[TUTORIAL] 2D Design With Solid Edge
Discussion in 'Modding' started by Bastard Child, May 22, 2011.
  1. Bastard Child
    Bastard Child Member
    Jan 3, 2006
    3,567
    Crooklyn 3012
  2. Clacker
    Clacker Member
    Apr 17, 2007
    74
    Thanks for that, needed an early morning laugh!
    I tried comp mode with admin rights and it worked...unchecked both and it still worked??
    Anyways, looking good now so eager to start messing around in it.
    Thanks again for the time you've spent on this for us plebs.
  3. Bastard Child
    Jan 3, 2006
    3,567
    Crooklyn 3012
    20k views? Man you guys are slow learners... I mean er... thanks for reading and shit, yeah :thumbup:
    Here's one of the latest little jobs I've done - fitting a servo motor to a Harley.
    Holding it in place (plus some rubber blocks):
    Getting a couple of key dimensions down:
    Rough mock-up in SolidWorks (3D) to get angles and lengths set (easier than doing it in 2D):
    Cardboard Mk1:
    [​IMG] [​IMG] [​IMG]
    Don't worry about water compromising the load bearing of cardboard, Harley guys don't ride in the rain :lol:
    Refine it for Mk2:
    Refine the shape to Mk3 for DXF and laser cutting (SolidWorks can blow goats in some aspects, so I still use simple 2D sketching to refine outlines):
    3 chances to not fuck it up @ $5-$8 each in 304 stainless:
    Off to the magnabend:
    One bend the old fashioned way - hammer and a vice:
    [​IMG] [​IMG]
    And we're done:
    [​IMG] [​IMG]
    Headlamp clips for mounting:
    [​IMG] [​IMG]
    And the final install:
    [​IMG] [​IMG]
  4. BlueRaven
    BlueRaven Member
    Jul 29, 2010
    3,906
    Back in Sydney
    Tidy work, nice. Thanks for the reminder about this tute thread too, I got distracted by other things and never finished working through it after you posted the OP (I know, I know.... ungrateful bastidges :p).
    Bookmarked it now.
    Out of interest, what was the servo for?
    Looks rather large to be part of a cruise control system, which is about all I can think of.
    But I don't know bikes that well. Or large servos/actuators for that matter, I've only mucked around with dinky RC stuff.
  5. Bastard Child
    Jan 3, 2006
    3,567
    Crooklyn 3012
    Cruise control servo. That tube represents over a year of my life's work :sick:
  6. oculi
    oculi Member
    Aug 18, 2004
    9,000
    can you elaborate on this a bit? i'm using draftsight for my 2D at the moment but it's a bit janky, it's almost like autocad (which is horrible) but slower, considering giving solidedge2D a go.
  7. Bastard Child
    Jan 3, 2006
    3,567
    Crooklyn 3012
    From the hazy depth of my memory (I use solidworks for my stuff, not 'edge)...
    When you FILE > SAVE your work in Windows it just overwrites your existing file.
    What if you want to make a copy with a new name? You would go FILE > SAVE AS > NEWNAME.EXT
    But from what I recall, this is disabled in the free version of 'Edge so you have to manually make duplicates of your work in Windows Explorer.
    If you accidentally overwrite your original template file it's gone for good.
  8. AntikytheraBB
    AntikytheraBB Member
    Oct 12, 2014
    180
    Oakleigh East, 3166
    how much does it cost to get something laser / water cut like bastard child did for his harley bracket a few posts back?
    I have a very basic HDD cage design I made in SketchUp. i plan to make it out of 0.95mm sheet steel. it would be much nicer if i didnt have to hand cut it.
  9. Bastard Child
    Jan 3, 2006
    3,567
    Crooklyn 3012
    You'll find every place has a minimum charge, newtouch laser in Melbourne charges us $80. This seems about the typical amount.
    We typically get $300-$400 worth of stuff at a time. I'll post a pic in a few days when the next delivery comes.
    Also be aware if you get a few things cut of different thickness/material you'll probably get charged a change of sheet fee. Newtouch are about $20-$30 for this.
  10. Bastard Child
    Jan 3, 2006
    3,567
    Crooklyn 3012
  11. arcanic_soul
    arcanic_soul Member
    Jul 2, 2007
    47
    Out of curiosity Bastard Child, do you have a Press Brake at your work or do you get your jobs bent at New Touch with their Trumpf?
  12. Bastard Child
    Jan 3, 2006
    3,567
    Crooklyn 3012
    We have a magnabend™ and some stuff gets bashed with a nylon or ball peen hammer.
  13. Bastard Child
    Jan 3, 2006
    3,567
    Crooklyn 3012
