2 Home wireless modems to single router
Discussion in 'Networking, Telephony & Internet' started by Nateid03, Feb 10, 2019.
  1. Nateid03
    Nateid03 Member
    Nov 4, 2010
    90
    hey ocau,
    had a bit of a brain wave and wanted to see if anyone has done something along these lines before.
    Long story short - we're on the optus mobile broadband network for internet at home: reasonable service but can be slow/patchy.
    was doing some reading with multiple internet connections to a single router - has anyone done this and is it worth doing: specifically with the mobile network
    I can setup the datashare between the 2 sims in the routers easily enough - it's more whether it's worth pursuing.
    Cheers
    Nath
  2. Copie
    Copie Member
    Jul 24, 2009
    13,741
    Newcastle
    There is a write up about adding antennas to improve speed floating around
    Nateid03
    Nateid03 Member
    Nov 4, 2010
    90
    Already did that - signal is good just want more speed. Gotta go fast
  4. Pugs
    Pugs Member
    Jan 20, 2008
    9,258
    Redwood Park, SA
    When and what type of nbn will you be getting??
    Nateid03
    Nateid03 Member
    Nov 4, 2010
    90
    Not getting NBN any time soon - need to stay on the Mobile broadband network for another 2 years
  6. hairy
    hairy Member
    Dec 11, 2010
    606
    im keen to see if anyone has any suggestions also.
  7. s4mmy
    s4mmy Member
    May 20, 2004
    2,183
  8. hairy
    hairy Member
    Dec 11, 2010
    606
  9. Draxx
    Draxx Member
    1,014
    Bendigo
  10. Mace
    Mace Member
    Aug 16, 2001
    485
    I tried Draytek (Vigor maybe?) a while back to load balance ADSL 1 and 3G. It worked OK but my 3G signal wasn't great so I abandoned it. From memory it wasn't too hard to configure.
  11. TehCamel
    TehCamel Member
    Oct 8, 2006
    4,183
    Realistically, all you're going to acheive is concurrency or load balancing, rather than improved speed flat out.
    By which I mean, if you have 2x 4G signals sycning at let's say 50M/sec each - it gives you aggregate speed of 100M/sec
    But you won't get 100M/sec on one single computer with a single download stream.
  12. Mace
    Mace Member
    Aug 16, 2001
    485
    Exactly right. The only way to get the full speed on one stream is to go through an aggregating company, two accounts, they split your connection across the two accounts and its reassembled at your end. Crazy expensive.
    2 x 50M is pretty good though. :)
    timace likes this.
    Nateid03
    Nateid03 Member
    Nov 4, 2010
    90
    perhaps with a standard ADSL/NBN connection however since this is using the 4g network the splitting could be achieved through the use of 2 sim cards in 2 modems, then using the same data from a data pool rather than having 2 accounts: effectively having "2" connections - that's the way I understand it anyway: happy to be proved wrong here.
    had a read through the thread - killer setup however being in a rental it's going to be hard erecting an antenna without the landlord getting the stinks up.
    main aim is to get some reliability without having to reset the router most evenings due to lack/slow signal. might need to do some more reading on this one
  14. Mace
    Mace Member
    Aug 16, 2001
    485
    Ooh. I hadn't considered that. One pool of data though, might not be one connection, ie. packets from one source being routed across two paths.
    No harm in trying though to confirm either way. ;)
  15. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,288
    This isn't going to work the way you think it'll work. I swear this question gets asked every few months.
    To load balance you need control over both the source and the destination and that doesn't happen on the internet. Best case you can send traffic for one application through one SIM and other traffic through the second, however even that gets tricky since most content on the internet uses CDNs these days and hardware that can correctly identify application traffic isn't cheap.
  16. MELso76
    MELso76 Member
    Jan 6, 2003
    147
    Just to clarify, you're using the old speed-limited Optus Home Wireless Broadband product?
    Have you thought about switching to the new uncapped Optus Wireless Broadband product, getting a high CAT modem like an AC800S and tethering that to a router?
    Nateid03
    Nateid03 Member
    Nov 4, 2010
    90
    I did switch late last year to the uncapped version - that was a huge help but still requires resetting the modem regularly to keep speeds up
  18. MELso76
    MELso76 Member
    Jan 6, 2003
    147
    Sounds like higher frequency signals may be marginal where the modem is placed.
    Which modem are you rocking and are you using any external antennas?
    And where's your nearest Optus tower, and what bands does it have?
