res/pump not straight
Discussion in 'Extreme and Water Cooling' started by mixsetup, Feb 16, 2017.
  1. mixsetup
    mixsetup Member
    Dec 22, 2003
    2,539
    Wynyard Tasmania
    Hi there any suggestions how to get it straight?
    https://www.dropbox.com/s/obhex1jxxgud85q/res.jpg?dl=0
    I thought when I put tubing in it will end up straight but what I have seen on YouTube it will just force the tube to be pushed down a bit.
    Oh it will be rigid tubes.
    Thanks
  2. Moptimus
    Moptimus Member
    Aug 22, 2011
    1,095
    Nambour-by-the-Sea
    It is hard up against the 4 x CDRW or whatever other piece of antiquated tech that is in the bay above.
    Either pack it out from where you have mounted it, get a usb dvd drive, or go all tower of pisa and shit.
  3. mixsetup
    mixsetup Member
    Dec 22, 2003
    2,539
    Wynyard Tasmania
    Hi there no it's not hard against the Blu-Ray bay there is an inch or so gap. The bottom where it is mounted is the surround bit which holds the hard drive cradle/bays.
    Think I might have to just redo it an see if it sits flat or the screw holes I drilled are flat and no bits of mettal sticking out as there has to be something I'm not seeing or thinking of. Thats all I can think of.
    Thanks
  4. mixsetup
    mixsetup Member
    Dec 22, 2003
    2,539
    Wynyard Tasmania
    Thanks going to just pack it out.
