30 Pin Ribbon Cable
Discussion in 'Electronics & Electrics' started by silenthunter, Nov 12, 2006.
  1. silenthunter
    silenthunter Member
    Aug 29, 2002
    2,634
    Amsterdam, Netherlands
    Does anyone know where to get 30 Pin (2x15) ribbon cable or headers.
    I've got a component hifi system i got for free that uses it but it didn't come with the 30 pin cable to join the components.
    Anyone seen it? Can't find it on the DSE/Jaycar websites...:(
  2. jomo
    jomo Member
    Oct 13, 2004
    188
    2800
    1.
    2.
    3.
  3. nux
    nux Member
    Jan 20, 2002
    16,780
    You can cut down a larger ribbon cable to 30.
    You can use larger headers too as long as there is enough room either side and you hook them up right.
    Otherwise, try the usuals like Farnell, RS, Futurlec, Digikey, Mouser,...
    silenthunter
    silenthunter Member
    Aug 29, 2002
    2,634
    lol thanks for that pictorial representation yeah i hacked up some 40 piners but its pretty dodgy and keeps cutting out and not turning back on! have probably fried the thing (it sends the power for the DVD/CD player via the ribbon cable from the amp)
  5. LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,760
    Cambridge, Massachusetts
    BWAHAHAHAHA :lol:
