3.5mm jack tip snapped in port
Discussion in 'Troubleshooting Help' started by Darkness Born, Nov 8, 2011.
  1. Darkness Born
    Darkness Born Member
    Feb 25, 2011
    740
    Melbourne 3004
    Is on my phone, but hey much of a muchness really...
    Any ideas? Tried supergluieng the other bit to it, wont stick....
  2. looktall
    Sep 17, 2001
    26,669
    what phone is it?
    can you get to the headphone jack by pulling the phone apart?
  3. bungs
    bungs Member
    Oct 14, 2004
    128
    drill it out
  4. tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,442
    magnet? tho I don't know how the rest of the phone will take it
    super-glue? naaa.. then again.. the *tiniest drop, slow pull.. *might do it..
    there was a bloke who had the same thing happen on his sound card couple months back.. can't quite remember how he got it out :(
  5. Ethan W
    Ethan W Member
    Jan 13, 2011
    1,753
    NSW, 2155
    At the very least, I'd turn it off if you try that. I must confess, it was my first thought. That would only work if the plug has broken off right at the edge and you can contact it.
    Otherwise, try this: http://www.youtube.com/watch?v=er_dTMlQ--E&feature=related
  6. EC MEISTER
    EC MEISTER Member
    Aug 15, 2007
    1,759
    Ivalice
    +1 especially if you can get a small enough drill bit to make a hole in it and then place a dab of superglue in it, stick a paperclip or thin wire into it, leave it for 2 minutes then pull it out.
  7. looktall
    Sep 17, 2001
    26,669
    or if you got a strong magnet. say that from a hard drive.
    and poked something thin enough and long enough to reach the snapped off plug. say a straightened paper clip.
    hold the magnet against the paper clip and you might be able to pull the snapped off plug out.
    Darkness Born
    Feb 25, 2011
    740
    Melbourne 3004
    no magnet would ever be strong enough for this, as the piece is 'locked' in (it is the part that sort of clips in when you plug in headphoes)
    So have superglued it in now, woot.... luckily I can get a micro usb > 3.5mm converter for it.
    Thanks guys
  9. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    You still may be able to drill it out if you have a small drill bit, I'd recommend using a drill press to make sure its straight and doesn't damage the phone!
    Edit: maybe try dripping some acetone or something in it to release the super glue then drill a hole and stick a paperclip soaked in super glue in the hole.
