Old 29th August 2014, 4:34 PM   #8071
headin2001
headin2001's Avatar
So quick man.......
Which OS for which benchie is best? Talking all PCMark versions here.
Join OCAU to remove this ad!
Old 29th August 2014, 4:46 PM   #8072
zeropluszero
zeropluszero's Avatar
no idea.
what are the top 10 using?
i know no one benches other versions of pcmark, because they're buggy as fuck.
whereas pc05 is buggy as fuck, but you can work that in your favour.
TeamAU
Old 29th August 2014, 4:49 PM   #8073
headin2001
headin2001's Avatar
Originally Posted by zeropluszero View Post
no idea.
Yeah, learning that quick. What a total POS! Did 3 runs on the X79/4930K combo and not one of them showed a score online. Totally F@#ked!
Thought I'd give it a go on the new platform for some extra Boints. Trying to work on 2d benching now instead of 3d.
Old 29th August 2014, 5:08 PM   #8074
gazza30 Thread Starter
gazza30's Avatar
PC mark 05 needs win 7 + the strongest AMD card you have + at least 2 ssd's for intel rst raid 0
beware the xp startup cap as 2 ssd's easily go over. Use something to slow the array down. A simple copy past can do the trick once you tune in the file size.
If your not getting a score then it means one of the subtests is failing check which one, it may even hint at why.
gazza30 is offline   Reply With Quote
Old 29th August 2014, 5:10 PM   #8075
Acidsys
Acidsys's Avatar
So quick man.......
I've been using Win7 64bit sp1 for PCM2005
Acidsys is offline   Reply With Quote
Old 29th August 2014, 9:07 PM   #8076
JunkDogg
JunkDogg's Avatar
My 2600 Tridents turned up today.
Good to go for Pentium runs again and see how it improves anything.
JunkDogg is offline   Reply With Quote
Old 29th August 2014, 9:57 PM   #8077
Jimba86
Jimba86's Avatar
does anyone know where to buy a cheap fluke 52 2 thermometer? im looking for one when my pots arrive (if they do)
WTB:GTX Titan - any
DESKTOP:980X|NHD14|UD7|12GB Gskill|3x1TB WD BK|500GB evo|GTX480 SLI|Xonar DX|3xU2711|HAF X|RM850|Win7|G500|G510|HD 280
BENCH:4670K|TRUE|Z97 SOC force|36GB Raptor|HyperX 2K|580 SOC|Gigabench|AX1200
Guitars: LP '60 CS,Class5,DRW Dreambird CS
Jimba86 is offline   Reply With Quote
Old 29th August 2014, 10:40 PM   #8078
eva2000
DDR1/DDR2/DDR3 Addict
eva2000's Avatar
Originally Posted by Massman View Post
Hey guys,
Matt asked me to post here to explain HWBOT's point of view on the merger situation.
To make a long story short, I would advise the members who want to see i4memory and OCAU merge in to Australia OC to manually move to the i4memory team. Then we can rename i4memory too.
The reason why we can't just merge the two teams and move both active and dormant accounts to the new Australia OC team is because the Team Captain of OCAU has not yet responded positively to the merger. I understand that the large majority of the currently active OCAU members are pro-merge, but that does not automatically mean all accounts can be moved along. The inactive accounts are part of the OCAU team and only the elected Team Captain can decided the faith of those accounts.
I hope you understand our position in all this. We highly value the role of Team Captain and we should not make team decisions for them.
If Snappy1 is okay with the merger as well we can still move the dormant accounts later on.
Cheers all!
fine with me
For now I edited the hwbot team url to point to http://australiaoc.i4memory.com/ it redirects to this thread's post regarding the changes
eva2000 is offline   Reply With Quote
Old 30th August 2014, 5:02 AM   #8079
sskmercer
sskmercer's Avatar
Just get a cheap one to start with, which is what I did (DSE type) and does a fine job. Yeah doesn't have micro adjustments above/below -100 but I'm on dice and not needing bleeding edge either.
sskmercer is offline   Reply With Quote
Old 30th August 2014, 6:20 AM   #8080
gazza30's Avatar
Save your money for now Jimba these do the job fine If your using LN2 just dunk the probes in to make sure they are spot on some of the cheap probes don't read 100% at full pot is all. Even if you buy a good probe for 10-20 bucks still much cheaper than the fluke.
Don't get me wrong if you can afford it Fluke all the way all my work gear is Fluke top stuff
Originally Posted by eva2000 View Post
fine with me
Thanks Eva
The new 5960x got you keen to bench? I remember you said your mainly into server gear these days but 16threads and ddr4 might just qualify
Old 30th August 2014, 7:47 AM   #8081
sskmercer
sskmercer's Avatar
Agreed, I would love a fluke based on what everyone has said and uses across different forums but for $350+/- and not needing the .1 past -100c that money can help buy a 5960X, GOD DAM I wanna gran one of these but still have the 4930k to play with.
Then which board is going to be the best bet. The Asus RIVE (then a BE comes out argh or the Giga OC board, but from reading people are wary as it seems there was some issue with X79/Gigabyte. I wasn't around then so have no idea.
But 8 cores @54x on DICE would do me nicely
Old 30th August 2014, 9:32 AM   #8082
Jimba86
Jimba86's Avatar
That is why I am looking at a 2nd hand fluke for around $100-150 or so.
Even though I don't need it I would spend 100 bucks and get the best 2nd hand vs 60 bucks and get something that just does the job. I would never spend $600 on a new fluke,it's just crazy! I don't work in that area so I don't need such good equipment.
I will check out your suggestions though!
WTB:GTX Titan - any
Old 30th August 2014, 4:51 PM   #8083
AUST_DeVinE
AUST_DeVinE's Avatar
so im in the new team, where is the beer and strippers promised
Dimastech easy dual hard bench | 3960X @ 5 | ASUS Rampage IV Extreme | G.Skill Ripjaws Z (4x4GB) DDR3 2400MHz | 4 x Gigabyte Titan OC's | Water cooled 1 loop. Lepa 1600W
MY Bot page Join OCAU HWbot team now funken OCAU Bot Thread
AUST_DeVinE is offline   Reply With Quote
Old 30th August 2014, 5:33 PM   #8084
FatBoyNotSoSlim
FatBoyNotSoSlim's Avatar
Said party was last night, it's too late now.
I DONT WANT YO LIFE, MONT BLANC
ALWAYS B TROLL'N
FatBoyNotSoSlim is offline   Reply With Quote
Old 30th August 2014, 10:49 PM   #8085
bob(nz)
bob(nz)'s Avatar
I would suggest that you zero chance. Maybe 250 if you are lucky. For $100 you are dreaming
Damn, if only you got the memo - we had a great time!!
Trusted Traders: Over 500 Successful trades on OCAU - PM me for details
Proud member of http://teamau.net
bob(nz) is offline   Reply With Quote
Tags
extreme, hwbot, subzero
