©º°¨¨°º Disco Scorpion º°¨¨°º©
Discussion in 'Modding Worklogs' started by Defyant, Sep 9, 2017.
  1. sammy_b0i
    sammy_b0i Member
    Jun 29, 2005
    3,222
    ACT 2914
    One day I'll have enough play money to commission a custom case from you Defyant. One day!
  2. Deano_20802
    Deano_20802 Member
    Apr 21, 2009
    236
    Tas
    Yeah that'd be hard to find these days :confused:
    Back in the single core / PCI (pre AGP / PCIe but post ISA for all you youngsters haha) days I used to get low end to mid-range boards, rip any cooling off (if they had any other than maybe a tiny heatsink on the chipset) and Frankenstein it up with old server heat sinks and fans ghetto modded on, then go for big overclocks :lol:
    The number of dead cap's I had to replace :sick:
    I'd love to do a modern, beaut' looking take on that... I'll put that on the project list :thumbup:
  3. Spork!
    Spork! Member
    Jun 5, 2009
    2,260
    Tasmania
    Don't see many like this.
    I'm just a "buy bits and assemble" type of guy, but I do enjoy seeing worklogs from true artisans like yourself. :thumbup:
  4. BigDave
    BigDave Member
    Nov 12, 2007
    3,680
    ADELAIDE/5018
    I'm with you G :thumbup:
    Defyant this is awesome :cool::thumbup::cool:
  5. Bertross
    Bertross Member
    Feb 2, 2009
    12,992
    Melb, CBD
    Holy Christ this is mint
  6. Defyant
    Defyant Member
    Mar 11, 2004
    1,105
    Defyant Modded Headlights
    Sammy i'd build yours free mate :D Cheers mate tyvm :thumbup:
    I'D love to see that project mate :thumbup: old skool p3/retro projects are really making a comback in the modding scene!
    A GREAT way to mod @ a reasonable cost :thumbup:
    Cheers Spork tyvm mate ... this is going to be a long worklog and it's the support that usually get me thru them :)
  7. Defyant
    Defyant Member
    Mar 11, 2004
    1,105
    I'd better give yas an update!
    Like the MB Armour this is just Concept atm
    I want the DS to have a Signature Side res but after looking back all my old diy res's just look dated.
    After a good amount of thinking i knocked up this. In honesty i'm pretty happy with the result and prolly stick with it.... Altho i may try one of 2 more designs this weekend
    Like everything on this mod is starts out with ahuge chunk of plex
    2 x white 1x clear 30mm+ :thumbup:
    All 3 are router cut to the same exact size.
    one is gutted to make the outer housing and the clear is edge routed.
    It's still not quiet deep enuf need to buy a reverse router bit then i can cut down into the bottom layer to add more CC's.
    And of course is has to be able to Go Disco!
    A quick mock up to show how it will be mounted to the case.
    I think it's a new spin on an old idea :)
  8. Deano_20802
    Deano_20802 Member
    Apr 21, 2009
    236
    Tas
    It's on the list, I'll see what happens post Crissy :thumbup:
    I think it looks great, it should work out nicely :)
  9. Defyant
    Defyant Member
    Mar 11, 2004
    1,105
    Cheers mate ty , i gotta agree :thumbup: in the end i was pretty impressed too! :D
    Had a pretty productive day today.
    Side Panel.
    * Must look sexy!
    * Must be RGB
    * Cut out for recessed RES and SSD
    The Side panel will be done fab'd from 3 layers of plex.
    The first layer is actually the support plate for the Side Res.
    This means that the Side Res will be "hard mounted" to that panel.
    That panel will then be corner mounted to the chassis.
    Effectively make the res and panel one joined piece.
    The second layer is clear and is the RGB light diffuser for the Side Res and a Window for the SSD.
    The third layer is white and the side panel of the case. This and second layer will be hard glued also effectively becoming one piece.
    The case on it's side. The right is front.
    The first layer is just a ruff cut white panel. The RES will eventually be HARD GLUED to this panel.
    Second layer (middle) is 6mm Clear this layer is the LIGHT layer and window layer to the SSD.
    This layer is OVERSIZE marked with a trace of the side RES which is then
    Router cut and then Scroll sawed.
    The next mod to the light panel is to add the channels for the RGB Strips
    The panel can now be temp taped to the 3rd panel and taken to the router to copy the hole.
    The clear middle panel can now removed, flipped and covered with block out.
    The block out can be trimmed a few mm from the edges this will all the light to flow and bleed through the top layer (case side wall) and give a very soft but classy hue around the Side RES.
    Also a cut out for the SSD window is made.
    The trimming is made in opposite on the sidewall top (3rd panel)
    Once the bulk of protective paper is peeled away a slim edge is left on the inside of this panel.
    This panel is then given a coat of white paint on it's inside.
    ( the white paint is to stop the black blockout film from darkening the plex)
    Once dry the thin strip of paper left around the res and ssd can be removed
    This layer can be flipped and the 2nd layer and this can be hard glued together.
    With that done i can temp attach the res and site the new panel onto the side of the case for some........
    Disco time!!
    I didint want to remove any of the outer protective paper just yet...
    But i couldnt resist a sneek peek at how the edge hue came out.
    I'm happy :thumbup:
    There is a "dark spot" @ the top... i'll fix this by adding small strip to that area.
  10. dinos22
    dinos22 OCAU Sponsor
    May 8, 2004
    12,294
    Love your work man, brings back the old days.
  11. dinos22
    May 8, 2004
    12,294
    Daaaaaaaaaaaaaaaaaayumnnnnnnn
  12. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    1,858
    Nulkaba
    looking sweet as:thumbup:
  13. Defyant
    Defyant Member
    Mar 11, 2004
    1,105
    Cheers BD tyvm mate :thumbup::thumbup:
    Cheers Bertross tyvm as well :thumbup:
    Ahhh the good old days :D :thumbup: Modding does make me feel 20yrs younger :p Cheers Mate tyvm:thumbup:
    A new mod is always and excuse to buy a new tool and add some thing new to the workshed :D
    Cheer mm tyvm mate :thumbup:
  14. Defyant
    Defyant Member
    Mar 11, 2004
    1,105
    A few small up dates this time :)
    *RGB HDD cover
    *1<5 RGB power strip bus
    Ive always wanted to make a RGB HDD cover and TBH i'm not sure i'll use it for this mod....
    Using the same style as all the other RGB modding.
    White paint is added before
