3D printer in server rack on slideout drawer
Discussion in 'Overclocking & Hardware' started by tiimo, Jul 28, 2024.
  1. tiimo
    tiimo Member
    May 28, 2007
    106
    Protective Custody
    Hey all.
    I'm wanting to save some space in my room by putting my 3D printer in my server rack.
    It fits in, heightwise, however the drawer that I ordered doesn't actually slide out very far, and came on here hoping people might have a couple of options.
    I thought of getting some rails and fixing a solid tray between them?
    Any thoughts?
    [​IMG] [​IMG] [​IMG]
  2. mtma
    mtma Member
    Aug 12, 2009
    6,883
    I can't tell from the pics but I assume the sliders are close to the generic filing drawer size. I think a possibility is looking at the drawer sliders from bunnings or anywhere else and seeing if you can transplant the bracketry to a longer (e.g 600mm) slider kit.
    That's of course if the cost of new sliders is actually less than a complete drawer kit.
    tiimo likes this.
  3. GumbyNoTalent
    GumbyNoTalent Member
    Jan 8, 2003
    11,801
    Briz Vegas
    tiimo likes this.
  4. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    3,242
    Perth , St James
    I think the issue with one of those is that the slides are only 350mm long so you will not get more than that without replacing the slides as mentioned by mtma
    tiimo and GumbyNoTalent like this.
  5. GumbyNoTalent
    Jan 8, 2003
    11,801
    Briz Vegas
    No I have 4 of them in my 600mm rack which is 400mm wide between uprights, I also have 450mm slides in a StarTech open rack set to 650mm, they adjust up to 550mm on the 350mm draw to 750mm on the 450mm + draws.
    The issue is the stopper on the rail slides, these have latches on the side so you can slide them out of the rails.
    tiimo likes this.
  6. 7nothing
    7nothing Member
    Feb 15, 2002
    1,821
    Can't tell if the proliant has a rail kit. If it does, nice solid shelf :)
    tiimo likes this.
  7. cvidler
    cvidler Member
    19,059
    does it actually need to slide out very far? is there anything on the back of the bambu you need to get to regularly, or almost never?
    I've got a Qidi XMax 3, the spool holder is on the back (worst UX ever), so I'd need it to slide out all the way and rotate around 180. only saving grace is I don't change spools unless it's empty. all black, all PA-CF all the time.
    tiimo likes this.
    tiimo
    tiimo Member
    May 28, 2007
    106
    Protective Custody
    That's a fair point. The only thing on the back is the ejection port. I could even print a chute that brings the waste around to the front!
    tiimo
    tiimo Member
    May 28, 2007
    106
    Protective Custody
  10. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    3,242
    Perth , St James
    Could try mine, sort of does what you want if you have enough width.
    https://www.printables.com/model/540242-poop-chute-with-removable-basket-3-sizes-for-bambu
    Not sure if you could make one that reach all the way to the front unless it goes below the printer as you need a fair slope to get the poop to roll.
    tiimo likes this.
  11. ndt
    ndt Member
    Sep 13, 2004
    2,122
    Is the sliding draw gonna lock in firmly enough to not cause wobbles in your prints?
    tiimo
    tiimo Member
    May 28, 2007
    106
    Protective Custody
    That's something I hadn't really considered...
    ... I'll try it out this weekend
    ndt likes this.
    tiimo
    tiimo Member
    May 28, 2007
    106
    Protective Custody
    So... 4 Cabling sent me a replacement drawer when I whined about the issues I was having with this one.
    The new drawer slides out almost far enough for me to open the AMS unit.
    It doesn't look overly strong and I might be at the weight limit of the drawer, so I may look at putting a panel between rail slides or something.
    The rack appears to shake very slightly when it's printing, however I printed a couple of Penrose triangles for a trial run and it seemed to not have any issues.
    Thanks all for your help/advice :)
    ndt likes this.
    tiimo
    tiimo Member
    May 28, 2007
    106
    Protective Custody
  15. mtma
    mtma Member
    Aug 12, 2009
    6,883
    Those cage nuts on the printer drawer are definitely not happy.
    tiimo likes this.
    tiimo
    tiimo Member
    May 28, 2007
    106
    Protective Custody
    fixed :)
    mtma likes this.
