)
To know the light, you must see the dark.
Hex is offline   Reply With Quote
Old 9th January 2017, 10:20 AM   #66
Dutch Wink
Dutch Wink's Avatar
Yeah I did see this too actually, at the XMP timings and volts for my ram (16-18-38 1.35v iirc) it just wouldn't boot, but eventually I found it'll do 14-16-34 at 3100mhz so I stopped caring
Old 9th January 2017, 10:26 AM   #67
AstinGC90
AstinGC90's Avatar
Did a trial on an old i3-2120 I had laying around. Not so great haha. Few scratches where the blade went under the IHS. Will have to do a few more to be confident I think.
Old 9th January 2017, 10:41 AM   #68
shane41
Talk to Headin about the correct delid tool
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
Old 9th January 2017, 11:09 AM   #69
AstinGC90
AstinGC90's Avatar
Yeah he suggested some great ones but to far out of reach to get here this week. The vice method looks very easy so I will look into that next.
Old 9th January 2017, 11:23 AM   #70
shane41
Check the youtube video out where heatgun was used to soften the bond first.
Old 9th January 2017, 11:42 AM   #71
AstinGC90
AstinGC90's Avatar
Got uneasy and jumped on an 88, Need to learn some patience, Thanks Shane
Old 9th January 2017, 1:45 PM   #72
headin2001 Thread Starter
headin2001's Avatar
I just went to supercheap auto and bought a tube of Sikaflex Black windscreen sealant. Works a treat. Just don't get it anywhere you don't want it. You can clean up with isopropyl alcohol though. Just use a very thin bead of it and clear off the old stuff a bit beforehand for better contact.
headin2001 is online now   Reply With Quote
Old 9th January 2017, 2:37 PM   #73
aussie-revhead
aussie-revhead's Avatar
Why glue them back on at all? Easier to reapply if you need to ...
Guys, 7700K are $479 delivered until 15th Jan:
http://www.ebay.com.au/itm/Intel-Cor...8AAOSwyQtVyZJU
Its a little saving but its something
Bench 1- Asus Rampage 5 Extreme- 5960x - 32gb of Samsung B die DDR4- evga GTX 1080Ti FTW (soon ....) - Intel 600P m.2 512GB - Enermax Revo1250 - water cooled tech bench - QNIX 2560x1440 screen @ 100Hz - Aten 120Hz KVM
Netbox - Dell 990 SFF - 2500 - 16GB ram - gtx750Ti - 240GB SSD - 2TB green
Current vehicles- Black 2007 ZX14 - VE V8 Calais (wifes car) - VN SS (for sale)
aussie-revhead is online now   Reply With Quote
Old 9th January 2017, 2:42 PM   #74
perz
perz's Avatar
I ended up jumping on the Kabylake bandwagon cause of that sale. Got myself an i5 7600k.
I WAS going to try and wait for Ryzen but meh, I'm too impatient and selling both my pc and macbook at the same time probably wasn't the greatest idea.
Oh well, here's to a machine that'll hopefully last another 4 odd years.
perz is offline   Reply With Quote
Old 9th January 2017, 2:59 PM   #75
aussie-revhead
What ram are you playing with?
