3.5mm extension for quality headphones?
Discussion in 'Audio Visual' started by antikk, May 12, 2012.
  1. antikk
    antikk Member
    Mar 19, 2009
    642
    Melb
    hey all
    just wondering if i would notice reduced quality audio if i were to use a generic 3.5mm extension cable for my earphones running off my iphone?
  2. DarkForceMage
    DarkForceMage Member
    Apr 3, 2009
    3,213
    Brisbane, Southside
    I use a $5.00 extension for my AD700's as my cheap 2.0 speakers don't have headphone out and it works fine, I tried the headphone out on my PC case but it must be unshielded as there's a horrible feedback noise which is why I don't use it.
    So short answer, it'll be fine.
  3. HairyMerkin
    HairyMerkin Member
    Jan 21, 2009
    1,842
    Melb
    No, the iPhone will almost definitely be the weak link unless it's cable made from sticks.
  4. Benno1988
    Benno1988 Member
    Oct 30, 2007
    3,552
    Just get something of ok thickness and build quality to ensure it doesn't fall apart on you.
    I usually eBay my cables, look for something with of good thickness, i like my sleeving too!
  5. antikk
    antikk Member
    Mar 19, 2009
    642
    Melb
  6. Benno1988
    Benno1988 Member
    Oct 30, 2007
    3,552
    Would do the job. It doesn't have any strain releif near the jack, just like the iBuds, so its likely that the cable will rupture there at some stage.
  7. garetz
    garetz Member
    Aug 7, 2002
    884
    2217
    Since its so cheap, your best bet is to buy it, then use it, and see if you hear a difference.
