Go Back   Overclockers Australia Forums > Specific Hardware Topics > Extreme and Water Cooling
Old 9th June 2012, 12:04 PM   #166
roamin
roamin's Avatar
Originally Posted by Illisis View Post
Not possible. there is only 3x5.25 bays available after putting a 360 in the front.
If you've seen what I have built and use at the moment you'd know anything is possible if you use your mind and tools to make things fit neatly and still look good.
roamin is online now   Reply With Quote
Join OCAU to remove this ad!
Old 9th June 2012, 12:23 PM   #167
Moptimus
Moptimus's Avatar
There are a couple of builds on here with this case. It is a versatile beast.
http://forums.overclockers.com.au/sh...hlight=elysium
I am looking at my 12 month old tj-07 with a sad face, If it didn't cost me so much $$ and time, I'd let it go and grab one of these.
Trades: koitech; bricktop; Mr DOHC; Bertross; Nerdbox87; Vantec; Rory K; i0Nic, Creepin, trash, Unr3strictable, EpicPCcases, omaraa, madaimer, pakka, mkusanagi, mrflay, illuminati, OnGsTa, doodz, interlopr.
Moptimus is offline   Reply With Quote
Old 17th June 2012, 9:03 PM   #168
Illisis Thread Starter
Illisis's Avatar
Finally got around to cable management.. you guys didn't see the other side of the case but it needed attention badly.
The only things left to do are:
- Make PSU shroud from aluminium - I have the measurements now
- Sleeve 200mm fan cable
- take outside pics because that's what everyone does 0.o
I would also like to announce that I am the third AU/NZ player to get the 5 star gold Jet service star as of yesterday! - BATTLEFIELD 3
And now for more rig shots:
Illisis is offline   Reply With Quote
Old 17th June 2012, 9:31 PM   #169
Creekin
Creekin's Avatar
i did....
hooray for not having a gf! congrats mate
Creekin is offline   Reply With Quote
Old 17th June 2012, 10:18 PM   #170
Illisis's Avatar
Originally Posted by Creekin View Post
i did....
That's my next project..!
Old 17th June 2012, 10:22 PM   #171
roamin
roamin's Avatar
looks good mate, well done. gotta be happy with the end product for sure.
Old 11th April 2013, 10:10 PM   #172
Illisis's Avatar
Thought I may as well update this to show you whats happening.
I think I will let the picture say the rest, But the loop has infested itself from the plasticizing crap from the tubing.
I am doing a full rebuild to clear as much as I can and replacing the tubing with the Advanced primoflex tubing instead of the predecessor PRO tubing.
Unless anyone has a better suggestion on the tubing(needs to be white).
Ps this is nasty shit.
(FB Link)
Old 12th April 2013, 2:04 PM   #173
Illisis's Avatar
New tubing ordered.
I don't even:
Old 12th April 2013, 3:12 PM   #174
Jakusonfire
Jakusonfire's Avatar
Wow! That is the worst i have ever seen it. How long did it take to get that bad?
I have been using the black version of the same tubing and when I have broken my loop down I always have small amounts of the same substance in the micro channels of my CPU block. I'll change to the new stuff soon I think.
Edit: If ever there was a case that deserved to be given the new version of the tubing for free, this is it.
Corsair 750D | Asus Sabertooth Z77 | 3570K | EVGA 780 | Samsung 840 Pro 256GB X 2 | EK Supremacy Acetal + Nickel | EK FC-Titan Acetal + Nickel | EK D5 X-Res w AC D5 USB | Aquaero 5 Pro | EK Coolstream PE 360 & 240 | 16GB Corsair Vengeance | Corsair SP120 & NB Eloop | Silverstone Strider+ 850W | Samsung S27A750 & LG E2290V | BF4:Jakusonfire
Jakusonfire is offline   Reply With Quote
Old 13th April 2013, 4:24 PM   #175
Illisis's Avatar
Sounds like I have made the ocau record for the grossest loop ever.
I sent I support ticket to primochill just to see what they have to say about these pics
I ripped apart the cpu block:
Old 13th April 2013, 5:18 PM   #176
sammy_b0i
sammy_b0i's Avatar
Xeon X5650, G1.Guerrilla, Hyper212 Evo w/ UF-140's, 12GB Mushkin Blackline Ridgeback, MSI GTX750Ti Gaming, Plextor M5 Pro Xtreme 256GB, FSP Aurum Gold 500W, Silverstone PS10.
Originally Posted by tommodmc View Post
OCAU is a breeding ground for hyper-moralistic 13 year olds who've never stepped out of the computer room in their entire life. Young liberals, young labor, people who will grow old and die before they ever think about pulling their head out.
sammy_b0i is online now   Reply With Quote
Old 16th April 2013, 4:54 PM   #177
auApex
auApex's Avatar
WOW. I'd be DEMANDING new tubing. That's all I have to say.
3930K @ 4.4ghz ||Asrock Extreme9||780 Ti SLI||16GB Dominator Platinum 2133||720gb SSD + 6TB||Strider 1200w||Modded TJ07||Catleap Q270 2b OC, U3011, 2*2007FP||G19, Ouroboros & Orbweaver||ATH-A900X on Essence STX||Custom Watercooling|| My PC
auApex is online now   Reply With Quote
Old 17th April 2013, 8:24 PM   #178
Illisis's Avatar
Updated primochill case.
Finished retubing with ADVANCED.
It is not as flexible but nothing hot water cant fix.
Leak testing..
p.s my fingers are on fire.
Old 19th April 2013, 9:23 PM   #179
Illisis's Avatar
PCCG & Primochill have agreed to replace my tube.
My processor is running much cooler after I some how overlooked the IN Port and had them switched all this time /derp
Remarks on this rebuild:
loop is performing well again
cards idle at 33 degrees
minimal white shit still floats around but you cant do much about it
I used exactly 2L of demin
I also found that if you set the powertune feature in AMD CCC at +20% I gained about 20FPS more in furmark.
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd. -
OCAU is hosted by Internode!
