FPS Issues - PUBG
Discussion in 'Newbie Lounge' started by Blackrayne, May 17, 2017.
  1. Blackrayne
    Blackrayne Member
    Mar 15, 2015
    14
    So i recently upgraded my pc
    specs
    Gigabyte z270A - Gaming 5
    Intel 7700k
    Gigabyte GTX 1070 G1 Gaming
    G.skill TridentZ - 16GB 3000hz
    Samsung 960 Evo
    CPU Cooler - h80i
    Monitor :
    Acer Predator XB241H
    Issues creating decent frames when running any Hertz, 60-85
    I want to use the screen to it's most benefit, but from what i gather this game is very CPU dependent, i was thinking about OC'ing my CPU a little higher to possibly a stable 4.7, i have OC'd before with my AMD-6100 however it seemed a little more forgiving :p i got it up to 4.5GHZ stable (i know)
    If anyone could suggest some good ideas or even possibly help me with a basic clock that isn't going to impact negatively as far as FPS goes.
  2. tree86ers
    tree86ers Member
    Oct 12, 2004
    301
    i would not bother trying to "optimize" for this game right now since it is beta and things can change.
    I get the same sort of FPS with 2 x 1080's on a 6800K. until they finish the build and start optimizing the game after release there is not much point.
  3. RacinBacon
    RacinBacon New Member
    May 7, 2017
    10
    PUBG is very poorly optimized for even the best of computers. There is no need to do anything to your set up, as it goes above and beyond the requirements for PUBG. If you are experiencing lag, it is most likely one of the servers (I play it on my current machine, and I know there is one server that makes me and my friends lag out). Have you gone through the PUBG faq's on FPS issues?
  4. Reins
    Reins Member
    Jan 31, 2012
    89
    Are you running a lot of background applications simultaneously? PUBG does use a lot of RAM (mine uses 12GB+) so that MAY be a cause of issue for you. :thumbup:
  5. Beaistheman
    Beaistheman Member
    Nov 27, 2004
    1,393
    As above, game is terribly optimized. I just set everything to low except draw distance at ultra, keep native resolution and I found that anti-aliasing has little effect for my computer on frames so I put that up.
  6. hairy
    hairy Member
    Dec 11, 2010
    430
    my rig runs 50-60 fps don't think it uses sli at all, one card idle.
    my net sucks donkey balls though 200k down.
    turning down details and aa does nothing so I run at max.
  7. FOTW
    FOTW Member
    Jul 20, 2002
    693
    Waterford, Ireland
