Network connection is 1 way only
Discussion in 'Troubleshooting Help' started by shiny1, Mar 20, 2017.
  1. shiny1
    shiny1 Member
    Aug 16, 2003
    2,954
    Rikku's G-String
    - I have a PC and laptop.
    - Both were accessible to each other in network. They used to play nice.
    - Suddenly, laptop cannot access PC.
    - PC can still access laptop.
    - PC ping laptop OK, laptop ping PC timeout.
    - Turn off firewall on PC. Everything OK.
    - Settings are the same/haven't been touched AFAIK.
    Side note - network discovery will revert back to OFF on PC.
    What can I do to fix this so it's 2 ways again?
  2. harrye30
    harrye30 Member
    Apr 1, 2012
    192
    Login as admin
    CTRL + R 'Enter'
    CMD 'Enter'
    Ipconfig /flushdns && ipconfig /registerdns
    Try pinging it again and let me know the result. :)
  3. shiny1
    shiny1 Member
    Aug 16, 2003
    2,954
    Rikku's G-String
    CMD as admin, both flush and register commands work, pinging the PC ip address still times out
  4. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    11,494
    Firewall issue. Find out the ports you need then open them on the firewall. Or just turn it off.
  5. shiny1
    shiny1 Member
    Aug 16, 2003
    2,954
    Rikku's G-String
    The thing is, it worked before when I set up the network a few months ago. I never touched the firewall and now it just doesn't.
    What gives?
  6. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    11,494
    Windows update.
  7. PsydFX
    PsydFX Member
    Jan 1, 2011
    1,184
    One of your NICs thinks it's now on a Public network.
  8. shiny1
    shiny1 Member
    Aug 16, 2003
    2,954
    Rikku's G-String
    Last update was 5 days ago, but it's updating something now. Doubt it would change anything. Or are you saying a Windows update would throw off some settings?
    My PC is purely running on wifi, no LAN cable running to it. Does that change anything? How do I set it to private?
    Edit: just checked, network category on wifi is private.
    Will network reset do anything?
  9. harrye30
    harrye30 Member
    Apr 1, 2012
    192
    Go to windows firewall with advanced settings - turn off the firewall and try pinging the device again.
    There's no IP address conflict with another device on your network by any chance?
  10. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    11,494
    It's already established that firewall was blocking it.
