120fps X-Fire or SLI Battlefield 4 Ultra/1440p experience ???
Discussion in 'Video Cards & Monitors' started by dzajroo, Nov 11, 2013.
  1. P00peyes
    P00peyes Member
    May 30, 2007
    435
    Werribee, Vic
    Unless I missed it in a previous post, you neglected to tell us what GPU's you're using
    edit:
    I see...
    What about without the AA? That seems a lot lower than I would have expected..
    What CPU/chipset you running?
  2. C-BuZz
    C-BuZz Member
    Jan 24, 2002
    5,205
    Melb, East
    CPU is irrelevant, both gpus are @ 100%. To many ppl exaggerate leaving others with unrealistic expectations including yours.
  3. makros2k1
    makros2k1 Member
    Jan 10, 2003
    105
    Rockhampton
    I'm running 780ti's in SLI @ 1600p, in BF4 I'm generally sitting on 100-140fps with everything on ultra.
  4. XaM117
    XaM117 Member
    Jun 12, 2007
    19
    Newcastle
    So 2x 290s would keep this above 50 FPS at 1440p? As soon as I've rid myself of
    the guilt and realise I've had a good year I'm thinking about buying them.
    Thanks,
    Xam
  5. munchkin1
    munchkin1 Member
    Jun 6, 2010
    4,657
    Yeah, I'll believe it when I see it, if it's actually 30% I'll likely sell my 770's and finally cross back to amd...
  6. P00peyes
    P00peyes Member
    May 30, 2007
    435
    Werribee, Vic
    I disagree...
    Ahhh... wtf?
  7. TaroT
    TaroT Member
    Jan 18, 2002
    8,727
    Hazelbrook nsw 2779
    frame:20666
    time(5 mins)300000
    min:29
    max:129
    avg:68.887
    thats all ultra but no AA 2560 1600 at the beggining of tagashar or whatever it is when you need to start off to old town
    lots of rockets and booms and too many deaths
    card was 1150/1400 (tried 1500 for the ram but got my first black screen and on rebbot it screwed up my memory overclock on the main system..so yeah...wierd.
    oh fx8350 @ 4.5
    dzajroo
    dzajroo Member
    Dec 23, 2010
    1,100
    anyone with MP FPS? SP seems to be really hardware hungry compared to MP. For instance I'm getting around 60-70fps in MP but SP it's more like 40-50fps
    damn would be nice to finally see some none-reference cards also some mantle benchmarks AMD please ?
  9. Chardiieee
    Chardiieee Member
    May 19, 2009
    1,019
    Clayfield, Brisbane, QLD
    I plan on getting a single 7970, watercooled and fully overclocked (future plans to have 2 in xfire) and using a Qnix 27" 2560x1440 overclocked to say 90Hz.
    What settings and average framerate could I expect with this in BF4? The second 7970 will definitely help, but that probably wont happen being so close to xmas.
  10. Razorz
    Razorz Member
    May 26, 2013
    536
    Just to put my experience in,
    After an hour of BF4 multiplayer at 2560x1440 with everything set to ultra and 4 times AA and SSAO rather then HBAO, I get 95-100 fps constantly. If I lower any of those settings I get 130 FPS+
    That's all on my 7990 at stock clocks
  11. walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,884
    if you arent running windows 8.1 do that, its like i added another 680!
  12. Foles
    Foles Member
    May 31, 2012
    87
    Darwin
    Yeah much the same on my 2x7950s with a minor o/c. Been turning AA off for 120fps pruposes on the qnix though. On the other hand you can add a fair bit of resolution scaling if you just want 60fps which is pretty handy for a $400 2nd hand gpu set up. What do people think of msaa vs resolution scaling btw? I like it, but my eyes aren't that great and I don't focus on the scenery all that much anyway so I haven't paid much attention to IQ.
    Is that from windows 7 to 8.1 or windows 8 to 8.1? I haven't bothered getting the update to 8.1 cause I think 8 and 8.1 perform the same?
  13. Frag
    Frag Member
    Feb 22, 2002
    5,201
    Brisvegas
    I run CF290X WC'ed setup with 3930k @ 4.5 (4.8 for benching).
    At Ultra settings - campaign as low as 60's as high as 180's.. Sits around 70-90.
    At ultra settings MP in some maps 100-160 (avg 120 odd) others 70-120 (avg 90 odd)
    This is true ULTRA not ULTRA with this and that and this turned down.
    At a custom ultra with 2xMSAA the frames go up to 90-140 (avg 110ish)- even higher sometimes. I am running Cat 13.11.9 Beta 4s which actually seem to score lower in 3dmark by about 6-7% so not sure how that would go with BF4 but they have been 100% stable and not one issue in any game so not changing at this stage until WHQL.
    I personally run at 2xMSAA, no need for anything more at 1080 - so take 20-25% or so off my FPS and you will have approx what you will achieve in 1440p
    I haven't tried to tune the settings in any other way like others here - ie HBAO etc, just dropped down the AA.
    I am convinced you work for Microsoft!
    But when I get my new SSD in the near future I will give win 8.1 a whirl - better be worth the pain! (Thinking on just waiting for 8.2)
  14. walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,884
    haha i was very anti win 8 until program called start8 came along :thumbup: but trust me your minimum fps will be 100 on windows 8
    dzajroo
    dzajroo Member
    Dec 23, 2010
    1,100
    Well at least according to Jurjen Katsman from Nixxes (doing Thief port to PC), 20% performance boost is not unrealistic. Also Johan Andersson, Technical Director DICE announced that Mantle won't be implemented to BF4 earlier than end of December (my bet is Q1-2014). Damn where are all the non-reference models or R9 :confused:
