2080 Ti Sea Hawk X temps
Discussion in 'Video Cards & Monitors' started by shadow85, Jan 24, 2019.
  1. shadow85
    shadow85 Member
    Sep 8, 2008
    244
    Holden Hill, SA
    Any MSI RTX 2080 Ti Sea Hawk X owners on here?
    Please tell me your temps. My GPU is easily sky rocketing towards 70°C in no time.
    I have tried various configurations of rad/fan placement and tried difference locations inside the case. Always the same result.
    I have 2000-2100 MHz running through it.
    What are other Sea Hawk X owners temps, please let me know? Thnx.
  2. havabeer
    havabeer Member
    Dec 12, 2010
    4,322
    Maybe pm Scum on these forums pretty sure he has a 2080ti sea hawk at the moment.
    What happens if you knock the OC down?
    shadow85 likes this.
    shadow85
    shadow85 Member
    Sep 8, 2008
    244
    Holden Hill, SA
    Thank you for the referal, will PM him.
    Good question though, I havent tried to knock the OC down. Might have to test that situation out later.
  4. Scum
    Scum Member
    Sep 1, 2001
    533
    6054 WA
    My Seahawk runs @
    gaming 2100mhz - temp around 45c
    ocing 2115mhz - temp low 60c under full load
  5. DarkStyle
    DarkStyle Member
    Jun 24, 2002
    1,585
    Based on Scum's temps, sounds like your card isn't properly pasted :)
    shadow85
    shadow85 Member
    Sep 8, 2008
    244
    Holden Hill, SA
    Thanks scum.
    Yeah looks like bad news for me. Might have to RMA it. Dammit, 4-6 week turn around time ;(
  7. Scum
    Scum Member
    Sep 1, 2001
    533
    6054 WA
    shadow85
    shadow85 Member
    Sep 8, 2008
    244
    Holden Hill, SA
    Oh I guess that sort of setup has netted you a decent few °C cooler temps?
    My setup is inside a massive 900D case.
  9. havabeer
    havabeer Member
    Dec 12, 2010
    4,322
    depending on your airflow setup you'd still assume a 50 - 60 degree temp, how ever a massive overclock maybe why your temps are rather high, its only a 120 rad afterall
  10. Sledge
    Sledge Member
    Aug 22, 2002
    7,458
    yeah i don't think high temps while OCing is an acceptable reason to RMA.....
  11. AlliZ
    AlliZ Member
    Aug 15, 2017
    166
    Ask Google
    its worth a shot though, CJ got a replacement chip when he failed to delid the first with an ice pick
    shadow85
    shadow85 Member
    Sep 8, 2008
    244
    Holden Hill, SA
    Well I agree with your point a little bit. It's just that, before this GPU I had a GTX 1080 Ti ROG STRIX OC with an another added +75 MHz ontop which gave me about ~2050 MHz. That card only saw a max temp of 65°C with automatic/default fan profile (65% fan max), inside my case with the exact same setup, and that is an air cooled card.
    I bought the Sea Hawk X hoping that I will see much lower temps. But this card shoots 70°C within minutes on a manual 85% fan profile! Makes me feel like there is something wrong, I am very dissapointed and totally wish I stuck with the ROG STRIX version, that is a solid card compared to this crappy MSi card
  13. Sledge
    Sledge Member
    Aug 22, 2002
    7,458
    Don't mention overclocking to them though
    Just say it seems to be running too hot for a liquid cooled card...
  14. d3vour3r
    d3vour3r Member
    Jul 27, 2012
    254
    take the heatsink off and re paste it with some good paste. if that doesnt fix it then you might have a crap binned chip and could possibly have grounds to RMA.
  15. super kermit
    super kermit Member
    Jun 18, 2002
    1,069
    Sydney Pyrmont
    I am going two 2080tis in a 900D. Can you PM me and we can chat. :)
    I had 1080ti in SLI before and it was always cold in the case
  16. C-BuZz
    C-BuZz Member
    Jan 24, 2002
    5,112
    Melb, East
    Since when is 70c hot for ann overclocked gpu? Is that a joke? No way your getting an rma on a product working as intended.
    They make no temperature guarantees.
  17. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,141
    70C is probably about right. Can't expect much from a tiny 120mm rad and inbuilt pump. Rad only looks to be about 30mm thick so there isn't much surface area to dump all that heat.
    Have you tried a better fan on the rad? Something with high static pressure could possibly net you a few degrees considering the stock one looks to be utter crap.
    You can't compare Scums temps to your own as he is using the actual MSI/EK full coverage block, not the all in one hybrid X version that you have which combines air and water. HUGE difference.
    This is what Scum is running by the looks of it:
  18. C-BuZz
    C-BuZz Member
    Jan 24, 2002
    5,112
    Melb, East
    Scum is also using an open case & he is also a pro overclocker & cannot be compared.
    Temps vary massively on many different factors. 70c is nothing to worry about. Carry on.
  19. dr_deathy
    dr_deathy Member
    Apr 27, 2007
    2,559
    Yeah a single 120mm rad can cool a GPU fine but dont the expect temps of a bigger water cooling system. I would say 70c isn't to bad really.
    I like to have a 360mm rad per device if you want it to be silent and cool.
    shadow85
    shadow85 Member
    Sep 8, 2008
    244
    Holden Hill, SA
    Why is everyone saying 70°C is not too bad for an OCd card. I know that is not bad, and is totally acceptable!
    But all those guys are failing to see my point, why pay the premium for a watercooled card when it cools worse than an air cooled card!
    Thats what I was getting at
