240v LED ?
Discussion in 'Electronics & Electrics' started by aussie-revhead, Sep 2, 2006.
  1. aussie-revhead
    aussie-revhead Member
    Feb 21, 2005
    19,438
    St Clair 2759
    Hi guys , I am wiring a relay in my water cooled case to allow my psu to turn on the 240v water pump automatically , but I want some kind of confirmation that the pump is activated . What can I mount in the front of my case , like a blue LED , that will illuminate when my pump is operating ? I went to DSE and they said they have never seen a 240v LED , and couldnt tell me what resistor to use to step 240 down to allow use of a 12v LED .
    Can one of you modding guys help me with this ? What do I need to do to set this up ?
    Any help would be great .
    :thumbup:
    PS I dont want it to light up half the room like a blue spotlight either , just a gentle light .
  2. -KoMoD0-
    -KoMoD0- Member
    Dec 26, 2005
    9,033
    Western Sydney
    no, you cant get a 240v AC led.
    You need a DC source and most led's are roughly 3v
    aussie-revhead
    Feb 21, 2005
    19,438
    St Clair 2759
    OK , then what do you suggest I use ? OK so LED wont work with AC , what about a normal globe in a bezel ? Have you seen anything like this ?
    :thumbup:
  4. dakiller
    8,069
    3844
    Something like this would run a LED off 240vAC
  5. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    Just use a neon indicator lamp which is designed for 240VAC use.
    For example, Jaycar SL2633
  6. Odje
    Odje Member
    2,296
    If you use dakiller's circuit make sure the capacitor is rated for 240V AC. The resister will be need to be rated to handle the power dissipated too.
    aussie-revhead
    Feb 21, 2005
    19,438
    St Clair 2759
    Goths idea is good , thanks man .
    :thumbup:
  8. Odje
    Odje Member
    2,296
    Too tired to do the maths to work out values, so after a few minutes of googling I found some pages of use.
    General info and theory for LED of mains with capacitor:
    http://www.marcspages.co.uk/tech/6103.htm
    And I found a little application that will do the calculations for all different types of configurations, including AC with resistor, capacitor and dioide or bridge.
    http://www.miscel.dk/MiscEl/miscelLeds.html
    EDIT: that app mentioned above looks very handy, just downloaded it. It does alot more than just calculate LED circuit, does all sorts of things.
  9. mAJORD
    mAJORD Member
    Jun 4, 2002
    10,675
    Griffin , Brisbane
    love the mspaint schematic dak :D
    neon is probably the simplest and best Idea
    remeber you still need a resistor if you don't buy it in a premade 'lamp' , (i.e you just buy the neon globe with flying leads).
  10. GOATMAN!!!
    GOATMAN!!! Member
    Apr 10, 2005
    677
    Iowa, USA
    Be carefull with this dude.
    Anyway, we use plenty of extension leads at work with LEDs in them to tell you if they have power. They just have a resistor in line with the led across the active and neutral. Not sure on the value of the resistor. I could check at work tomorrow if you want.
    aussie-revhead
    Feb 21, 2005
    19,438
    St Clair 2759
    Im not really keen on touching the 240 at all , hence the questions , but I am waiting for a certain electrician to turn up at work and I will quiz him about it all .
    :thumbup:
  12. dirtyd
    dirtyd Member
    Jan 4, 2006
    4,032
    Melbs
    Bit of a thread revival, thanks to Odje's links I was able to replace the little incandescent globe in a 4 socket power board, just had to get a high voltage cap from Jaycar for $2. Winner :thumbup:
  13. Odje
    Odje Member
    2,296
    Power boards have incandescent globes?
    Make sure you include a bleeding resistor across the capaictor to discharge the capacitor. Otherwise you might get a bit of a zap if you happened to unplug it and touch the pins on the mains plug.
  14. dirtyd
    dirtyd Member
    Jan 4, 2006
    4,032
    Melbs
    This one had a tiny little one, the board is a bit of a relic that was found in the depths of a relatives house. I intended to include a bleeding resistor and then forgot all about it when I was soldering everything together :Paranoid: Hopefully won't be touching it for a long time anyway.
