12volt to 5volt
Discussion in 'Modding' started by Opti, May 10, 2005.
  1. Opti
    Opti Member
    Jul 25, 2004
    2,080
    MillParkistan
    Isn't there a way to make your 12v case fan 5v, or 7v i think to slow it down, by changing the wires some how? I'm sure i seen it somewhere but dunno where.
  2. aln
    aln Member
    Dec 1, 2004
    397
    Melbourne, Australia
    Opti
    Opti Member
    Jul 25, 2004
    2,080
    MillParkistan
  4. hendot
    hendot Member
    1,277
    you can do it without cutting or soldering wires. Just de-pin a molex connector (even just the red and yellow pins) and switch red and yellow. Seeing as you are only doing 2 pins, it isn't too tedious to just use a needle to do this.
  5. aln
    aln Member
    Dec 1, 2004
    397
    yea...you can...but i don't have anything to depin them...and don't know how...
    you can also make a 7v mod by crossing one of the black wires with the red
  6. dakiller
    7,978
    Gippsland
    after connecting 5->12 it's probably better to not connect the 12 to the 5 and only have 1 ground wire as well, so its sort of a visual reminder that its for fans only as if you mistake it for a normal one and connect to something you shouldnt Bad Things will happen
    Opti
    Opti Member
    Jul 25, 2004
    2,080
    MillParkistan
    what is the fan has only one red wire and one black wire? Can't do it? Also if your running two fans together and they are wired together, they will still be running at 12volt yeah?
  8. petercr
    petercr Member
    Jan 4, 2002
    4,333
    Northern Brisvegas (4504)
    If the fan only has two wires, it will still work. The red is +ve and the black is -ve (or ground). The third wire (usually yellow) is used for the speed sensor and is generally left connected directly as it goes back to the motherboard header and in theory this is the only wire that needs to be connectored for the speed to be measured. As to the two fans, it depends on how they're wired up - if they're in series (ie black wire of one is connected to the red wire of the next) then you need 2x the rated voltage of the fans to drive them at their rated output. If they're in parallel (red to red and black to black) then you'll need to supply the combined current rating of the two fans.
  9. phathag
    phathag Member
    Sep 14, 2002
    811
    this site is what i am about to use to de-volt my loud case fans...
    http://www.7volts.com/
    i believe most of the time people would go to 7volts from 12v as 5v sometimes is not enough to start the fan... so ive read.
  10. Kenny12
    Kenny12 Member
    Aug 1, 2002
    2,801
    just use a little screw driver / toothpick to depin them easy as
    Opti
    Opti Member
    Jul 25, 2004
    2,080
    MillParkistan
    to depin the male connectors just get some 5/32" od nylon air hose, you get it from a truck parts place, it fits over the male pin and you can push the tabs in. You only need about 3inchs of the stuff.
  12. SteakTheMooCow
    SteakTheMooCow (Taking a Break)
    Apr 26, 2005
    3,069
    Ok, what everyone has NEGLECTED to mention is this:
    You need to find the bits that stick out (usually 2 of them). Depress that with a small object (eg. precision screwdriver). Once you've done this the pin usually falls out of place. Then just bend them back up (GENTLY!) and stick them back where you want them.
  13. Lucanus
    Lucanus Member
    May 30, 2003
    73
    As someone said earlier - Be careful not to connect anything other than fans after the converter. I'm ashamed to say it, but I once blew up a brand spanking new (and at the time *very* expensive) 18.2gig Quantum Atlas 10K U160 SCSI disk that way. :o
  14. SteakTheMooCow
    Apr 26, 2005
    3,069
    If the fan has a 4 pin running through it F-> just swap the pins again and you can plug anything in... just remember to fix it up :)
    Oh, and make sure you change it on the MALE side, otherwise you'll still have a damn fast fan =\
  15. montyt
    montyt Member
    Aug 13, 2002
    275
    melbourne
    i find that it is safer to modify the connector on the fanso that way you dont blow anthing up, and you are only modifying the fan voltage and not anything after the fan.
    please be aware that not all fans will run at 5 volts.
    some will not have enough power to start.
    i run my fans at 7 wolt.
    keep + wire connected to yellow (12 volt)
    and disconnect the black wire (ground wire) and connect the ground wire to red wire (5 volts)
  16. SteakTheMooCow
    Apr 26, 2005
    3,069
    ok, heres how to do it CHEAPLY WITHOUT blowing anything up.
    note: green replaced yellow for clarity.
    Molex 1 (on the left) you leave alone. (assume it comes from the PSU)
    Molex 2 (the fan molex): you swap the yellow (in the diagram in green) with the black cable which is under the red.
    Molex 3 (the other fan molex): you swap the yellow with the black again.
    I've done it, it works... :: shrugs :: no cutting, just pop out the molex with a precision screw driver, needle or something else tiny.
  17. metamorphosis
    metamorphosis Member
    Feb 25, 2002
    1,915
    Works fine for my 12" evercool but yeah some fans don't cut it, in that regard-
  18. Sephir0th
    Sephir0th Member
    Aug 12, 2002
    2,352
    or, rather than change two lots of wiring, all i did was get one of the 3-4pin fan adapters, get a knife and expose some of the red 5v wire, cut the black wire that goes from the molex to the fan header away from the black molex wire and solder it onto the red 5v wire, then put electrical tape over the exposed wires, easy.
    and also your diagram is very wrong, you say green=yellow in the picture, you have red (5v) going to the fan +, and green(yellow=12v) to the fan - which would give -5v to the fan. Just thought i'd clear that up
  19. jrun4117
    jrun4117 Member
    Nov 1, 2003
    185
    Sydney, NSW
    Does having the fan connecting across 12V and 5V mean that the PSU has less control over voltage levels because a sudden current draw (surge) on the 12V or 5V can now affect both rails?
  20. SteakTheMooCow
    Apr 26, 2005
    3,069
    ah true seph...
    red = yellow
    green = red :p
    edit: but I have a 5V fan?
