32bit vs 64bit
Discussion in 'Windows Operating Systems' started by neomatt, Jul 17, 2008.
  1. neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    Exactly what are the advantages of 64bit over 32bit? Will it make much difference when gaming?
    Gaming is really the only reason I'd use a 64bit operating system if it made a big difference in gaming...
    What about overall performance on 64bit? Will things run noticeably faster?
    I'm trying to decide if I should stick with my 32bit XP Pro until I can afford to fork out money for Vista Ultimate... Or just stick with XP Pro...
    Speaking of which...
    How big are the differences between Ultimate and Home Premium?
    Is there an in-between version between home premium and Vista that is better than Home Premium but not as good as Ultimate?
  2. DeejW
    DeejW Member
    May 18, 2008
    1,950
    Margaret River WA
    There is very little difference between home prmium and ultimate. The only differences are the native backup software, remote access and a few other minor things.
  3. jmart38
    jmart38 (Banned or Deleted)
    Jun 2, 2007
    6,912
    ಠ_ಠ Brisbane
    home premium is probably a better choice, cheaper - don't really 'need' the extras ultimate has to 'offer'.
    neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    Okay but what about the advantages of 64bit Windows over 32bit?
  5. stoopidwog
    stoopidwog Member
    Feb 16, 2005
    79
    32bit can only address up 2 3-3.5gb of ram
    64bit can address 4gb+
    theres prob other things but that seems to be the main one
  6. Flux
    Flux Member
    Jul 4, 2007
    1,511
    Using vista home premium x64 and do a lot of gaming.
    Steam works perfectly, the only thing I've ever had go wrong which was more common in 64-bit pc's was punkbuster having a hissy fit once in a while, but that's an easy fix.
    Are you building a new system, if not make sure all your hardware is supported in 64-bit.
    neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    New system, q6600, 4850, etc...
    I doubt I'll be using punkbuster anyway. It's not a requirement to play a game, just an optional background program.
    neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    Also, I've heard bad things about people having trouble updating to SP1 through Windows Update on Vista... Is that still a problem? Can I just buy Home Premium without sp1 and still be able to upgrade?
  9. Elyzion
    Elyzion Member
    Oct 27, 2004
    7,198
    Singapore
    Sigh, 3 out of 100,000 people have a problem, they post on the net and all of a sudden its assumed its everyone having the problem.
  10. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    148,237
    Omicron Persei 8
    Currently not a great deal at all other than addressing the memory issue, if you can call really it an issue.
  11. kreegor
    kreegor Member
    Apr 24, 2007
    4,987
    If you buy Vista now it will have SP1 included on the disc. It is quicker and much much simpler to install with SP1 then to upgrade to SP1 later on. That can take around 45mins to an hour (in my experience anyway).
    I have never had an issue with SP1, in fact found Vista a whole lot better with SP1.
    Apart from detecting more memory there is no real advantage of 64bit over 32bit. That being said, there is quite a big difference between 2gig and 4gig of ram in gaming so for me 64bit is definitly worth it.
  12. Tartarus
    Tartarus Member
    Mar 19, 2008
    190
    Canbra
    32-bit operating systems can only index a total of 4GB of RAM. This includes both system memory and graphics card memory, along with a few little things some sound cards or network cards might have. Basically what this means is if you have, for example, a 1GB video card, you will only be able to address 3GB of system memory. With the price of DDR2 these days, and the proof that 4GB of ram outperforms 2GB, any serious new system builder would be wise to invest in 4GB.
    I have used 64-bit Vista Home Premium since the week it came out, on two computers, and have never had a problem I would not experience on a 32-bit OS, except that older 16-bit games won't run without an emulator. (Which is easy to solve) More than anything, 64-bit is undeniably future proof. 32-bit is not.
    Ultimate is a ridiculous waste of money for anyone who doesn't know without a doubt they require the extra features.
  13. foxmulder881
    foxmulder881 Member
    Nov 17, 2004
    5,884
    Gold Coast, QLD OS:Linux
    I installed 32bit Vista because I run 64bit linux. I like to have a combination of the two. Not that it makes much of a difference on my low-specced system anyway. :lol:
    And I installed Vista Ultimate because the option was there for me. But as others have said, Home premium is sufficient for most users.
    There's a good comparison chart on Microsoft.com that lists the different features between Vista versions.
    http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
    neomatt
    neomatt Member
    Mar 28, 2006
    272
    WA
    http://www.ccpu.com.au/show_cat.php?cat_id=software
    This doesn't say it comes with sp1... A lot of other PC sites specifically state it comes with it... Maybe this is an old version? Either way, Elyzion seems to think I won't have a problem, so I'll probably buy it with or without...
  15. foxmulder881
    foxmulder881 Member
    Nov 17, 2004
    5,884
    Any retailer selling Vista should include the SP1 update pre-installed. If it doesn't contain SP1, it's simply old stock. Not that it matters. If it's not included, just install it afterwards.
  16. Flux
    Flux Member
    Jul 4, 2007
    1,511
    Both my partner and I had no issues whatsoever installing service pack 1.
  17. Kabal
    Kabal Member
    Aug 1, 2001
    1,045
    Remote desktop is the only worthwhile part of ultimate over premium IMO. Even then you can get around it by using VNC.
  18. kreegor
    kreegor Member
    Apr 24, 2007
    4,987
    Or by getting Business edition. I bought business because it had remote desktop and Ultimate had too much crap I didn't need. The only thing about business is that there is no media centre..... but that is what my mythbox is for :)
  19. foxmulder881
    foxmulder881 Member
    Nov 17, 2004
    5,884
    This is a good thing. I never liked or used Media Center anyway!
  20. kreegor
    kreegor Member
    Apr 24, 2007
    4,987
    Yeah I'm the same. Windows media player is all I need for music and videos :)
