Old 21st March 2017, 9:29 AM   #151
nCrypt
nCrypt's Avatar
Originally Posted by sammy_b0i View Post
Literally the post above his, is another of his that has a picture
So last night trying to get Prime95 SmallFFT stable. Got 3.8GHz @ 1.375 stable. Then needed sleep, so will fiddle more later on. Stoked that the ram is on 2667 though. Much better than 2133.
glad to hear its all working
Im still stuck @ 2133 Mhz. which is sad considering its 4x8gb 3200 c14, assume eventually once the platform matures i will be able to achieve these speeds.
rigs been off for a couple of days, just installed the new waterblock on the Ti last nite, run the loop, just gotta fill for leak test, then can OC!
1.5960X@4.5Ghz 1.25V WC X99 ROG R5 E10 32GB TridentZ 3200C14 GTX1080 Ti SLI WC CaseLabs S8
2.7700K@5Ghz 1.30V WC Z270 ROG APEX 16GB TridentZ 3200C14 GTX1080 STRIX OC WC Phanteks Luxe Tempered
3.7600K@5Ghz 1.31V H115i Z270 ROG STRIX 16GB TridentZ 3200C14 HD630 Caselabs S8
nCrypt is offline   Reply With Quote
Join OCAU to remove this ad!
Old 21st March 2017, 10:02 AM   #152
itchynads
Originally Posted by TaroT View Post
what bios are you using and what settings did you use for 2933 on the ram?
also which cooler do you have and do you have the am3 bracket for it....Baymax goes both ways am4 or am3
Using Stock BIOS 0702 and H115i
Desktop Intel Core i7-5820K @ 4.5/ MSI X99A Gaming 7/ 64GB (16GB x 4) Corsair Vengeance / Corsair H115i/ EVGA GeForce GTX 980 Ti 6GB SC GAMING ACX 2.0+
Benching Ryzen 7 1700 @ 3.9GHz 1.38 Vcore / Asus C6H (BIOS 0082) /Corsair Vengeance LPX 16GB (2x8GB) 3000C15 @ 2997C16 DDR4 Hynix)/Fractal Define C ATX Case/eVGA SuperNova G3 650W PSU
itchynads is offline   Reply With Quote
Old 21st March 2017, 10:08 AM   #153
TaroT
TaroT's Avatar
ditch that bios very quickly go the 902 1001 if you want 1t or 0038 for 2t
i had the 702 and it was horrendous ending up loosing the cpu after not to long, so far 902 is pretty rock solid.
if you have the am3 bracket for that 1151 you can mount it(it ahs both mounting holes for am4 and am3) BUT and again i will say it BUT be very careful removing the back plate as it is stuck on very well, but then looking at it does that screw into the original back plate if so that's a pain in the ass.
might have to get together all my spare am3 mounting plates
AMD R7 1800X@stock:corsair H110 cooler: ASUS X370 crosshair 6(Baymax)Corsair 3200 ddr4 @2133(for now)R9 Fury X 1100/500:
Old 21st March 2017, 10:52 AM   #154
toje
toje's Avatar
Well that’s my present to myself!
On its way are
ASRock Fatal1ty X370 Gaming K4 AM4 ATX Motherboard
AMD Ryzen 7 1700X 8-Core Socket AM4 3.4GHz CPU Processor
G.Skill Ripjaws V 32GB (4x 8GB) DDR4 3200MHz Memory
I ended up getting the 1700X as it’s a nice compromise with a 1080 for VR, as I also ordered a vive. First upgrade in 8 years! I’m still running an i7 920.
Systems Administrator, Rural Firefighter, and Terrible offroader
Ryzen 1700X (Stock), G.SKill 32GB RAM 3200Mhz (2400Mhz, 15-15-15-38), 8GB GTX 1080, ASROCK Fat1lity Gaming K4 X370, 500GB and 1TB Rust Drives, Logitech G15 Woop Woop, 15 year old BenQ 24" LCD, HTC Vive.
Holden Jackaroo, 3.2L V6, 2" Ironman Lift, 32" MTZ, Front AutoLokka, Rear ARB Air Locker, Commodore Injectors, 85L Tank, TJM Alloy Roo Bar. Go Anywhere just not quickly.
toje is offline   Reply With Quote
Old 21st March 2017, 11:15 AM   #155
TaroT
TaroT's Avatar
yeah i have an osvr sitting in a box i will get back out again soon
now playing a little i drop the vcore down to 1.36 but the temps and the voltages still go up when running 4g...not sure about that one.
really wish they would release a nice even bios....getting tempted to try 1001...but it ain't broke i get 1744 in cinebench regardless.
maybe just throw caution to the wind and try 4.1 again...
Old 21st March 2017, 11:45 AM   #156
itchynads
Thanks I tried 0902 but had all sorts of memory related issues. Moving onto 0038 now.
QUICK UPDATE: 0038 looks to be an improvement over 0902. The 2T settings seems to have done the trick for me. Running stability tests now.
Old 21st March 2017, 12:23 PM   #157
TaroT
TaroT's Avatar
thanks for Guinea pigging depending on your feedback i may try it.
i can't seem to get past 4G or 2666 on mine at the moment without upping the vcore and of course the heat a lot.
tried 4.075 and .1 offset that failed miserably and 3200 and manual timings and upping the voltage...yet again fail
Old 21st March 2017, 2:56 PM   #158
itchynads
Will be trying 1001 tonight as well. I like living on the edge
The only thing stopping me from pushing the system any further are the temps. I know the chip will boot into Windows at 4GHz but can't bench.
The poor wraith cooler has been pushed to its limits
Old 21st March 2017, 3:28 PM   #159
TaroT
TaroT's Avatar
well you could always try the cooler they supply with the 7700k...oh wait...
Old 21st March 2017, 7:41 PM   #160
sammy_b0i
sammy_b0i's Avatar
Mmkay. So my sweet spot at the moment is 3.8GHz @ 1.3125v P95 Small FFT stable.
Tried for a flat 1.3 and it wasn't happy.
Wanted 3.9 but still couldn't get it P95 Small FFT stable at ~1.4v.
At the moment I'm topping out at ~65-66deg at 100% load, whereas 1.4v adds at least another 10deg.
Edit: So I guess:
sammy_b0i - Ryzen 7 1700 - UA1705PGT - ??? - MSI X370 Gaming Pro Carbon - G.Skill TridentZ 3200 16-18-18-20 @ 2667 18-20-20-22 - 3800 - 1.31250v - AIR - Noctua U14S Push/Pull - Prime95 Small FFT 2.5Hrs
Ryzen R7 1700, MSI X370 Gaming Pro Carbon, Noctua U14S, 16GB G.Skill TridentZ 3200MHz, eVGA GTX980 Classified, 480GB OCZ Trion150, eVGA G2 750W, Fractal Define C, BL3200PT
Originally Posted by tommodmc View Post
OCAU is a breeding ground for hyper-moralistic 13 year olds who've never stepped out of the computer room in their entire life. Young liberals, young labor, people who will grow old and die before they ever think about pulling their head out.
sammy_b0i is offline   Reply With Quote
Old 22nd March 2017, 8:21 AM   #161
not4us
not4us's Avatar
that doesn't look to bad sammy_b0i.
My build is pretty similar to yours except for the RAM. Put it all together last night but haven't had a chance to boot it and start overclocking it.
I ended up getting the MSI Gaming Pro Carbon after ShoppingExpress eBay stuffed up my order for the Asus Crosshair VI Hero (the let me place the order and turns out they didn't have it in stock an no ETA, go figure).
So I bought the MSI which is not compatible with my H100i v2 cooler like the Asus was, and right now I've got the AIO in place with zip ties...
Bloody Corsair won't ship the AM4 bracket outside the USA, even called them to check. Hopefully Scorptec will have it in stock next week so I can fit it properly.
Can't wait to finish work today and get back home to start tinkering with the Ryzen!
SPAIN ROCKS!
(even if we don't have a translation for overclocking)
AMD Ryzen 7 1700, MSI X370 Gaming Pro Carbon, 16GB DDR4 Corsair Vengeance LPX 3200 , Gigabyte GTX 1070 WindForce OC, Samsung 960 EVO 500GB NVMe, Seagate 2TB Barracuda ST2000DM001, Corsair RM750X, Corsair H100i v2, NZXT S340 Elite, Corsair K70 LUX RGB, Corsair M65 PRO RGB, ViewSonic VX3209-2K, Windows 10 Pro x64
not4us is offline   Reply With Quote
Old 22nd March 2017, 8:38 AM   #162
TaroT
TaroT's Avatar
well after trying the 1001 bios not a huge fan no performance gained really and a little flaky for me i will hold out for a later revision.
and after panicking about the cooler not making good contact and removing and redoing now the rgb leds don't work oh well and back to 0902 and all good except the rgbs which as i researched seems to not only be me...no big loss.
Old 22nd March 2017, 2:54 PM   #163
itchynads
I was testing on BIOS 1001 all of last night to the wee hours of the morning and I found it worked best for me in terms of memory clocking.
DOCP Standard profile (3000 - 15,17,17,17,1.35v) worked best for my memory and managed to keep it at 2933MHz.
CPU at 3.8GHz (38x100).
Tested via Prime95 small FFT for 1h, Blend for 1h and RealBench (30m, 8GB).
I did notice some quirks where it would shutdown and restart during bootup twice. Not sure if its specific to the BIOS version.
Having said that still on air cooling and running the memory at that speed just added even more heat to the CPU
Was also using a new 3109 build of HWiNFO that was able to show that I hit a peak of 100W on the CPU.
http://www.hwinfo.com/beta/hw64_547_3109.zip
Still trying to figure out which temps to believe. I have a feeling Ryzen Master is under reporting compared to HWINFO.
Old 22nd March 2017, 3:41 PM   #164
TaroT
TaroT's Avatar
so you set standard docp profile then manually did the ram or was it the 3000 preset.
and yes that version looks a lot more accurate than the slightly earlier one i had.
i had the double boot as well when i was using it...seems it has to set it a few times to get it to load(i thought it was going to safemode me )
i might give it another go once this storm has gone.(what ram are you using ?)
Old 22nd March 2017, 3:55 PM   #165
itchynads
Apparently I may need to toggle the sensemi skew in the BIOS to get accurate temp readings. Will try that later tonight.
I set the DOCP profile preset then set the memory speed to 2933MHz in the drop down a little further down the list. In that order.
HWinfo confirmed the memory speed and timings (@ 1T).
Extra settings that I had set:
vSOC 1.05v
LLC Level 3
Using Corsair Vengeance LPX 16GB (2x8GB) CMK16GX4M2B3000C15. (Hynix modules)
I also have some Corsair 3200C16 Samsung B die modules (2x16GB) that I might try should I get bored
