Old 7th March 2017, 12:19 PM   #31
mAJORD Thread Starter
mAJORD's Avatar
Originally Posted by aussie-revhead View Post
mAJORD - what do you think about adding a benchmark score to the results for an extra level of comparison? Its good to compare efficiency too and it may help others with their ram and clock choices. Eg Cinebench or FS physics or what ever you like to use.
Sounds like a win idea. I reckon something that scales well with both clocks and Mem performance , which may end up being 3dm phys
Originally Posted by Sgt Bilko View Post
Username - Model - DateCode/Batch - Stock (P0*) VID - Motherboard - RAM - Frequency - Vcore - Cooling - Stabilty (hrs)
Sgt Bilko - Ryzen 7 1700x - UA1705SUT (China) - No Idea - Crosshair VI Hero - Corsair Vengeance LED 3200 c16 currently at 2666 16-16-16-38-1T - 3.9Ghz - 1.387v - EK Predator 360 - AIDA64 CPU, Cache, FPU, Memory stress test for 4 hours.
I'm thinking about an 1800x just for the guaranteed clocks so we'll see
First in! (added) Seems like a good voltage for 3.9. Have u measured core by any chance? Reporting on my msi is off.
Originally Posted by demiurge3141 View Post
Do you still get power saving features when you manually overclock? Will it down clock and/or undervolt when idle?
Yes, just to a lesser extent than normal operating mode, in that shadow p states and fine grained auto voltage and clock control are disabled, but your usual programmed p states should work fine , though I noticed on my setup lower pststes went lowering core voltage, only clocks. Not that it matters, power Consumption remains low regardless
On the Bench: Ryzen 7 1700 - MSI B350 Tomahawk/Asrock AB350 Pro 4 - 16GB Corsair Vengance DDR4-3200
Ryzen OC / Owners Thread
Join OCAU to remove this ad!
Old 7th March 2017, 3:03 PM   #32
Sgt Bilko
Sgt Bilko's Avatar
I've seen lower volts needed for 3.9 on nearly every other chip.
Temps are supposed to be accurate on the tctl sensor that HWiNFO64 picks up
Guy on OCNis compling a data list here: https://docs.google.com/spreadsheets...p8oyHDucYrVnC0
For some reason my data is listed under Rainmaker91 and I'm seeing higher temps than everyone else when I really shouldn't be, we need way more data!
AMD Community Manager
Sgt Bilko is offline   Reply With Quote
Old 7th March 2017, 3:27 PM   #33
TaroT
TaroT's Avatar
well my 1800x is a UA1707SUT and going by the limited data i see in that other chart maybe i get a good one this time and did your baymax come with the 5803 bios ?Sarg ?
also as i mentioned before is the mount good? we know there were issues with the stock back plate but maybe also the boards are weird might be worth doing a test to see if it is making full contact(this chips going by the thermal tests i saw(video) heat up pretty even, not that much of a hot spot in the middle like the intels and old fx's
AMD R7 1800X@stock:corsair H110 cooler: ASUS X370 crosshair 6(Baymax)Corsair 3200 ddr4 @2133(for now)R9 Fury X 1100/500:
Old 7th March 2017, 4:39 PM   #34
Sgt Bilko
Sgt Bilko's Avatar
I'm not using the stock backplate, using EKs own, I will be checking mounting though but I'm 98% sure my mount is good.
I have no idea what Bios mine came with (only just realised why you call it Baymax ) because i had alot of issues getting the board to boot (turned out the EK gasket was the issue) so I flashed it to the 5803 straightaway anyway.
Old 7th March 2017, 5:08 PM   #35
cbjaust
cbjaust's Avatar
and why is that? i've been wondering myself.
MAIN AMD FX-8350 @ 4.78GHz | Asus Crosshair V Formula-Z | 16GB G.Skill TridentX | Radeon R9 280X 3GB
HTPC AMD A8-7650K @ 3.8GHz | ASRock FM2A88X-ITX+ | 8GB G.Skill Ares | Radeon R7 Graphics on-board
SERVER AMD Phenom II X4 940 @ 3.4GHz | DFI DK 790FXB-M2RSH | 8GB G.Skill PI | Radeon HD5670 1GB
cbjaust is offline   Reply With Quote
Old 7th March 2017, 5:15 PM   #36
Dragonfly
Dragonfly's Avatar
Crosshair VI Hero as in Big Hero 6. I never thought of Baymax myself either lol
i5 3570K | Asus Maximus V Gene | 32GB GSkill Ripjaws | Asus Strix RX470 | Corsair AX850 PSU | Silverstone FT02 | Dell U2412M
DesignInfusion
Dragonfly is offline   Reply With Quote
Old 7th March 2017, 7:18 PM   #37
Rammoth
Rammoth's Avatar
So. Neat. If you run 1.45v for prolonged periods on a gigabyte gaming 5 with a evga 1000 p2 it will murder your nvme port within the cpu. neat. new cpu mended it. might have murdered another cpu trying it again... lalalala <3 amd.
Rammoth is offline   Reply With Quote
Old 7th March 2017, 9:15 PM   #38
toje
toje's Avatar
Ha, this is probably the first place where I have come where people are not shilling hard for Intel.
I am looking forward to this processor TBH, Its my planned chip.
Systems Administrator, Rural Firefighter, and Terrible offroader
Ryzen 1700X (Stock), G.SKill 32GB RAM 3200Mhz (2400Mhz, 15-15-15-38), 8GB GTX 1080, ASROCK Fat1lity Gaming K4 X370, 500GB and 1TB Rust Drives, Logitech G15 Woop Woop, 15 year old BenQ 24" LCD, HTC Vive.
Holden Jackaroo, 3.2L V6, 2" Ironman Lift, 32" MTZ, Front AutoLokka, Rear ARB Air Locker, Commodore Injectors, 85L Tank, TJM Alloy Roo Bar. Go Anywhere just not quickly.
toje is offline   Reply With Quote
Old 7th March 2017, 9:24 PM   #39
jajjj
so i will post my results with my 1700x, Gigabyte gaming ax 5 and g.skill 3200 ram as soon as i can get a cooler. Running the original heat sink from my 8120 and i can't stand the noise it is putting out. Going to get a coolermaster 240 liquid master.
Check out JNRSNRGaming on Youtube.
jajjj is offline   Reply With Quote
Old 7th March 2017, 9:27 PM   #40
mAJORD's Avatar
shit!
You didn't accidently up your SoC voltage ?
(I know on this msi board, I accidently did because they have ridiculous menu system where you move the mouse cursor over the wrong parameter while + - incremnting and it starts modifying that value instantly)
Old 7th March 2017, 9:32 PM   #41
mAJORD's Avatar
It's a shame they don't supply the Wraith Spire with the other SKU's, it's a brilliant cooler, just limited in it's ability obiviously, but for those who actually don't want to OC an 1800x it would suffice.
Old 8th March 2017, 12:02 AM   #42
mAJORD's Avatar
Thumbs up
Ryzen 7 1700 - UA1706PGT - 1.05v - MSI Tomahawk B350 - Corsair Vengance 3200@2933 - 3800Mhz - 1.36v - AIR (stock Wraith Spire HS) - 2hr Prime 64k
Some measured ATX12 power consumption numbers:
*note VRM % loss calculated using default clockspeed SVI package power values vs measured ATX12v power
3200Mhz (stk) 1.05v 74w
3800Mhz - 1.36v 120.9w
3900Mhz - 1.40v 136.8w
Wraith Spire vs Coolermast Hyper 212 Turbo
3.8Ghz/1.33v 30c Ambient:
Wraith Spire: 76.5c
Hyper 212 : 62.0c
Old 8th March 2017, 7:19 AM   #43
Madengineer
Madengineer's Avatar
What's the safest operating temp on this gen?
'Fakts still exist even if they're ignored.'
Madengineer is offline   Reply With Quote
Old 8th March 2017, 9:58 AM   #44
TaroT
TaroT's Avatar
firstly...we are going to need 30 inch portrait mode monitors to show all the prime results
secondly temps i,m not sure i do know 95 is the bye bye and thanks for the fish temp from what i have read.
thirdly they are not bad temps for an included cooler...but the 212 is such a dark horse for the money.
Old 8th March 2017, 11:18 AM   #45
Madengineer
I'm keen as to give one a shot, but man those prices are high!
I've got pretty much everything except the CPU and a compatible board to go with it...
But a board and CPU alone could run into $600 easily...
