3d printer troubleshooting/tweaking/building
Discussion in 'Hobby Engineering' started by rockofclay, Aug 14, 2020.
  1. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    Cheers, also I have a Mega instead of a Uno so I take it I am still fine as they are much the same.
    I can just get a cheap Uno clone on ebay.
    Edit do you happen to have the ender 3 stock board settings I could use?
  2. uLa32
    uLa32 Member
    Sep 13, 2002
    416
    western suburbs, vic
    sorry all gone now. i used this guide though: https://howchoo.com/g/mge1mdfkzjv/ender-3-bootloader-firmware-update-marlin got everything going on first go.
  3. yeahbabi
    yeahbabi Member
    Mar 30, 2006
    55
    sydney
    It probably comes with thermal protection,
    but to make sure, connect the printer to a computer/raspberry via usb and send M115 command,
    it'll tell you if you have it or not.
  4. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    Will do that when I get it, any particular software I need for doing that?
    Very new to all this I guess octopi pc server can until I get a pi.
    Edited to fix up typos
  5. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,414
    Perth , St James
    I still have my stock ender 3 board and am in Perth.
    I would tune the retraction settings and maybe also look at coasting .
    As for the print times. If you are running very high travel speeds as you mentioned in a later post and the slicers have different acceleration settings that would radically affect print times. Your printer most likely has a default acceleration around 500m/s/s as that's pretty common.
    FYI, Octoprint is great.
  6. yeahbabi
    yeahbabi Member
    Mar 30, 2006
    55
    sydney
    pronterface from the computer or octoprint from the raspberry.
  7. Outcast_Aussie
    Outcast_Aussie Member
    May 27, 2008
    926
    Peterboro, Distro:Ubuntu
    Groan.. the heated bed has just failed. Aint stopping now at 69 hours in lol
    I assume a wire has fell off !
    The print banding is probably because the temperature here has just changed from 32c (about 40c in my shed) to "Build an Ark" ie: Raining Cats & Dogs @ 17c
  8. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    Cheers will check that out as well may check OctoPrint on my PC as theres a windows version of that.
    What Pi's and cameras are you guys using for OctoPrint?
  9. m3k
    m3k Member
    Dec 29, 2007
    890
    oh boy, failed heatbed- might be broken connection due to no strain releif
  10. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    What do you all print for testing sample packs and filament?
    m3k what are you printing there?
  11. m3k
    m3k Member
    Dec 29, 2007
    890
    cute octo says hello or benchy is my go-to filament test - oh nothing i was just reacting to the video
  12. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,414
    Perth , St James
    I am using the Pi Camera V1 of Ebay, there are better ones but it was cheap and works well enough. The Pi3 i use tends to heat up if i run the camera at too high a res anyway so i think i'm at 1280X1024 or something like that.
  13. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    Ahhh cool.
    My info from the printer.
    Firmware is 0.6 according to the lcd.
  14. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    My first print obviously failed.
  15. m3k
    m3k Member
    Dec 29, 2007
    890
    if thats marlin 0.6 - just fyi 8bit boards go all the way to 1.9xx and 64bit boards are recomended to run off marlin 2.1
  16. m3k
    m3k Member
    Dec 29, 2007
    890
    but i mean- marlins sort of buggy in general i often suggest using classic jerk nowdays still
  17. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    Here is what the LCD says for firmware.
  18. Revenger
    Revenger Member
    Aug 7, 2002
    4,211
    Armadale / Perth
    Second attempt going much better a ittle sticking issue though.
  19. Outcast_Aussie
    May 27, 2008
    926
    We all have failures... there usually about 70 hours in !!
    My case just failed after 73 hours... Layer shift !
  20. CQGLHyperion
    CQGLHyperion Member
    Feb 3, 2003
    1,680
    North Rockhampton
    That might just be the creality version of their build, not the marlin version they used to build it.
    m3k likes this.
