Old 10th March 2017, 1:50 PM   #61
danyell
danyell's Avatar
@lowdog is there an offset type setting in the BIOS? Similar to Intel rigs where you set an offset to achieve a vcore bump but you don't permanently set the vcore, so you get all the power saving settings etc to drop speed and vcore at idle?
danyell is offline   Reply With Quote
Join OCAU to remove this ad!
Old 10th March 2017, 2:49 PM   #62
lowdog
lowdog's Avatar
no offset settings I'm my bios, use to have them on my MSI Z97 Xpower but not on the X370 Titanium...think I read that Asus C6R has them but not sure.
any way with this board with vcore left on auto and cpu speed manually set at boost speed of 3.7GHz i'm getting default vcore of 1.19v and all power saving features working.....core speed and vcore throttling down at idle but turbo speed across all cores at load with low vcore and 1 hour 28 mins prime stable so looks good to me.
lowdog is offline   Reply With Quote
Old 10th March 2017, 3:00 PM   #63
lowdog
lowdog's Avatar
Some thing going on here;
First run 1700 @ 3.9GHz and ram 2 x 8GB @ 2933MHz loose timings
Second run 1700 @ 3.7GHz and ram 2 x 16GB @ 2133MHz tighter timings
Old 10th March 2017, 3:17 PM   #64
WallySimmonds
Quite a jump when changing the timings..
AM4 MSI Tomahawk, Ryzen 1700, MSI 1080TI FE
WallySimmonds is offline   Reply With Quote
Old 10th March 2017, 3:33 PM   #65
m0n4g3
m0n4g3's Avatar
AMD has always been about tight timings, rather than sheer brute speed when talking about memory.
i7-5930k @ 4.0ghz with EK Supreme-HF | Asus X99 Sabertooth TUF | 2x 980TI SLI with EK CU Blocks | 16gb Corsair Vengeance DDR4-3000 | 256gb Samsung 840pro | Xigmatek Elysium | Danger Den Monsoon D5 Dual Res bay, Koolance PMP-450 Pump | 2x XSPC RX360 Rads with 3xScythe Slipstream 1900rpm each | 3/8" Danger Den Black UV tubing | Red Monsoon Compression fittings
m0n4g3 is offline   Reply With Quote
Old 10th March 2017, 3:36 PM   #66
Bertross
Bertross's Avatar
that is a huge score man. I havent seen it that high on the 1700. Tight!
EVGA GTX 1080TI FTW3 | RYZEN 1700+H100I | ASUS ROG BIG HERO 6+SAMSUNG 950 PRO M.2 | 32GB TRIDENT Z RGB 3000 | PHANTEKS ENTHOO EVOLV TEMPERED | DELL U3415W 34"
Bertross is online now   Reply With Quote
Old 10th March 2017, 4:21 PM   #67
TaroT
TaroT's Avatar
are we forgetting the elephant in the room
3.7 vs 3.9 and 3.7 scores massively....
even with the ram differences that makes absolutely no sense.
quick everyone underclock your cpus for more power take that intel
oh wait i only just noticed 2 16 gig sticks?
what black magic is this
AMD Threadripper 1950X@stock:corsair H115i cooler: Asrock Taichi X399Gskilll Flarex 3200 ddr4 @3200 cas14XFX Vega 64 8 gig
Old 10th March 2017, 4:24 PM   #68
lowdog
lowdog's Avatar
What is the elephant then
Old 10th March 2017, 4:28 PM   #69
TaroT
TaroT's Avatar
i have no idea been out in the sun too long and thought it sounded cool more the point the lower actual speed got a vastly higher score and no one mentioned it...that was it i think
Old 10th March 2017, 5:11 PM   #70
lowdog
lowdog's Avatar
Run is bugged for sure even though it gave that score on 2 runs a reboot soon sorted it out
Old 10th March 2017, 5:46 PM   #71
Dragonfly
Dragonfly's Avatar
Asus Prime B350-Plus kicking ass
http://valid.x86.fr/top-cpu/414d4420...6f636573736f72
Save those sheckles on the X370 lol
i5 3570K @4.5Ghz | Asus Maximus V Gene | 16GB GSkill Ripjaws | Asus Strix GTX1060 | Corsair RM650X PSU | Fractal Define C | Asus VG248QE & Dell U2412M
DesignInfusion
Dragonfly is offline   Reply With Quote
Old 10th March 2017, 5:48 PM   #72
mAJORD Thread Starter
mAJORD's Avatar
Lowdog: Are you using ryzen master or bios? You need to ensure HEPT is on, looks like you've been effected by the know timing bug. Did the machine sleep before that run?
On the Bench: Ryzen 7 1700 - ASUS Prime X370 Pro - 16GB Corsair Vengance DDR4-3200
Main:
Ryzen 7 1800x - Crosshair VI Hero - 16GB G.SKill DDR4-3333 - ASUS 1080Ti FE - Custom water - Be-Quiet Silent Base
Ryzen OC / Owners Thread
mAJORD is online now   Reply With Quote
Old 10th March 2017, 5:53 PM   #73
Sgt Bilko
Sgt Bilko's Avatar
Haha, my best is 1774cb at 4041Mhz with 2400 c15 mem but I have seen 1900cb on a well tuned system before
AMD Community Manager
Comments are my own unless stated otherwise.
Sgt Bilko is offline   Reply With Quote
Old 10th March 2017, 5:55 PM   #74
lowdog
lowdog's Avatar
Yep woke from sleep and had the sleep bug lolol yay for the extra performance
Old 10th March 2017, 6:49 PM   #75
phantompisser
phantompisser's Avatar
Thats awesome . Considering that board can be had for under $150 .
Shame it's only realtek Lan and 887 Audio .
Cat hater ? No .
Hater of cat owners that let tinkerbell roam around killing native animals , fighting on my roof at 3am , killing MY pets and pissing on my car ? You betcha .
phantompisser is offline   Reply With Quote
