12V lipo battery charger
Discussion in 'Other Toys/Hobbies' started by raynman, Jun 11, 2013.
  1. raynman
    raynman Member
    Mar 30, 2011
    4
    Could anyone recommend me a cheap 12V LiPo battery charger?
    Doesn't have to be fast, just has to charge the batteries properly. My batteries came with those nasty cheap ones, and after one shorted I want to get a proper one
  2. SLATYE
    SLATYE SLATYE, not SLAYTE
    Nov 11, 2002
    26,857
    A battery charger that charges 12V LiPos, or a battery charger that charges LiPos using a 12V input?
    Either way, the Turnigy Accucel 6 at HobbyKing is a decent bet. Not the best charger around, but it'll charge up to six cells (ie 22.2V) and you can power it either from a 12V car battery or from a laptop-style 12V power supply. The only downside is that the tiny little fan in it can get a bit noisy at times.
  3. Azrael
    Azrael Member
    9,039
    Yeah, i have an Accucel 6, works well.
  4. RAtSAcK
    RAtSAcK Member
    Feb 25, 2007
    2,367
    Bundaberg, QLD
    iMAX B6 and Turnigy MAX80W are also other options.
    iMAX is a very popular beginner charger (have seen a fair few since I started the hobby) and I own 2 of the Turnigy's with no issues (and it'll charge slightly faster too).
    raynman
    raynman Member
    Mar 30, 2011
    4
    Oops - I meant to charge 12V batteries. Preferably to run off the 240V mains
    Thanks for the pointers
  6. RAtSAcK
    RAtSAcK Member
    Feb 25, 2007
    2,367
    Bundaberg, QLD
    Any of them will do that as well, you'll just need a power supply to attach them to.
    I bought some cheap 240W LED power supply of eBay a while ago for like $40 and it's been powering 2x of those Turnigy's that I linked and one iMax B6 just fine.
    Also, generally LiPo's are rated as 3.7V/cell so I'm assuming you have an 11.1V or 3s battery (the "S" stands for series and shows how many are in series).
  7. james150
    james150 Member
    May 14, 2011
    62
    If your still looking, the imax b6 from hobbyking is a good score.
    It charges lithiums, lead acid with various charge modes.
    It runs off 12v, however as a poster above mentioned, a 5A laptop charger works well, or an old ATX psu.
  8. BigandY
    BigandY Member
    Apr 1, 2003
    8,155
    12v lipo? You mean 11.1v 3 cells?
    Also have the Turnigy Accucel 6, great charger :thumbup:
  9. Azrael
    Azrael Member
    9,039
    I assume he means one that charges from 12v. Could be wrong though.
  10. RAtSAcK
    RAtSAcK Member
    Feb 25, 2007
    2,367
    Bundaberg, QLD
    Read the thread, it's clearly stated. Why bother replying if you haven't even read it?
  11. Azrael
    Azrael Member
    9,039
    If you bothered to read I originally responded before he specified his intentions to charge 12v batteries. Regardless, my suggestion does charge 12v SLAs and regulated 12v LiPos.
    Besides this was resolved almost a month ago and then someone dredged it up again.
