©º°¨¨°º Disco Scorpion º°¨¨°º©
Discussion in 'Modding Worklogs' started by Defyant, Sep 9, 2017.
  1. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    Defyant Modded "Tail" Lights!
    Latest Work log progress pics.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    DISCO SCORPION
    It's been quiet some time since i contributed the modding forums and after being inspired by the recent RGB craze i decided to dust off the old modding gear and have a go!
    This old Junker will be transformed into the ultimate RGB SFF PC.
    It's got the main things i wanted in a chassis. Small solid and "flippable" ;) With a window that presents on the opposite side.
    This is an OLD SKOOL case mod and will follow the formula i used on most of my previous mods.
    *Lots of plex ( Seriously lots!)
    *Lots of RGB lighting (in bucket loads)
    *Custom Defyant signature water loop (it's back)
    *Side mounted custom hand made Res (Defyant Style)
    *Every part will be fabricated by my own hands
    *Hardware is still not set in stone
    *And have some fun :D
    The Case to be transformed is an OLD SKOOL Ocktec P3 case mad by Compaq (hence the orig worklog title) And a OLD SKOOL case Deserves OLD SKOOL Modding.
    The first thing to do is strip the case down the chassis and cut away a large section at the front top and rear to accommodate the new cooling and windows.
    Next is to give the chassis a rub down and a few base coats of white. This is only a pre coat to build with. A final respray will be done near completion.
    With that out of the way it's time to start some good old plex modding.
  2. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    The first Panels to be installed will be 3mm gloss white plex.
    * PSU shroud/cover Full length.
    * MB back panel Cover.
    The PSU shroud is cut to size and bent using a DIY line bender.
    The line bender give a clean tight bend
    The mother back panel cover is a measured drilled and cut to size.
    The panels are sat into the chassis for a test fit.
  3. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    The First RGB mod will be installed to the PSU Cover.
    * PSU Accent RGB Lighting
    This will be a simple Accent light to run along the side as a light feature for the PSU cover.
    A section of 3mm white plex is cut to size and a matching piece of clear is cut to the same shape.
    The clear will catch the LED RGB strip and carry light.
    To stop the light bleeding thru the face side the White panel is painted with white to the back.
    This dos not stop the light bleed but it does hide the black out vinyl that is applied next.
    The clear panel can also be painted white and the 2 sections can be glued.
    A strip of RGB led's can be laid into the pre cut out section and the panel installed using double side tape.
    And Disco time begins!
  4. Supernauty
    Supernauty Member
    Jun 22, 2017
    29
    Tasmania
    This is looking awesome, nice work
  5. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    1,864
    Nulkaba
    look forward to watching the mods:)
  6. havabeer
    havabeer Member
    Dec 12, 2010
    2,851
    Great work with the Perspex
  7. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    :thumbup: thanks guys :)
    I'll keep posting regular updates as often as i can :thumbup:
  8. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    The next Mod for the internal Panels will be to add a front and rear fan mount system.
    Disco Scorpion Wont use traditional fans. The fans will be incorporated into the chassis and panels of the case.
    *2 x 120mm Modified fans front
    *1 x 120mm Modified fan Rear
    First the front internal panel.
    A fair bit of measure twice cut once went into this panel some careful dremel and deft router work to make these possible.
    With the panel in the case it starts to make sense.
    Some Spare fans are stripped and gutted for a test run.
    The final fans will be EPOXIED into place.
    Air flow is surprisingly good and will get alot better once the front is added. This will be a positive pressure system.
    The exact same mod is done for the exhaust panel @ the rear of the case.
  9. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    RGBRGBRGBRGBRGBRGBRGBRGB
    The next RGB Feature lighting will also be to the back of the case.
    This mod will be done much the same way as the side feature was done. Again using a clear panel RGB strip blockout tape
    and a feature ring.
    * The feature ring also acts are a cowl surround to help the fan draw air out.
    These type of mods are like a full mod within a mod...
    The ring is routed to a 45 degree angle
    As part of the whole assembly
    and installed as shown
    The end result is a Second internal RGB Feature
  10. sammy_b0i
    sammy_b0i Member
    Jun 29, 2005
    3,227
    ACT 2914
    God I missed your mods, Defyant! Always such classy work. :thumbup:
  11. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    RGBRGBRGBRGB
    TYVM mate:thumbup: Always good to cu2 :)
  12. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    RGBRGBRGBRGB
    Front Panel Fascia
    I again i'm going back to my old mods for inspiration on this.
    The main features for this panel will be.
    *5 layered plex 2 clear 3 white 8-10mm each
    *Defyant style Dual 120mm blow holes
    *Full RGB lighting
    *Replaceable RGB RGB Lighting
    *Power/Reset Buttons (hidden)
    *Magnet hold
    I had to make this whole panel twice... and depleted alot of my PLEX stockpile. But the end result was more then worth the cost.
    It's starts by Routing circles to house the 120mm fans. This is done to 5 panels 10 holes.
    When all 5 panels are done they create the sandwich effect. It's ALOT of plex. close to 2KG.
    Next is to create the channels that the RGB LED strips will sit in.
    The unit was salvaged from an old epc. and with a little modding perfect for the concealed buttons.
    The middle 3 layers are routed
    Next is to add the magnet hold mod. (this is more to help with modding)
    Cover the back and front layers with block out vinyl.
    Add all the layers together
    Slide in the RGB strips
    Router the edges
    Add the power wires 4 into 1
    A qik test
  13. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    Testing front side and rear RGB mods
    As you can now see Disco Scorp is it's own RGB light feature.
    No need for RGB Fans or RGB addons.
  14. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    RGBRGBRGBRGBRGBRGBRGBRGBRGB
  15. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    1,864
    Nulkaba
    cool work:thumbup:
  16. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    Cheers mm tyvm
  17. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    RGBRGBRGBRGBRGBRGBRGBRGBRGBRGB
  18. vladtepes
    vladtepes Member
    Sep 30, 2015
    1,188
    Brisbane, Qld
    This is a sweet build; very creative !
    Funny thing is what you call "A bit MEH!!" I would be pleased as punch with ! But then, I'm new at this...
  19. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
    Cheers mate tyvm :thumbup:
    It just dosnt "pop" as nice as the other lights.... and it was a bit rushed.
    Got a whole half a day to throw at it this weekend so hoping to get a few things done :)
  20. Defyant
    Defyant Member
    Mar 11, 2004
    1,107
