![]() OCAU News - Wiki - QuickLinks - Pix - Sponsors |
| Notices |
Sign up for a free OCAU account and this ad will go away! Search our forums with Google: |
Thread Tools |
#1 |
RIP
Has anyone ever used this product.
Engine Ice I would be interested in opinions of this product regarding info provided in the FAQ section of their web site. Neil |
| Join OCAU to remove this ad! |
#2 |
RIP
I just ordered some, will post back with report and pic's
Neil |
#3 |
(Banned or Deleted)
uhh dont use engine coolant
in your pc .. its apparently bad for some reason , but good luck. |
#4 |
Old and Decrepit
[EDIT:I've removed the crap from this thread. Keep it useful or keep it to yourself.]
Let us know what you think after you try it. It should work fine. Theres nothing wrong with using engine coolant, except that it usually doesn't do quite as good a job of heat transfer as water, unless your system is running at sub-zero tempt of course. I've been using Tecalloy 100+ for 5yrs so far and its always done the job well but as I mentioned, I only use it because of sub-zero temps. The pump doesn't push ICE very well Mred32 |
#5 |
(Banned or Deleted)
ohh, thats what i thought,. i would reccoment that nulon stuff, or . what i use
swiftech hydraX |
#6 |
(Banned or Deleted)
or you could just use Nulon like everyone else.
Or as some of us use Listerine. Minty fresh and works a charm ![]() -Matt |
#7 | |
(Banned or Deleted)
| Bookmarks |
Sign up for a free OCAU account and this ad will go away! |
| Thread Tools | |
