Go Back   Overclockers Australia Forums > Software Topics > Programming & Software Development
Old 13th August 2002, 11:56 PM   #1
Geo Thread Starter
Default Geo's fantastic Perl script
Here is a little perl script I knocked up a while ago.
Download me
I wrote this little program while I was doing alot of C++ programming. When writing C++ I always write the headers first then write the cpp files. After writing a big long header file it always seemed really tedious to have to re-write your method declarations in a cpp file to fill out the actual methods themselves. So I looked around the net for something that convert headers to cpp files, but I could only find a commercial product that did it. So I spun my own, and its free.
Basically it reads in a C++ header file and writes out the cpp file with the skeletons of all the methods that need to be filled in. It should work for most standard class definitions, things that are little more tricky (or things I left out) it might stumble over. If you try it on anything and it produces the wrong output, let me know (post in here) and Ill fix it.
Feel free to use it for anything you want, C++ programmers might find it a real time saver, I do.
Like I said, if there are any bugs please let me know.
Aside:
Its good when you invent something out of laziness, has anyone else ever taken a few hours to write something that will stop you having to do something that will take 5 minutes, or just invented something out of laziness?
"That's the way good software gets designed. So if you pull out a piece it won't run" - Steve Ballmer
Geo is offline   Reply With Quote
Old 14th August 2002, 11:05 AM   #2
gatecrasher
gatecrasher's Avatar
Aside:
Well its not that lazy, but i had JCreator (Java IDE) set up so it autocompletes System.out.println("") and places the curser in between the "" was simple but made coding sooo much quicker..
gatecrasher is offline   Reply With Quote
Old 15th August 2002, 7:24 PM   #3
Geo Thread Starter
So has anyone downloaded this or has my generosity been in vain?
Old 15th August 2002, 8:06 PM   #4
Rampage101
Well I can see the use for it, but for me to need it at the moment is just not happening. I'm only doing my second UNI unit, a second C++ unit, but I'm still only in Year11 at school and don't do enough programming as of yet. Although I'm looking into game programming.
AMD Phenom 920 || Gigabyte GA-MA790FX-DS5 || Seagate 320gb & A-RAM 64gb Pro SSD || 2x2GB Corsair XMS PC6400 DDR2 || 512MB Powercolor HD4850 ||
AMD Athlon II 245 || Gigabyte GA-MA770-S3 2.0 || WD 250gb OS, MDADM 5x HD753LJ Raid 5 || 2x2GB Corsair XMS + 2x1GB XMS || Nvidia x16 PCI-E cut down to 1x ||
Rampage101 is offline   Reply With Quote
Old 15th August 2002, 8:17 PM   #5
Decker
Decker's Avatar
I downloaded it. Haven't used it yet, but seeing as I'm studying a few different header files atm and will be doing C++ for a while yet, It'll be very handy, I'm sure.
KTHXBIBIKEKEKE
Decker is offline   Reply With Quote
Old 16th August 2002, 9:18 PM   #6
xntrik
don't tools like the MS' Visual Studio and Rational Rose do this stuff already?
ie: u give it all the UMLesque info (incl. specs) and it'll create all the files with skeletal information?
Christian "xntrik" pHreakshow xntrik@gmail.com un-excogitate
xntrik is offline   Reply With Quote
Old 17th August 2002, 1:56 AM   #7
Geo Thread Starter
Not everyone uses those tools do they?
Old 17th August 2002, 9:58 AM   #8
SpeedRacer
SpeedRacer's Avatar
Originally posted by xntrik
Rational Rose
ARRGGGHHHH
/me runs off screaming!!!!!
Frangipani's on cars... Australia says NO!!!
SpeedRacer is offline   Reply With Quote
Old 17th August 2002, 12:52 PM   #9
xntrik
yep. I suppose your both right.
and who could stay mad at you perl.. oh perl!
Old 19th August 2002, 7:35 PM   #10
Predator
Predator's Avatar
Originally posted by SpeedRacer
ARRGGGHHHH
/me joins SpeedRacer
Originally Posted by Christopher Joye View Post
Idiots will tell you that this means house prices are going to fall 20-40%. There is not a snowball's chance in hell that will happen.
Predator is offline   Reply With Quote
Old 28th September 2002, 6:27 PM   #11
Geo Thread Starter
I just did an update to this. It how handles the ordering of constructors a bit better and handles class and method declarations that span multiple lines... if any one is interested.
Old 28th September 2002, 8:13 PM   #12
DRILL SGT
GEO, fuck yeah apps that save you time own ass. I was sick and tired of having to open IE and Notepad so I developed my own VB HTML/Javascript Editor and it saves time. Alas I am not at that level of C++ coding nice and slow does me fine.
DRILL SGT is offline   Reply With Quote
Old 29th September 2002, 1:54 PM   #13
Nasher
They do. You also pay through the nose for licences if you wish to use these products legally. That's why I've boycotted Visual C++ 6.0 and taken to writing my programs in TextPad and compiling them with Borland command line tools.
I'll be the first to admit that I'm a C++ dunce, but I've had no luck in getting Geo's script to work. I knocked up a simple header file to feed it, and so far I've received no useful output. Here's my header file:
Code:
class blah : public test
	public:
		blah();
		~blah();
		int blah4(int a);
		char blah5(int a, int b);
I've named the file t.hpp
Originally, the script would straight away output "t.cpp written" and the file would be empty. I found out this was just because I'd stuffed up the header.
Now, if I'm not mistaken, the script should generate something like this:
Code:
test::blah()
test::~blah()
int test::blah4 (int a)
char test::blah5(int a, int b)
Correct?
I run the script, and a t.cpp will be created, but the script will freeze. Task manager indicates that perl.exe is using '99 CPU', so presumably it's trying to do something, but nothing seems to happen. The script doesn't end unless I ctrl-c it, and the t.cpp file remains empty.
I'm using Perl 5.6 which I found lying around on my hard drive, using Windows 2000 if any of that information is relevant.
Nasher is offline   Reply With Quote
Old 29th September 2002, 3:49 PM   #14
Geo Thread Starter
Ah, your one of those curly brace on the next line people arent you. I usually put mine on the end of the line (K&R Style) and I have tried one on the next line yet. I'll fix it up for you.
Thanks for testing it.
Old 29th September 2002, 3:53 PM   #15
Geo Thread Starter
Actually, it did already handle it, you left a ; of the end of your class declaration. It should be:
Code:
public blah {
But Ill fix it up to handle it more gracefully and only output K&R style braces if K&R style braces were used.
