Samsung Note 8
Discussion in 'Google Android (OS & Devices)' started by Kookooburra, Aug 23, 2017.
  1. HyRax1
    HyRax1 ¡Viva la Resolutión!
    7,712
    At a desk. Distro:Ubuntu
    I can see mine fine - what are your USB connection settings? Are you attaching the SD card to the PC exclusively as a storage device instead of an MTP device?
  2. wraith666
    wraith666 Member
    Jan 17, 2013
    1,525
    QLD
    Tried it as USB and pictures only. No dice. It can see the SD card and does save stuff to it but yeah on PC only Internal Storage comes up.
  3. walker_2003
    walker_2003 Member
    Jan 15, 2003
    8,367
    anyone had any success with glass screen protectors? the one I got (cheap) was a joke.. was a nuglass.. wasnt very clear, was thick and u could see the glue on edges :thumbdn:
    Back to film for now till I decide (which is lifting on edges) might need to bite bullet and go one of the expensive $60 glass ones.
  4. mils1
    mils1 Member
    Jul 17, 2005
    962
    I highly recommend the Whitestone Dome Glass. The ones with adhesive on the edges are the worst kind you can get. Sensitivity on the dome glass is great & the edges aren't felt when using the device.
  5. walker_2003
    walker_2003 Member
    Jan 15, 2003
    8,367
    someone else recommended that (if it wasn't you).
    The installation looks so complex haha..
  6. Moochin_Bastard
    Moochin_Bastard Member
    Dec 3, 2003
    459
    Stafford, Brisbane (4053)
    Thats hectic as, glad to see some proper glass protectors though the ones with glue only on the outsides are useless.
  7. StratosFear
    StratosFear Member
    7,956
    Melbourne, Australia
    Why not rock a naked screen for the first year and if it gets scratched you can "accidentally" crack your screen and get it replaced free of charge?
    :paranoid:
  8. TheBear21
    TheBear21 Member
    Aug 2, 2007
    2,383
    Central QLD
    I didn't realise people still used screen protectors?
  9. roxydog
    roxydog Member
    Oct 19, 2005
    57
    Geelong VIC
    Yeah - dump the protector. If the glass is the same as the S8+ it is super scratch resistant.
    Use mine in heavy metal dust environment with no scratches at all so far for many months.
  10. mils1
    mils1 Member
    Jul 17, 2005
    962
    It's more about drop protection.
  11. roxydog
    roxydog Member
    Oct 19, 2005
    57
    Geelong VIC
    The dome cover looks real good compared to normal screen protectors for sure. The video above is a beaut.
    I do have a cracked screen but can't see it most of the time. The top layer is some magic coating I'm sure haha.
