Go Back   Overclockers Australia Forums > Specific Hardware Topics > PC Audio
Old 4th October 2009, 3:29 PM   #121
dakiller
(Oscillating & Impeding)
dakiller's Avatar
Originally Posted by NoRemorse1812 View Post
I had a pair of Zalman ZMRS6F Headphones which were cool for their price. I'm after a pair for this Christmas - any suggestions?
Yes. Take it to [URL="http://forums.overclockers.com.au/showthread.php?t=801514"]the correct thread[/URL, and read through it before posting helps as well too
dakiller is offline   Reply With Quote
Old 5th October 2009, 12:57 AM   #122
scottath
Default New Headphones
Hey all,
Looking to get my self a late birthday present of some nice headphones.
So far after chats with some guys from the Aussie thread on OCN i have narrowed my selection down to these 3:
Audio-Technica ATH-ES7
Sennheiser HD212PRO
AKG K81
these are all within my budget (of $100 - but i can stretch a little)
Which would you recommend?
Will be used for gaming, music from PC, music from phone (Samsung Omnia) mainly.
i like bass and do sound engineering for school for all the school shows/performances/presentation nights - so i know what sounds good *to me*
I have a friend with a pair of HD485 - and they have far too much bass in them for my liking - so use that as a comparison....
I wish to get these soon - as i have end of school exams soon....
Thanks in advanced
scottath
| i7 4770k | GA-Z87-UD3H | 2 HD5850 | HX-850v2 | Lian Li v2010b | Samsung 840 Pro 256gb | TRUE | 12gb 1600 c8 | Xonar D2X + Swan T200B + SVS PB1000 | Dell U2713H + Dell E248WFP*2 + Dell 2405FPW |
| Canon 5D2/7D/550D | 17-40 F4L | 28-75mm f2.8 Tamron | Canon 70-200 F2.8L IS II | Canon EF 85mm f1.8 | Zeiss 50mm F2 Makro |
scottath is offline   Reply With Quote
Old 5th October 2009, 1:35 AM   #123
Comma
Comma's Avatar
On the ES7's. Great for portability. Not so great for sitting around and listening. They aren't particularly comfy and the short cable doesn't sit nicely with home setups.
Comma is offline   Reply With Quote
Old 5th October 2009, 9:01 AM   #124
scottath
hmm - ok then - that will sort of eliminate them also.
Also - thanks to the mod who moved it into here - i almost posted it in here.
Old 5th October 2009, 10:20 AM   #125
Snufkin
Snufkin's Avatar
If you don't want something overly bassy, the HD212pro aren't going to suit - they're boomy and muddy.
The AKG K81 has been replaced by the K518DJ, which are another bassy model.
I'd suggest the Shure SRH440 if you need closed, or Alessandro MS-1 if you don't.
Snufkin is offline   Reply With Quote
Old 5th October 2009, 10:26 AM   #126
scottath
the MS-1's look rather delicate...
I posted thisd on the OCN forum also - and they have recommended many - but the consensus seems to be the Senn HD555;s
http://www.overclock.net/sound-cards...eadphones.html (not sure if you can see that though.....?)
Also - i want to get them ASAP - so the MS-1s are out of stock atm on your site
Have HSC coming up - want them before that for study sessions
Old 5th October 2009, 11:06 AM   #127
MomijiTMO
MomijiTMO's Avatar
The Grado design does indeed look fragile but hey, they have very expensive headphones that use the same design. It's simple and fewer things to go wrong I guess. As long as you aren't an abuser, I can't see anything wrong happening.
I believe the MS1i's are due in soon [end of the week maybe? depends on customs].
Don't fall into the Sen hype. It's the default go to company. You could get something better than the 555s for the price.
Q6600 | DFI x48 LT | GTX 260 | HX-620 | Lian Li V2010B
i7 920 | DFI x58 UT | GTX 275 SLI | TX-850 | 2 x Lian Li A09B
MomijiTMO is offline   Reply With Quote
Old 5th October 2009, 11:13 AM   #128
scottath
please recommend then
i like to think im careful with my things - my touchscreen phones ive had over a year now and haven't cracked the screen (only dropped it twice)
Old 5th October 2009, 11:19 AM   #129
MomijiTMO
MomijiTMO's Avatar
Hey I baby my stuff but went to put my phone in my pocket, only to have it slip out of my hand. As it was flying towards the cement, I quickly stuck my foot out in an attempt to cushion the landing. Walked away some tiny marks on the plastic casing. My heart was going nuts.
I guess it depends what your priority is. If it is music, the MS1s are better. They go nicely with rock. If it's gaming, well I'm not sure. Shures?
Old 5th October 2009, 11:27 AM   #130
scottath
lol - they will be widely used....
music + gaming
i have done much the same - the foot trick.lol
My predicament - i know nothing of good headphones, i want really good ones but for a broad range of uses....
The MS1's everyone seems to like - but to me they look like they are rather easy to break....so not sure on them
Old 5th October 2009, 11:32 AM   #131
MomijiTMO
MomijiTMO's Avatar
You have to get what you want. If you think they might snap, don't get them. I'd wait for snufkin to come back to suggest alternatives.
The 440s are said to be excellent closed phones for the price.
Old 5th October 2009, 11:35 AM   #132
scottath
im a waiting....most likely i;ll get them from his store also...he has nice prices and free shipping !
Also - i dont really have experience of closed vs open either.....
Also - any of them come with some sort of case? (hard preferred)
Old 5th October 2009, 12:50 PM   #133
Snufkin
Snufkin's Avatar
The headband and supporting arms etc are metal, you can bend them but breaking them isn't so easy. Cables are the weak points on headphones.
http://headphones.com.au/blog/open-vs-closed-headphones
Nope.
Our MS1 stock is due very soon. I don't recommend the HD555 because they're basically mediocrity at its best, ie: they don't do anything particularly well, or anything particularly badly.
Old 5th October 2009, 12:59 PM   #134
scottath
Right - so the Slightly cheaper shure's or the MS1's people?
leaning towards the shure's now as i need to get them ASAP
Thanks for the advise Snufkin
Old 5th October 2009, 1:02 PM   #135
Snufkin
Snufkin's Avatar
The Shures are great if you need isolation, the MS1 are quite a bit better if you don't.
Tags
audiofx, beyerdynamic, creative, earphones, etymotic, headphones, headphonic, logitech, plantronics, razer, sennheiser, tdk, ultimate, zalman
