Old 4th September 2014, 8:49 PM   #8191
Bullants
Bullants's Avatar
Originally Posted by headin2001 View Post
What he said +1
What they said +2
Will get on the X99 ban wagon too later,will be pretty cool freezing quad memory's
Bullants is offline   Reply With Quote
Old 4th September 2014, 9:44 PM   #8192
Paulie_AU
Paulie_AU's Avatar
Originally Posted by Jack Harry View Post
Sorry mate, I meant 4770k.
Got a couple of questions :-)
1- What cooler and motherboard are you using?
2- Some people say the mobo plays a part in how well the CPU overclocks, most people say it's just extra features with more expensive ones...
I'm confused
My ASRock Z87 Extreme 4 is possibly more stable than the Gigabyte Z87X-OC (that or my CPU just isn't what it was). The gigabyte does however work better with really pushing memory due to allowing vDIMM above 1.8v
Mr_McPoo
Paulie_AU is offline   Reply With Quote
Old 4th September 2014, 10:33 PM   #8193
JunkDogg
JunkDogg's Avatar
Well I tried and tried and tried and hell even tried some more.
The 4770k didn't have anymore to give. I've tried every different configuration of uncore etc and nothing.
Is what it is. Oh well, no Rookie Rumble #9 for me.
Got a prime run up my sleeve still to take back #1 in that stage.
Going to try and get the 3528 XTU run up a bit over the weekend. ALso got to get some subs in for the AMD rookie rumble. I'll be more than happy if I can make it 3 in a row.
Will get a 4790k after I get back from holidays and have a functioning race car again. Mighgt buy a couple and see if I can get a good one for benching and one to put in my gaming rig when I finally get around to putting it back together.
@Jack Harry.
Mate, I'm running a Gigabyte Z97-SOC board and have 360 rad attached to my test bench.
It really depends on how much you want to spend and what it's for. If you are looking for a 24/7 OC. I personally wouldn't use one of these boards I'd go for one of the actually gaming board as it would have more than enough features for a good 24/7 OC.
If you are looking at what we are doing and just benching chips then it's your choice of manufacturer really. Everyone here uses different boards and it doesn't seem like there is a lot between them if everyone has decent chips.
JunkDogg is offline   Reply With Quote
Old 4th September 2014, 10:57 PM   #8194
Jack Harry
Originally Posted by JunkDogg View Post
@Jack Harry.
Sorry probably should have given more info when posting first comment on this forum
I'm upgrading my i5 to an i7 because of hyper threading and obviously higher clock speeds
The machine will be a 24/7 OC for video editing purposes and the occasional gaming.
So I'm trying to find optimal settings of clock speeds while maintaining an efficient machine (power)
I've bought the 4770K for $300 and I have the option to return it if I want a swap for let's say a 4790K for another $90.
Dilemma I'm facing is, do I have a good chip and try to set it up and find out. OR bite the bullet and get the 4790K Batch L4 for the extra $...
I'm sure you guys can give some good advice
Jack Harry is offline   Reply With Quote
Old 5th September 2014, 7:54 AM   #8195
zeropluszero
zeropluszero's Avatar
4790K brings nothing to the table
TeamAU
Originally Posted by shane41
Another freezer's words of wisdom
Old 5th September 2014, 8:19 AM   #8196
headin2001
headin2001's Avatar
Except the possibility of better temps and clocks if the 4770k is a dud (Delid seemed to fix a lot of them thought).
My last 4790k would only go 4700@1.31v for 24/7. Benching wouldn't go much higher even though the temps were still good. Limited to 5 no matter the volts for 2c/2t.
Clock for clock, same chip. Standard, different animals.
There's only one way to find out if you have a good chip, and that's to try it. Batch is one thing, actual end product is another depending on where in the batch it's from.
Old 5th September 2014, 8:27 AM   #8197
JunkDogg
JunkDogg's Avatar
Maybe I'll just get a couple more 4770k's and delid them and hope for a decent one.
Old 5th September 2014, 8:33 AM   #8198
headin2001
headin2001's Avatar
I wouldn't go that far. I think you'd probably have more luck with finding a better 4790k due to the better power delivery. Each to their own and price contributes.
Second hand 4770k's will be easier to get a hold of.
Old 5th September 2014, 8:47 AM   #8199
JunkDogg
JunkDogg's Avatar
Yeah just been looking now. Brand new 4770k's are a lot more expensive to get a hold of than 90k's. Will look around when I have the funds to bin a few and find a beauty.
Old 5th September 2014, 9:06 AM   #8200
jjjc_93
jjjc_93's Avatar
Yeah for an air/water cooler 4790k is the way to go. Temperatures are much better and in general clocks are too. The issue with them is that many don't scale with high voltages under LN2, but that won't worry somebody benching on water.
Team.AU
jjjc_93 is offline   Reply With Quote
Old 5th September 2014, 9:12 AM   #8201
JunkDogg
JunkDogg's Avatar
Cheers mate.
It appears one of my workers has come in and seen me this morning and has sorted a constant supply of DICE. Best of all it will be free!
So I'm off to try and find some pots.
Old 5th September 2014, 9:57 AM   #8202
zeropluszero
whereabouts are you located?
oh lol.
I was going to suggest you visit JJJC in Perth loooool
TeamAU
Old 5th September 2014, 10:01 AM   #8203
newlife
newlife's Avatar
I have a spare pot that only needs a base like a ek base that I'll sell you for a token fee
Old 5th September 2014, 10:04 AM   #8204
JunkDogg
JunkDogg's Avatar
oh lol.
At least if I started driving now he would have 12 hours to run and hide.
What pot is it Newlife?
Hopefully one time I'm in Perth somone will be doing some Ln2 stuff and they don't mind me watching and learning. But, that won't be for a while.
Old 5th September 2014, 10:18 AM   #8205
newlife
newlife's Avatar
It a kayl pot, it's perfect for Dice
Tags
extreme, hwbot, subzero
