![]() OCAU News - Wiki - QuickLinks - Pix - Sponsors |
| Notices |
Sign up for a free OCAU account and this ad will go away! Search our forums with Google: |
Thread Tools |
#106 | |
What shit results, considering the H50 is stock, so adding two x decent fans on the H50 should yield very similar results to the H70. But then again, you could add better fans to the H70.. But AFAIK the H70 fans are pretty top notch in terms of static pressure and performance (from what i've read anyways).
i7-3770k @4.8ghz (Delidded) | Asrock Z77 Extreme 6 | 16GB Corsair Vengeance 1600mhz DDR3 | Zotac GTX 580 3GB SLI @ 940/2100mhz 1.150v | Corsair AX1200 PSU | LianLi PC-Z70 | Dell U2311H x3 NVsurround | Win8 Pro 64bit | Watercooled CPU + GPU's
| Join OCAU to remove this ad! |
#107 | |
#108 | |
I'm seeing more shit results.
Core i5750 @ 3.2ghz Corsair H70 (two fans) || Corsair H50 (one fan) 100% Burn (C) 51.25 || 56.5 Quote:
#109 |
(Banned or Deleted)
5 degree's isnt bad, thats pretty good actually
#110 | |
Inverted Monkey
#111 | |
#112 |
Considering its against the H50 stock.
what if they added two decent fans to the H50, you could make that 5* difference even more marginal Consider the extra cost, its approx $30 more then the H50 according to some sources (yet to be verified) So I would say that's pretty shit results., But hey, these are early test, will just have to wait and see wont we boys!
#113 | |
#114 |
very disappointing results
#115 |
Yeah disappointing SO FAR. Out of two pretty dodgy reviews that is. Wait for some real reviews to come in, using the same fan setups on both the H50 and H70, plus using a more standard case over the Raven RV-02.
If an i7 @ 4GHz is 5C cooler at load with a H70 over a H50 using the exact same two fans then I reckon it would be worth it. Maybe not worth an upgrade if you already have a H50 with two decent fans, but worth it if your coming off a large air cooler and want something neater and nicer looking that performs just as well as a 1kg lump of metal!
The ULTIMATE Sleeper PC - Awakened: Intel Core i5 2500K | Thermalright MUX-120 Black | ASUS Maximus IV Gene-Z/Gen3 | 8GB G.Skill Ripjaws | Inno3D GTX 570 OC | Thermalright Shaman | Samsung 830 256GB | Corsair AX850 | IBM Aptiva mATX | Lamptron FC Touch | Dell U2412M | IBM KB-9930 | Logitech G700 | Xtrac Ripper XXL Steam Last edited by Zenskas; 7th August 2010 at 9:47 AM. |
#116 |
Pity the H70 hasn't seemed to knock the H50 down, pity for some that is.
I am sure H50 owners are glad though
Intel E8400 OC@3.6GHz, EP35-DS3R, 4GB DDR2 800MHz, Gigabyte 1GB GTX560 OC@830MHz, Intel X25-M G2 80GB SSD, 2x 500GB WD BLUE AAKS, Antec Sonata III, Zalman 9700, 22" Samsung + 24" BenQ, & Win7 x64 SP1
CHECK OUT MY PRACTICAL CYCLING AND CYCLE TOURING BLOG: VELOPHILEAUSTRALIA! |
#117 |
Some high expectations in this thread.
#118 |
#119 |
(Banned or Deleted)
#120 | |
My rig i7-2600k@4.6 | Z68X-UD7| 16 GIG | GTX 690 | 120 Intel 520 | Win 7 64-Bit | D5 & XSPC W/C | 800D | 24" ASUS 120hz I am the 120fps Nazi
| Bookmarks |
| Tags |
| corsair, h50, h70, hydro |
Sign up for a free OCAU account and this ad will go away! |
| Thread Tools | |
