120MM Diameter Flexible Tube ????
Discussion in 'Modding' started by cruro02, Nov 18, 2002.
  1. cruro02
    cruro02 Member
    139
    Wantirna, Melbourne
    Don't know if this is the right forum, but I figure if anyone is going to know it will be the modders... I have an idea for a mod, but it will need some flexible 120mm (inside diameter) tube to make it work.. Does anyone know where I might be able to lay my hands on such a thing???
    Cheers...
  2. cerberos
    cerberos Member
    1,747
    melboure NE
    would ducted heating duct be what your after, i think it comes as small as 120mm
    cruro02
    cruro02 Member
    139
    Wantirna, Melbourne
    Hadn't thought of that...nice..I'll check it out....
  4. AMD=ViPeR=
    AMD=ViPeR= Member
    Sep 24, 2002
    158
    sydney
    where abouts can u get that stuff???
    jonno
    cruro02
    cruro02 Member
    139
    Wantirna, Melbourne
    Not sure - had ducted heating and cooling installed last year -might have to dig out the invoice and give the block who did the install a call...If I find anything I'll post the details here...
  6. AMD=ViPeR=
    AMD=ViPeR= Member
    Sep 24, 2002
    158
    sydney
    sweet dude!
    jonno
  7. Truncheon
    Truncheon Member
    Jun 26, 2001
    434
    Sydney. AU,
    Bunnings sell it. I was just at my local Bunnings and saw it on a shelf up there. I think it was in the bathroom section for exhaust fans.
    Sorry I didn't check the price I just remember seeing it there.
  8. BasS-InJecTeD
    BasS-InJecTeD Member
    Dec 26, 2001
    1,186
    East Brisbane
    Yeah where do you get that 120mm ducting stuff from? I have tried a few places to no avail
  9. Zzapped
    Zzapped Member
    Jul 8, 2001
    12,352
    Madora Bay
    Also check out stores that sell clothes dryers as some models come with a flexible 120mm pipe to duct the heat out through a window.
    Cheers
    cruro02
    cruro02 Member
    139
    Wantirna, Melbourne
    Ok. Found a couple of manufacturers here in Oz...
    http://www.iplspiratube.com.au/
    http://www.speedlock.com.au/2002/speedflex/speedflex.htm
    Seems that the standard sizes are either 100mm inside diameter or 127mm. For what I am thinking of the 127mm would be the go with one of the extra large hose clamps to bring it down to size at either end....
    Now to find a retail outlet...Truncheon spotted something at Bunnings, so I'll start there...failing that I'll simply call the manufacturers and see what they have to say...
  11. cerberos
    cerberos Member
    1,747
    melboure NE
    i wouldn't bother with hose clamps, just cable ties, much much cheaper
    cruro02
    cruro02 Member
    139
    Wantirna, Melbourne
    Cable ties - hadn't thought of that...Thanks....
  13. Gnuthad
    Gnuthad Member
    Jul 13, 2001
    1,599
    Why not duct tape? The situation might not be good for tape, but if it is, give that a consideration, it may be exactly what's best.
  14. DDsD
    DDsD @DDsD
    8,866
    Well seeing as this is a 'duct' i would have thought that duct tape would be ideal ;)
  15. cerberos
    cerberos Member
    1,747
    melboure NE
    problem with duct tape is likly to be attaching the tape to something :)
  16. Gnuthad
    Gnuthad Member
    Jul 13, 2001
    1,599
    Exactly what I was getting at cereberos, while the duct tape would adhere well to the duct (duh!) there may not be enough of a support for it to adhere to on the other side of the application.
  17. DDsD
    DDsD @DDsD
    8,866
    Perhaps we need some sort of 'fan tape' or 'case tape' for these sorts of situations? ;)
    But from my ghetto modding days, Duct tape has little trouble holding together most PC related things :)
  18. massiveoni
    massiveoni Member
    Apr 29, 2006
    21
    Rockingham, WA
    does anyone know where to find ducting this size that will mount to a 120mm case fan?
    sorry if i hijacked your thread...
  19. da_truest_moo
    da_truest_moo Member
    Feb 10, 2010
    174
    seeing as this thread is about 9 years old its probably not the best pace to look.. but, maybe try bunnings they sell ducting like that there, just not sure if it comes that small.
  20. Dux
    Dux Member
    Dec 20, 2009
    246
