Go Back   Overclockers Australia Forums > General Topics > Newbie Lounge
Old 17th May 2017, 9:15 AM   #1
Blackrayne Thread Starter
Default FPS Issues - PUBG
So i recently upgraded my pc
specs
Gigabyte z270A - Gaming 5
Intel 7700k
Gigabyte GTX 1070 G1 Gaming
G.skill TridentZ - 16GB 3000hz
Samsung 960 Evo
CPU Cooler - h80i
Monitor :
Acer Predator XB241H
Issues creating decent frames when running any Hertz, 60-85
I want to use the screen to it's most benefit, but from what i gather this game is very CPU dependent, i was thinking about OC'ing my CPU a little higher to possibly a stable 4.7, i have OC'd before with my AMD-6100 however it seemed a little more forgiving :P i got it up to 4.5GHZ stable (i know)
If anyone could suggest some good ideas or even possibly help me with a basic clock that isn't going to impact negatively as far as FPS goes.
Blackrayne is offline   Reply With Quote
Join OCAU to remove this ad!
Old 17th May 2017, 11:12 AM   #2
tree86ers
tree86ers's Avatar
i would not bother trying to "optimize" for this game right now since it is beta and things can change.
I get the same sort of FPS with 2 x 1080's on a 6800K. until they finish the build and start optimizing the game after release there is not much point.
Main PC "Tensa Zangetsu" - MB "eVGA X99 Classified" - CPU "i7 6800k" - RAM "corsair dominator platinum 32gb" - GPU "evga GTX 1080 FTW x 2" Trans-code PC "Hyōrinmaru" - MB "ASUS P9X79" - CPU "Xeon E5 2670" - RAM "corsair LP 32gb" - GPU "eVGA GTX 960 2GB" LAN PC "Zangetsu" - MB "EVGA Z77 Stinger" - CPU "i7 3770k" - RAM "corsair LP 16gb" - GPU "eVGA GTX 980 4GB"
tree86ers is offline   Reply With Quote
Old 17th May 2017, 2:50 PM   #3
RacinBacon
New Member
PUBG is very poorly optimized for even the best of computers. There is no need to do anything to your set up, as it goes above and beyond the requirements for PUBG. If you are experiencing lag, it is most likely one of the servers (I play it on my current machine, and I know there is one server that makes me and my friends lag out). Have you gone through the PUBG faq's on FPS issues?
i5 2500k, Gigabyte 570 Graphics card, H161M-USB3-B3 Motherboard,16gb 1600mhz DDR3 G.Skillz, 650w PSU, Asus Xonar DX sound card, 3TB HDD, Corsair K70 Keyboard, Corsair M95 Mouse
RacinBacon is offline   Reply With Quote
Old 17th May 2017, 11:26 PM   #4
Reins
Are you running a lot of background applications simultaneously? PUBG does use a lot of RAM (mine uses 12GB+) so that MAY be a cause of issue for you.
Reins is offline   Reply With Quote
Old 18th May 2017, 3:11 PM   #5
Beaistheman
As above, game is terribly optimized. I just set everything to low except draw distance at ultra, keep native resolution and I found that anti-aliasing has little effect for my computer on frames so I put that up.
The deaf man heard what the mute man said and they all followed where the blind man led.
Beaistheman is offline   Reply With Quote
Old 19th May 2017, 6:00 PM   #6
hairy
my rig runs 50-60 fps don't think it uses sli at all, one card idle.
my net sucks donkey balls though 200k down.
turning down details and aa does nothing so I run at max.
antec skeleton, msi gaming m5, 6700k, 32 gig 3200 ram, gtx 1080ti sli, hb bridge, cm 280 aio, 500gig 950pro, 750gb crucial ssd, 43inch phillips and 24 inch aoc monitors. server dual xeon quads, 48gig ram, 5x3tb and 2x1tb, hx850, lianli case, freenas.
hairy is offline   Reply With Quote
Old 19th May 2017, 7:58 PM   #7
FOTW
Try these configurations mods. Does require you to edit game files. Some people have reported 30-40fps boost.
https://www.primagames.com/games/pla...-battlegrounds
01011001011011110111010100100000011001110110010101 10010101101011001000000011101100101001
OCAU Night Owl
OCAU Camera Club
FOTW is offline   Reply With Quote
