Laing DDC vs EK-DCP 2v2
Discussion in 'Extreme and Water Cooling' started by zottffssen, Apr 23, 2012.
  1. aeries
    aeries Member
    Dec 5, 2011
    1,361
    Get the D5. Most used pump on these forums (I dare say), not one foul word used in the same sentence as the D5.
    The $50 you save can be spent getting a pump top for the D5.
  2. Creekin
    Creekin (Taking a Break)
    Jun 21, 2003
    10,109
    believe creekin, hes AWESOME! :thumbup:
    also i didnt say that exactly anyway :p
    they are about the same when it comes to "bestness" some things are just moar best than others :pirate:
    d5s moar common and moar reliable
    ddc is moar compact and moar warm
    thats about it.
    ftfy :thumbup:
  3. xRdawGz
    xRdawGz Member
    Dec 16, 2007
    752
    d5's are horrible, had 2 fail on me now. :/
    jokes, don't hurt me pls.
  4. bobster
    bobster Member
    Nov 11, 2011
    942
    As with all things its the luck of the draw
  5. Sleepy Dude..
    Sleepy Dude.. Member
    May 5, 2008
    1,669
    Parramatta,NSW Status:MIA
    my D5 lasted about a week before it turned into a tractor powered lawnmower.
    Swapped to an EK DCP4.0, have not looked back. i've only had to top up my system with the dcp4.0... 2 maybe 3 times since i put it all in? the D5 i was doing it monthly. it cracked two of my o-rings each month from pressure buildup or something.
  6. Creekin
    Jun 21, 2003
    10,109
    wtf?!? :confused:
    was the loop clogged perhaps?
    got any pics or a log.....never heard of that before
    seen them blow off a pump top but that was due to a faulty thread on the top.
  7. Sleepy Dude..
    May 5, 2008
    1,669
    Was about two years back, so I dont unfortunately. I have the pump somewhere in storage I think. The impeller inside the pump grinded itself out, so the hole was about 3mm thicker then what it should of been. I came home after work one day and I could hear the pump from outside my house. I thought someone was running a lawn mower inside my lounge room when I heard it. If I find it I'll upload some shots.
