Help with pc/help with new build
Discussion in 'Troubleshooting Help' started by Dave86, Mar 20, 2017.
  1. Dave86
    Dave86 New Member
    Mar 17, 2017
    7
    Hi guys,
    This is the first time I have been on this forum, I have built my two previous computers which were only ever intended for emails, surfing the web and the occasional movie stream, specs are as follows
    TX650W corsair PSU
    GIGABYTE GA-P55-USB3 motherboard
    CORSAIR 2x2gb DDR3 ram cmv4gx3m2a1333c9
    I have bought 2x4gb DDR3 ram cmx8gx3m2a1600c9 but my computer won't boot with this ram.
    ASUS EAH5450 graphics card
    1TB 2.5" WD Black drive brand new
    1TB 3.5" WD Blue drive
    LGA1156 socket I3 CPU @ 3.2ghz
    My question is I have installed windows 10 from windows xp a few months ago and all was fine, removed two hdds and bought the new 1TB drive and the ram to speed it up as my wife is doing a lot of graphic design and has a vinyl plotter now connected. Why will the new ram not workin my motherboard, they are only 4gb sticks, yes they are slightly faster speed but won't the auto function in the bios correct this to the max allowable speed? I am just wondering how I can get this new ram to work otherwise I am looking at another system that I have pieced together. If the general consensus is that the old system is outdated I will put up the parts I'm looking at buying to get some advice of im going the right way.
    Cheers
  2. Madengineer
    Madengineer Member
    May 27, 2011
    11,474
    You running 32 or 64bit os?
  3. Dave86
    Dave86 New Member
    Mar 17, 2017
    7
    Installed OS is 64bit
  4. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    11,494
    Can you get into BIOS? If you can then manually set the speed of the RAM to 1333Mhz and latency to 9-9-9-24. Voltage is 1.5V and try again.
  5. Dave86
    Dave86 New Member
    Mar 17, 2017
    7
    Yeah can do no worries
  6. Dave86
    Dave86 New Member
    Mar 17, 2017
    7
    Ok i will try this cheers
  7. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    11,494
    If it works, bump it up to 1600Mhz. It's rated at 1600 but the old RAM were only 1333Mhz, so process of elimination is try it at old speed manually to see if it works. If it does then move it up to 1600 and see if that works. If yes then it just means auto setting is stuffed. If it doesn't work, then possibly dud RAM. Try it one stick at a time or try different slot. Could also be dud slot.
  8. O-B-E-L-I-X
    O-B-E-L-I-X Member
    Jul 11, 2008
    858
    SYD, Matraville 2036
    Update the M/B BIOS to the latest version.
    The RAM you bought could be faulty.
    Buy a SSD drive to get a faster/better performance from this PC.
  9. Dave86
    Dave86 New Member
    Mar 17, 2017
    7
    Just comes up with a blue screen and an error. And the reboots
  10. Dave86
    Dave86 New Member
    Mar 17, 2017
    7
    Motherboard bios has been updated to latest version, always contemplated an ssd
  11. O-B-E-L-I-X
    O-B-E-L-I-X Member
    Jul 11, 2008
    858
    Clean the gold contact on the RAM "sticks" with soft rubber eraser and then with metho or isopropyl alcohol.
    As mentioned by the other poster, could be faulty RAM slot/s.
    The SSD's became cheaper and the performance gain is worth it.
  12. Dave86
    Dave86 New Member
    Mar 17, 2017
    7
    The original ram works fine in the slot it's just when I put the new sticks in
  13. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    11,494
    Yup, sounds like faulty RAM. Tried 1 stick at a time?
