~125V DC Power Supply
Discussion in 'Electronics & Electrics' started by JohnZ, Jun 17, 2010.
  1. JohnZ
    JohnZ Member
    Dec 21, 2007
    373
    RAdelaide
    I'm just about to start putting together a VU meter that outputs to nixie tubes as per this website:
    http://tchips.com/home/index.php?option=com_content&task=view&id=35&Itemid=1
    However, I have no idea how to safely convert say a 12V DC plugpack from Jaycar to ~125V to power the IN-13 nixie tubes that I have...
    I found this spec sheet: http://www.tube-tester.com/sites/nixie/dat_arch/IN-13.pdf
    Which indicates that I need a maximum ~5mA of power per nixie tube (there are 14 all together) which is about 70mA all up.
    Are there any prebuilt units I can buy for a reasonable amount or and PCBs I can get as well as components?
  2. mobs
    mobs Member
    Jul 8, 2009
    137
    back to back transformers.
    ...........AC Plugpack............Reversed Transformer..............Bridge rectfier
    240VAC------------->9VAC----------------------------> ??VAC ----------------->DC
    Plugpack = 240v to 9vac
    transformer = 240v to 24vac (with 9vac from plugpack applied on 24v side)
    rectifier + capacitors on the 240v side of the transformer should get you right around your target voltage.
  3. dohzer
    dohzer Member
    Jan 5, 2002
    5,452
    I'm a little confused by your post, mobs, but doesn't he want 125VDC, not ~12VDC? Or is that what the setup in your post achieves?
    I had a similar question when I needed a +110VDC supply, and people suggested one of the step-down transformers with rectifier and capacitors, etc. That would probably work for you, but obviously you'd need the correct ratio transformer that produces a voltage that is rectified to 125VDC. Not sure if that is "safe" enough for you though.
  4. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    240 VAC --> 9 VAC
    9 VAC --> 90 VAC (with a backwards 10:1 transformer intended as a 240VAC : 24 VAC stepdown transformer)
    After rectification and filtering, you get 127 V DC.
