2080 with water block
Discussion in 'Video Cards & Monitors' started by thedirkdiggler, Feb 5, 2019.
  1. thedirkdiggler
    thedirkdiggler Member
    May 19, 2006
    361
    My older r9 amd watercooled card is dead.
    I was looking at a 2060 or 2070 card. But I want it under water too. I am looking but, do not see anything . Is it too early or they just not going to make a block for a mid range card.
    The only ones I see is a 2080 for around 1500. But I don't really want to spend that much.
    I also need a new monitor too.
    I was looking at
    ASUS ROG Strix XG32VQ QHD 144Hz FreeSync 32in VA Gaming Monitor
    https://www.pccasegear.com/products...2vq-qhd-144hz-freesync-32in-va-gaming-monitor
    too go with it.
    What do you all think. Computer is for 95 per cent gaming. cpu 7700k on water and overclocked.
  2. havabeer
    havabeer Member
    Dec 12, 2010
    4,489
    2nd hand 1080ti with a block?
  3. Ratzz
    Ratzz Member
    Mar 13, 2013
    7,872
    Cheltenham East 3192
    Yeah they don't usually make blocks for 'mid range' cards, even when they are better than the previous 'high end' cards. Your options are pretty much a 1080Ti with a block, or a universal/hybrid setup on a 2060 or 2070 if you don't wanna spring for a high end RTX.
    thedirkdiggler
    May 19, 2006
    361
  5. glnn_23
    glnn_23 Member
    Jan 19, 2012
    421
    thedirkdiggler likes this.
    thedirkdiggler
    May 19, 2006
    361
    thanks for that, I forgot about them. Was looking at ek only
