3.5mm headphone jack replacement
Discussion in 'Electronics & Electrics' started by supernom, Apr 24, 2012.
  1. supernom
    supernom Member
    Apr 28, 2009
    2,608
    Lyndhurst, Melb
    hello everybody
    i need to replace the 3.5mm jack on my AD700's , now I'm just wondering if anyone knows any shop that will be open tomorrow that will sell them. I can think of jaycar but according to the website they are not open.
  2. admiralranga
    admiralranga Member
    Aug 8, 2011
    298
    Claremont, WA
    maybe try RS Components (1300 656 636)?
  3. Gecko
    Gecko Member
    Jul 3, 2004
    2,716
    If you want it tomorrow, you're probably better off posting an offer for a 6 pack for anyone that you can pick one up from locally :)
    I know I have plenty of them in the workshop, but I'm up in Syd.
  4. spludgey
    spludgey Member
    Jun 30, 2001
    5,427
    Just get some old headphones and chop them off. Surely you've got some somewhere or know someone who does.
  5. Piroteknik
    Piroteknik Member
    Jun 17, 2002
    379
    Bat Country
    doesnt bunnings carry some connectors in their larger stores?
  6. supernom
    supernom Member
    Apr 28, 2009
    2,608
    Lyndhurst, Melb
    So I hacked together a temporary fix until the shops open and I can get a brand new good quality jack. Chopped off my current (broken) AD700 jack, expose 3 wires. Chopped the jack off an old pair of phones, (made a mistake, should have left more wire hanging off it lol )
    Connected the new jack onto my ad700 wires. I put some PVA wood glue around the end to try and stop the wires touching each other on any exposed bit.
    And it works! It's not perfect ( left is slightly louder than right ), but it's better than no sound at all.
    http://iforce.co.nz/i/v0qudj04.ied.jpg
    http://iforce.co.nz/i/0rbuesvq.lnj.jpg
    Hehehe =D
    I wanna get a new soldering iron and some of those alligator clips on a stand to hold it. I really struggle to get a nice solder joint, it tends to want to stay in balls. Hehehe
  7. mtma
    mtma Member
    Aug 12, 2009
    4,333
    When doing wire chops I usually stagger the joints so they're not on the overlapping positions. This allows you to not have to use heatshrink or tape on the inside and end up with a nice slimline join once heat-shrunk.
    On thicker wires it doesn't matter as much though, but the thin headphone style wires can be a bit of a pain for this detail.
    ED-
    Also for the adventurous you can actually re-use the moulded plugs with the careful application of a knife on the jack's moulding. you can tear the plastic off and get to the contacts of the TRS this way, and if you happen to be lucky these will be pretty easy to solder. If you're unlucky you can still use the jack, it will just be more finicky.
    Then you can use epoxy or hot glue to reform the actual plug body.
