Old 15th March 2017, 5:54 PM   #91
lowdog
lowdog's Avatar
Ummmm what DF mean
Also what res was the Resident Evil game run at?
Want to see more game results please.
lowdog is offline   Reply With Quote
Join OCAU to remove this ad!
Old 15th March 2017, 6:00 PM   #92
mAJORD Thread Starter
mAJORD's Avatar
Data fabric. Maybe it should read / instead of and
On the Bench: Ryzen 7 1700 - ASUS Prime X370 Pro - 16GB Corsair Vengance DDR4-3200
Main:
Ryzen 7 1800x - Crosshair VI Hero - 16GB G.SKill DDR4-3333 - ASUS 1080Ti FE - Custom water - Be-Quiet Silent Base
Ryzen OC / Owners Thread
Old 15th March 2017, 8:24 PM   #93
aussie-revhead
aussie-revhead's Avatar
mAJORD - re the score in your chart showing 20k fs physics, what cpu clock was that? Do we have fps data for BF1 comparing Ryzen with Intel products?
Bench 1- MSI x299 Gaming Pro Carbon - 7820x - 32gb of Trident Z RGB DDR4- 1x Galax GTX1080 Ti HOF - Samsung 960 Evo + Intel 600P m.2 512GB - Enermax Revo1250 - water cooled tech bench - QNIX 2560x1440 screen @ 100Hz - Aten 120Hz KVM
Netbox - Dell 990 SFF - 2500 - 16GB ram - gtx750Ti - 240GB SSD - 2TB green
Current vehicles- Black 2007 ZX14 - VE V8 Calais (wifes car) - VN SS (for sale)
aussie-revhead is offline   Reply With Quote
Old 15th March 2017, 9:03 PM   #94
mAJORD's Avatar
Sorry, forgot to add those details , 3.9Ghz for all tests
There are a few tests around for bf1, one of the few games where Ryzen does well, with SMT on to boot
Main:
Old 15th March 2017, 11:55 PM   #95
Kelvin
hmmmm..
Just putting a together a 1700 and Prime B350M-A in a silverstone SG11..
A few issues along the way.. most minor..
The Standoff layout on the Asus board is slightly non standard.. (no holes for the top of the board)
The Standoffs in the Silverstone SG11 are mostly fixed and cannot be removed....
Had to use a bit of masking tap other bits to insulate the board electrically from the stand offs.
The front header layout.. is poorly marked on the board (not typical of asus)... had to consult the manual on several occasions..
Can't figure out the CPU fan LED connector thing (will sort that out later)
Installing windows 7 on Ryzen.. is interesting...
http://www.anandtech.com/show/11182/...-windows-7-x64
had to dig out a PS2 keyboard and board.. (the first one I had.. had a faulty spacebar and faulty row of keys (5tgb).. installed via DVD ROM..
None of the USB2 ports worked until the drivers were installed..
(copied the drivers onto an SSD and plugged the SSD into the sata port)
Kelvin is online now   Reply With Quote
Old 16th March 2017, 2:39 AM   #96
cbjaust
cbjaust's Avatar
Originally Posted by mAJORD View Post
finally got around to collecting Some DF and RAM scaling data.
I plan to do a lot more game related testing than this. But i graphed the couple that showed the trend most obviously - that is, Memory/DF clocks trump timings
and particuarly interesting is the skydiver combined test. you can see what appears to be n very little memory bw bottleneck on the individual tests, but a clear scaling when you combine physics with graphics.
this trend is not seen on firestrike, possibly because it's more bound to both raw rendering and computational power on both cpu and gpu wheras the lighter skydiver test , memory subsystem becomes the bottleneck.
I'd love to to test this on 4+0 config, and also on a system with fixed L3 / ringbus clock (something thats not possible on ryzen - so bulldozer or intel system) while varying ram speed. and see if the combined test still see'
s an uplift.
I think you should chart the different latencies individually and use the correct scale for the frequency like this for example (using your data):
It shows that least in this benchmark that the lower latency gives a small but consistent increase in score.
MAIN AMD FX-8350 @ 4.78GHz | Asus Crosshair V Formula-Z | 16GB G.Skill TridentX | Radeon R9 280X 3GB
HTPC AMD A8-7650K @ 3.8GHz | ASRock FM2A88X-ITX+ | 8GB G.Skill Ares | Radeon R7 Graphics on-board
SERVER AMD Phenom II X4 940 @ 3.4GHz | DFI DK 790FXB-M2RSH | 8GB G.Skill PI | Radeon HD5670 1GB
cbjaust is offline   Reply With Quote
Old 16th March 2017, 12:53 PM   #97
2_stroke
somebody get a x1800 please
http://bfbc2.elxx.net/sig/clean1/pc/2stroke.png
Successful trades
Sold to: chopstick9558, jackdaw, davomaster, haksam, jomo, kingpeck
Bought from: h$v, epo299, tangcla, Gillyske, winterstide, jboles, nooobs,Sainter4Life, auron1
stop listing years ago just way to many trades lol
2_stroke is offline   Reply With Quote
Old 16th March 2017, 12:57 PM   #98
Bertross
Bertross's Avatar
OJR should be setup tonight with the 1800x.
EVGA GTX 1080TI FTW3 | RYZEN 1700+H100I | ASUS ROG BIG HERO 6+SAMSUNG 950 PRO M.2 | 32GB TRIDENT Z RGB 3000 | PHANTEKS ENTHOO EVOLV TEMPERED | DELL U3415W 34"
Bertross is offline   Reply With Quote
Old 16th March 2017, 1:02 PM   #99
mAJORD's Avatar
yes most certainly tighter timing does give an increase. Mmain reason I graphed in that fashion was was to illustrate a greater importance for memory clock under such workloads especially at lower clocks.. Ultimately you'd need to map minimum stable timings @ the different memory clocks for your own system, but for the most part, it seems chase memory clock first - at least up to 2666 - 2933 which should be achievable fairly easily, then by all means tighten timings as much as possible.
The other thing that needs testing is single vs Dual rank. The later will yield higher memory clocks, but does this offset any potential performance deficit vs Dual Rank, i'm not sure. It does have some effect on Bristol Ridge
Main:
Old 16th March 2017, 1:21 PM   #100
TaroT
TaroT's Avatar
i have a 1800x...what do you want to know
have not added it in yet still tinkering.
AMD R7 1800X@stock:corsair H110 cooler: ASUS X370 crosshair 6(Baymax)Corsair 3200 ddr4 @2133(for now)R9 Fury X 1100/500:
Old 16th March 2017, 2:44 PM   #101
lowdog
lowdog's Avatar
F6 to optimised defaults in bios and what volts does your cpu vcore read please while in bios
Old 16th March 2017, 3:16 PM   #102
TaroT
TaroT's Avatar
oh but but means i have to reboot again...ok brb
ok 1.460 vcore at default settings (loads up to 1.504 at times in bios)
hence why i manually newtered it
Old 16th March 2017, 3:42 PM   #103
lowdog
lowdog's Avatar
1.46 wow. Obviously different kettle of fish to my 1700. Mine boosts to 3.7GHz with default vcore 1.19v and I can set the speed in bios to 3700 or 3.7Ghz and leave vcore on auto and in windows when loaded it never goes over 1.19v.
Can do 3.9GHz with 1.325v and LLC - 4 and under load it's 1.320v max.
You should be able to get similar settings for 3.9GHz......the extra volts for 4GHz and the increased power draw just don't seem worth it for the extra 100MHz.
wonder what you max volts will bump to in windows under load if you set your cpu speed in bios to fixed 3700/3.7GHz....be interested to see if it's similar to mine of under 1.2V while running prime full load.
Old 16th March 2017, 3:57 PM   #104
TaroT
TaroT's Avatar
on stock at 3.8 it was pushing 1.5 auto seems to think the more volts the merrier but then the 1700 is a 65w part mine is a 95w so i expected some hulk like power
i could drop it down to 1.35 but i think it will fall over so i, m happy where i am at the moment till the bioses even out
Old 16th March 2017, 4:03 PM   #105
lowdog
lowdog's Avatar
Lol they both perform the same at a given overclock frequency eg: 4GHz but may require different volts to get there
