HDCP Issue - 7870K
Discussion in 'Troubleshooting Help' started by eliminatrix64, Jul 17, 2017.
  1. eliminatrix64
    eliminatrix64 Member
    Dec 26, 2015
    1
    Hi All,
    I have an ITX box with an ASRock FM2A88X-ITX+ motherboard. It came with an AMD 5300 Dual-Core CPU. I've done a complete format and re-installed Windows 7 SP1 Ultimate.
    I upgraded the CPU to an AMD 7870K but when I try to play a BluRay with this CPU, the HDCP status is disabled. I'm using Cyberlink PowerDVD 17 Ultra and I use the Cyberlink BD Advisor to check the HDCP status.
    I've just taken it out and put the 5300 back and the HDCP is enabled / Ok.
    Could I have damaged the 7870K when I installed it in the socket to cause the HDCP issue?
    I really, really want to use the 7870K as I can see a massive and noticeable system improvement overall using this CPU.
    I've updated the BIOS to the latest to ensure it's compatible with that CPU.
    Any help / advice?
    Thanks!
  2. FOTW
    FOTW Member
    Jul 20, 2002
    693
    Waterford, Ireland
    Try installing the latest AMD APU drivers. See if updating it to windows 10 through https://www.microsoft.com/en-us/accessibility/windows10upgrade fixes the issue.
    If processor is damaged you could always get a cheap GPU for video playback heck you might even be able to game with it if its decent enough.
