3D Printer General Chat
Discussion in 'Hobby Engineering' started by Spanos, May 26, 2021.
  1. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,668
    Perth , St James
    Most RGB strips are 10mm wide, they will fit in the Rails, just has to be fed from one end. If its more than 10mm then its a no go.
    It could be a few things but I think heat is one for sure. I had that issue when I started with ABS, everyone said high temps and no cooling, turned out that I needed cooling . Also if you missed a layer it was most likely a small jam caused by heat creep.
    I would try a lower temp, maybe 180C as a base.
    Then maybe check the part cooling fan and set higher.
  2. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,668
    Perth , St James
    I am thinking of getting rails for mine in the 11:11 sale and was torn between "Hiwin" or generics from Aliexpress.
    Those generics going OK for you? Smooth and rigid?
  3. tumutbound
    tumutbound Member
    Aug 30, 2008
    556
    Geeveston, Tasmania
    They are good. They did need a serious clean before use, lots of dirt and swarf in them. Smooth and tight still after 12 months moderate usage.
    I use a light oil instead of grease so need to re-oil more often than you would with grease.
    I bought the same style rails for my new Hevort build. Not sure if there is a lot of difference between suppliers but I got mine from CNA Mechanical Parts along with the ballscrews for the Hevort.
    Very quick delivery via courier - about 2 weeks.
  4. brayway
    brayway Member
    Nov 29, 2008
    6,965
    New Zealand
    Oh sweet! I don't know why I didn't think of that, test fitted, and yup, they'll fit in there.
    Might have to take the top off and slot it in for now, then when I get another dremel (Mine died :( ) I'll do the full 'U'.
    I think the missed layer is from the slicer, reprinted and it did the exact same thing, will have to try re-slicing it.
    Just doing another temp tower now with lower tempts, starting at 180, and going up in 5*c increments. Will see how that goes.
  5. brayway
    brayway Member
    Nov 29, 2008
    6,965
    New Zealand
    Okay so I 'gave in', and pulled the machine down a bit.
    I had suspicions that the fans weren't running at full speed, sometimes they'd struggle to start etc, and if I moved the step down units, the fans would stop spinning altogether.
    So I removed the connectors I put on, and removed the wires I'd soldered on, and fixed that all up.
    Bought a hot glue gun and glued the PCBs to the cases, and the cases to the bottom of the printer.
    Also realised that the lead screw for the 2nd Z Stepper wasn't seated right in the coupler. The coupler had dropped down and the screw wasn't even touching the grub screw. That was also probably one of my main issues.
    Put it back together and so far it's printing much better, will need to recalibrate almost everything now.
    tumutbound likes this.
  6. brayway
    brayway Member
    Nov 29, 2008
    6,965
    New Zealand
    Getting pretty dialed in now, started printing out this enclosure, and the first piece has come out really nice in comparison to any previous print of mine.
    Really happy with how it's turning out! Second half printing now.
  7. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,668
    Perth , St James
    Looks miles better, that Blue print was pretty bad.
    Just hit that print with a hot air gun to get rid of the wisps and you are good. Maybe also add abit of Z hop as there are a few drag lines on that top surface and maybe try that new Cura feature (Monotonic something something) to even out the top a bit.
  8. Dilbery
    Dilbery Member
    Nov 19, 2005
    1,398
    Sydney, NSW
  9. apsilon
    apsilon Member
    Feb 2, 2003
    6,766
    Sydney Australia
    Definitely want but my wallet doesn't agree right now,
  10. Franc
    Franc Member
    Jul 10, 2003
    5,033
    Melbourne North Sub
    Its got a number of really cool features, but the one I really like is the load cell.....though the heated bed is nice.
    Pity the price, its double the amount I have spent for my Voron 2.4 even before considering shipping
  11. Current
    Current Member
    Aug 10, 2021
    347
    Hey guys, this may sound stupid or something, but it's a genuine question.
    So, i see people have nice looking pictures of the model they are designing, how to you get/do that ? I just have my design in my brain and i use solidworks to design the piece with cut/extrude :/
    I feel like I know enough to get by and design some basic stuff, but not enough to do it professionally or even close to that level.
  12. Franc
    Franc Member
    Jul 10, 2003
    5,033
    Melbourne North Sub
    No way anyones going to cover that here - way too much an indepth topic watch some youtube videos there are tons of people out there explaining how to start and use solidworks. Helps if yuou have two screens though (or two PCs) Theres more packages out there than solidworks for different things.
  13. .Radiant
    .Radiant Member
    Nov 25, 2009
    5,283
    4113
    need to get my hands on some of this stuff. I just printed a whole set of christmas presents for the nephews and ant to re do them all in this :Paranoid:
  14. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,668
    Perth , St James
    I use Fusion 360 and there are a massive number of guides on Youtube, there is a bit of a learning curve but you can do some pretty cool stuff with the basics.
  15. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,403
    Melbournish 3750
    Thinking about taking the plunge and building a voron. anyone locally done it that can comment on what additional challenges we face in australia?
  16. garfield2k
    garfield2k Member
    Jun 13, 2006
    703
    depends where you buy it i guess and luck if it gets picked up by customs.
    from alie you already pay gst so less likely? full kit or self source?
    unique prints store in melb offer some parts that would be better to source here - frame, panels, etc
    Defyant likes this.
  17. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,403
    Melbournish 3750
    was thinking the formbot kit from ali + get someone to print the printed parts for me
  18. garfield2k
    garfield2k Member
    Jun 13, 2006
    703
    yeah thats good value - possibly replace some of the important electrical bits - ssr, heated bed etc..see on the discord channel. also on there, some offer part printing for the aussie/kiwi group as well.
  19. Defyant
    Defyant Member
    Mar 11, 2004
    1,500
    Defyant Modded "Tail" Lights!
    Prolly had 30+ printers in and out of the farm over the past 24 months . From 10+ Ender 3 V2's to CR6Se's ,CR10s Pro V2's , Tronxy's, Tevo's and the printers that have been our constant and buy far out performed the others in everyway have been the BIQU B1's
    We were nearly going to blow a stack of cash on Joe's over rated printers till we tried these. These have made us good rtn on our investment and continue to do so.
    Just get creative and add a Lack !
  20. Defyant
    Defyant Member
    Mar 11, 2004
    1,500
    There's a local guy in AU (not the parramatta guy) that is pretty switched on, I dont think i'd be challenged building a Voron but running our print farm robs me of a lotta time so i'd happily trust this guy.
    https://www.youtube.com/channel/UCyfNef1WVhzrHvqgQCtOorQ/videos
    Thats his youtube page
    heres his webby
    https://www.keenzkustoms.com/product-page/voron-2-4-3d-printer
