2014 releases: Haswell, Haswell Refresh, Broadwell, etc.
Discussion in 'Intel x86 CPUs and chipsets' started by stmok, Oct 22, 2013.
  1. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    A 500 dollar dent in the wallet unfortunately. I'm awaiting benchmarks eagerly too
  2. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
  3. newlife
    newlife Member
    Oct 20, 2012
    2,153
    Adelaide, SA
    For Broadwell at least Intel seem focused on low power usage and igpu not high clocks or anything but that's where skylake comes in
  4. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    I remain optimistic as always. 65w part to match the predecessor maybe & lower frequency.
  5. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    Time for some 48's while I have a nice warm ambient 7deg :D
  6. dinos22
    dinos22 Member
    May 8, 2004
    12,332
    nice overclock there :D
  7. Silenius
    Silenius Member
    May 25, 2002
    823
    So, any consensus yet on whether Broadwell will have the advantage when overclocking?
    I'm so split on whether to get some 2nd hand 2600k or whatever and wait for Broadwell, or just get a 4790k.
  8. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    We'll only be guessing till real benchmarks are done.
    I'd jump on a 4790K, going 350 in the forum atm.
  9. sanjeevlives
    sanjeevlives Member
    Feb 6, 2004
    2,883
    id 2nd hand the 2600k until skylake comes round
  10. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    15deg ambient + HT is just too much for this pressure cooker :p
  11. sskmercer
    sskmercer Member
    May 5, 2003
    3,103
    Brisbane, Sth Side
    Am I reading that right Shane it's still hitting 90c on a core and that's with out hyper threads based on CPUz. Dam that is a hot mofo. What program is that your cooking with?
  12. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    You can add another 10deg :Paranoid: with HT Scottie + another maybe 0.02v
    Running 1500rpm on the pump & two decent 360rads < no gpu in loop >
    Koolance 370 block
    Think myself lucky :), Headin's is apparently far worse / why he delid
    LinX 0.64 very mild runs / can go much harder with prime 95 etc
  13. newlife
    newlife Member
    Oct 20, 2012
    2,153
    Adelaide, SA
    that's shocking given my old 4770k could take 1.45v and max around 90c with a h100
  14. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    Yes hot fukka. Need test another block for it. :D
  15. ska'
    ska' Member
    Dec 25, 2011
    1,748
    Setup in sig.
    4690k @ 4.5ghz, 1.1v prime 95 stable, temps max out ~62c on a 240mm AIO.
  16. shane41
    shane41 Member
    Nov 10, 2008
    6,842
    dice que no sabe
    Hmm...........needs another digit :p Big range between 1.1V & 1.199V
  17. ska'
    ska' Member
    Dec 25, 2011
    1,748
    1.100V :)
    During normal usage (Gaming etc) temps top out at low 50's.
  18. sanjeevlives
    sanjeevlives Member
    Feb 6, 2004
    2,883
    whats the cache run at? does everyone just leave cache as is?
    i always try to run 1:1
  19. Alchemist
    Alchemist Member
    1,658
    Hopefully this is the right thread, has there been a release date for the Broadwell chips yet? (5XXX series)
    I am still seeing all Aust stores stocking 4xxx and a few random images of the 5's for sale in JP but I cannot find a release date for it in Aust :confused:
    I am about to buy a new system so was thinking if it was only another few weeks to wait for a newer series chipset.
  20. Omarko
    Omarko Member
    Nov 25, 2004
    4,189
    Kellyville
    hi guys, I have been completely out of overclocking since my 2600k.
    I have Asus Z87 Pro mobo and i5 4670k CPU that I would like to overclock. CPU is under water.
    whats the best way to go about it ? is it as easy as the 2600k was ?
    what parameters should I adjust and what should I aim for if I want a decent but not too crazy overclock that can run stable for hours.
    cheers
