Asrock BIOS UI Problem!! help!
Discussion in 'Troubleshooting Help' started by bumography, Mar 11, 2017.
  1. bumography
    bumography Member
    Mar 8, 2006
    1,492
    Adel
    HI,
    So I bought a few asrock B250M-PRO4's
    This is what has happened.
    BIOS works fine, First setup I enter a bios PASSWORD (supervisor).
    Now, with every PC, after i've set a password, the UI Is all screwed up. The screen appears black (after entering correct password) and if i move the mouse cursor around it shows some graphics but no options. ! I cannot get into the bios anymore.
    I've tried updating to the current BIOS through DOS but still the same problem persists.
    I'm trying to avoid moving the battery, as these computers have a GFXcard which is in the way (trying to avoid pulling out GFX on each computer...)
    Anyone had this problem before? or know how to solve it?
    It appears I'm not allowed to set a supervisor password anymore... to enter the bios but that really is required.
  2. i7Baby
    i7Baby Member
    Jul 3, 2012
    289
    I've never set up a password with bios. Can you undo it? eg reflash bios.
  3. bumography
    bumography Member
    Mar 8, 2006
    1,492
    Adel
    Unfortunately I have to reset it by taking out the battery.
    Massive hassle because i have to take out the graphics card.
    I can't setup a bios password if i ever want to get back into the bios. Which sucks.
    I might have to email asrock to tell them to fix the issue.
